91 Eliminator 83K miles refresh with NOS parts
  • 1 month later...
On 3/3/2020 at 8:18 AM, Red Mistress said:
Installed NOS heater motor blower and fan.
Twain aftermarket- compared to Jeep.
Also Twain vent hole is clocked incorrectly, so correcting PO repair with correct vent tube.
Vapor steamed the evaporator and inside vents, for hours.  Unbelievable how much dirty water came out drain to shop floor.
Just came  across a NOS tube and fin evaporator with that impossible to find foam insulator: https://teamcherokee.com/a-c-evaporator-core-assembly-heavy-duty-oem-cherokee-1991-1996/
i retrofit a plate and fin condenser in mine and it is phenomenal but obviously not original.
DON'T BUY THAT IF YOU EXPECT THE GASKET TO COME WITH IT. TEAM CHEROKEE ARE LYING SCUMBAGS.
Now that I got that out of my system, it's just a standard evaporator core, not any heavier duty than OEM, and it will not come with a gasket. I'm also pretty sure it's for a right-hand drive XJ, as the input and output tubes are offset in the opposite direction from the original. That said, the expansion valve and lines still fit just fine for me, but I'm still a little salty about the false advertising in that ad. I'm also a little leery to recommend A/C parts that have sat uncapped on a shelf for 20 years. Mine had no caps on it when it arrived. They should be vacuum (or nitrogen) sealed with caps on the lines until right before the expansion valve is put on.
5 hours ago, ghetdjc320 said:
That’s awesome! Didn’t even know the existed
I'm still a newbie MJ owner, and I asked several experts ...but this is only one that has ever been heard about.
Feel pretty honored to have for this project, although it's pretty useless in function.
Here it is with good cleaning, plastic prep & couple coats of SEM:
Team GW Team Cherokee etc... Years ago learned about the business practices, they do seem to come across good stuff but it's buyer beware.
Forget about getting customer service if needed, they won't even take picture of item if you want to buy it.
Did you ever figure out what was causing the chirping? FYI mine would do the same thing. Found the rubber in the harmonic balancer had gone bad. The HB had shifted and was barely touching the timing chain cover. (After changing idler pully, water pump.)
On 6/19/2020 at 2:55 PM, fiatslug87 said:
Picture?? :popcorn:
Edited Saturday at 12:00 PM by fiatslug87
The bed rails you've been looking for?
Got square type bed rails from Eagle Scout on October 14-19
Have not found the O.E.M. round type rails.
Haven't been able to determine if round came as factory installed option.
19 hours ago, Strokermjcomanche said:
Emblems ?
Found emblems, but guy doesn't want to re-do his shadow box of Every Jeep emblem ever made, including the Wagoneer II emblem. (He doesn't have Lone Star special plaque :) )
So going to have mine rechromed.
Not sure they would be considered an accessory
17 hours ago, TheDude said:
Brush guard?
Founding Member of the Comanche Preservation Society
My post of Feb 11-20 shows the early style winch / brushguard combo.  I have since found the later style brushguard / winch mount  which I like better.
12 hours ago, Pete M said:
hidden winch?
Jan 24-20 found NOS hidden winch kit & Feb 3 found NOS special XJ Ramsey winch and fairlead
12 hours ago, MJCARENA said:
Rear window louvers?
Haven't really looked for rear window louvers, so that's not it.
