1 hour ago, fiatslug87 said:
Decided to put the rear sliding window switch in the cup holder so I made a switch panel for it.
The aftermarket power rear came with a factory style switch and labels?
Nope, homemade. Using a Grand Wagoneer switch: momentary, off, momentary.
a-yup. :crazy:  thank goodness the truck isn't from the salt-belt and the rot is mostly just the floor and isn't in the frame or rockers.
Added a set of aftermarket louvers that I’ve had for over 10 years to the power slider. I didn’t like how they fit so I added additional mounting points at the corners.
Before:
After:
Mmmm ‘80’s goodness:
Before:
After:
:drool:
Before:
After:
Very sexy
I had a set of bed rail covers from a 2014 Ram 3500 long bed.
I used a chop saw with a fine tooth blade to cut them down.
The truck came with a tool box that I wanted to remove but someone painted the truck and could not bother to remove the tool box. More effort to cover the box than remove one bolt from each side.
That looks really good! Nice work!
Nicely done!
Thanks guys!
I used 3 rows of 3M red tape to attach them. No reason to drill more holes.
Some year when I go back to the original color, I will get rid of the rope cleats on the side of the bed. They painted around them also!
  • 3 weeks later...
Put it under a cover. It’s a Sealskin Supreme, the fit isn’t perfect but it fits over the brush guard, roof rack and sport bar with lights so I’m happy. It seems pretty thick so I’m hoping it keeps water out from some leaks I get (I’m not pulling the dash). If you want one you can get 20% off use code FRIEND-G8LJ49F
Great job on the font and graphics! What did you use for the lettering? And is it also backlit?
Thanks, my wife cut the lettering and graphic out of vinyl on her Cricut. There’s no backlight, no room because of the cup holder and it’s really not very visible from the seats.
