3
The manifold on these isnt always the issue.... they like to break the very front and rear manifold bolts off in the head and then create a leak. Its likely your manifold is good still. I wouldnt buy one before pulling it off and making sure about any broken bolts. My truck has both of them broken, and at least the front one is leaking, but its not bad enough for me to want to fix it until I have to really dig into it.
Adding power steering
dasbulliwagen replied to Comanche1's topic in MJ Tech: Modification and Repairs
I did this to mine. Yes to the list above. The wiring for the power steering high pressure switch should already be there and be plug and play. Good luck finding a resevior for a 2.5. I gave up and used one from a dodge journey and custom mounted it.... unless you have a complete 2.5 power steering pump donor already! Youll need to be careful with the steering gear spacer behind the gear. If your truck is rusty at all, the thing will probably disintegrate when you take it off. Steel reproductions are available if you need to buy one. -
Yes, its possible to do what youre saying, but youll want to keep tension on the chain so it doesnt fall in while doing the head work. Chrysler has a special tool to hold the chains on the bottom of the idler, but as long as you don't let it fall youll be ok. And before you disassemble, line up all your timing marks and don't let the crank move while its apart.
I agree too, no need to swap it as long as you arent having any issues and you don't beat on it. Before my 4x4 swap what I assume was the original 35 under my truck had 340,000 miles on it with no noise.
When that one person decide to waste your time.
dasbulliwagen replied to Blaine.D's topic in The Pub
My thinking for a lock, might be something like a box cover that tabs in at the bottom, and has one hole tab at the top to match to another tab on the bumper where a padlock could be installed, thus covering the whole fairlead area. It would keep crap off and out of that area when not in use too.... unless youre the mudder type, in which case it would be a mud trap.... -
As a long time Jeep dealer tech, Ive never seen this happen on a 3.7 or 4.7. Especially since they hadnt been in there that long, they should have come right out. If youre going to do one head gasket, you may as well do both of them, and maybe get valve job while youre at it. The biggest issues these engine have is with overheating and then having head issues, so if you intend to keep it long term, I would either fix both sides, or get a full rebuilt one to go back in. And then use a dab of anti sieze on the plug threads from now on.
I added AC to my 87 with an 86 donor. The dash side was plug and play, but the engine side I had to make some wiring to attach to the "dealer installed AC" plug on the driver side inner fender, as said, under the washer bottle. The dash side youll need the HVAC box and the controller. I just left the controller attached to the box and fished it through the dash when I put the dash back in. Having all this apart, gives you a good chance to clean the heater and AC evaporator coils while its out if you arent using new ones. Youll then probably need to convert the whole system to R134a refrigerant when you go to charge it. Its been a bunch of years since Ive done mine, so no pics, sorry. Its always had a small leak too. It needs charged every year. And when that compressor kicks in on a 2.5, just don't expect to go anywhere very quickly!
Endless tail light search
dasbulliwagen replied to SIERRA051's topic in MJ Tech: Modification and Repairs
If you can do bodywork/ metal work, Ive always thought that converting the rear bed sides to cherokee style was a good idea, and then use Cherokee lights.... Keeps a stock look, but isnt. Or filling over the light holes, and installing JK style light assys. -
Clutch Slave Cylinder pushrod cap?
dasbulliwagen replied to Kevin Evans's topic in MJ Tech: Modification and Repairs
I think I answered you this on the facebook page. Hope you found what you needed. -
I agree with West Virginia. Lots of stuff around Fayetteville. There is a nice little lodge/hotel there at Hawks Nest we've stayed at a few times. Lots of hiking, natural scenery, white water rafting, jet boat rides. And every fall for one weekend, they let people jump off the bridge at New River Gorge (look up Bridge day). And New England.... We once went to a wedding up there... I think In Portsmouth, but we went driving around sightseeing in some of the smaller towns south of Kittery, Maine, very nice, very old historic areas and downtowns. great to just wander around sightseeing.
91 Comanche electric window controls
dasbulliwagen replied to k4g3d1's topic in MJ Tech: Modification and Repairs
4 door switch sets work also, you just don't use the other switches. And also try something before fixing anything. While holding the switch in the desired direction, punch the interior door panel really hard several times just below the door open pull handle. The window motor is in the door right there and sometimes if you jar it hard enough the motor will work again. I have to do this every once in a while on mine.... at least until I can replace the motor. Or if the door panel is off, tap on the motor with a small hammer while holding the switch. This might at least make it usable until you can fix it right. -
Shifters and Ashtrays
dasbulliwagen replied to Dammerung's topic in MJ Tech: Modification and Repairs
Google: GM Saginaw steering column shift knob -
If I'm remembering correctly, wasnt there a fuel saver option on the early models? One that came with some odd combination of trans and higher axle gearing? i havent seen it referred to in years, but I was thinking I saw it somewhere here in the past.
Adjustable control arms or drop brackets?
dasbulliwagen replied to OldSch88L's topic in MJ Tech: Modification and Repairs
I havent been on here as much as I used to, so I'm catching up a little. While doing my 6 inch lift, I set the axle tubes on jackstands front and rear, so full weight is on the axles with the wheels off and they are all set at the same height as if tires were mounted. Then using the yellow tool shown above setting on top of the upper ball joint, I set the caster to spec which I think is 5-7 degrees positive. In this manner i could unhook one adjustable arm at a time and adjust it and reconnect and then do the other side. Its been a year or so since I did that and its been driving great with no issues. Once you get caster adjusted, then youll need to set toe again, assuming you don't have crossover steering. If you have stock steering, any caster movement or camber movement with change the toe setting. So do caster first. -
Local Jeep dealer MOPAR filter number 05012968AA. They still keep them on the shelf, at least at my local dealer they do. If not, they can usually have stuff in 1-2 days.
I am by no means a full blown Country music fan, but Ive recently discovered Chris Stapleton. He has an amazing natural talent voice, and is a no frills, genuine singer songwriter. His wife Morgane who sings backup for him is amazing in her own right. Here is one with her on lead and him as backup. YOU ARE MY SUNSHINE
Actually, I have yet to hook the speedo back up..... Its been several years now. I couldnt use the original cable due to length issues, but I bought a new one for the application, and it is sitting in a box behind my seat! I still have the original dummy light cluster. This question may be worth starting a new topic for.
AX5 fifth gear and AX15 fifth gear
dasbulliwagen replied to eaglescout526's topic in MJ Tech: Modification and Repairs
Any axle gearing higher (lower number) than a 4.10 on a 2.5 will make if feel slower, as there isnt as much torque multiplication at the axle. don't expect too much from the 2.5. Drive it like an old man, and it will last forever, just don't expect it to be a powerhouse and youll be fine. The advice given above is good. 3000 RPM is right in the sweet spot power band for the engine, and it would be happy there all day long! -
I agree with drop brackets and arms, but if you really are only at 3 inches, you probably don't need the drop brackets. Anything over 3 and I say absolutely yes, especially if you want it to ride good. Core4X4 makes a set of adjustable upper and lower control arms that are fairly affordable and very beefy. Also, you can order them in several colors. They also make an adjustable trac bar, but again, at 3 inches, you probably don't need it. The adjustable arms will allow you to set your caster over the factory adjustment, which I found to not really be enough even at 1 inch over stock. Again, most shops won't go through the hassle of adjusting it, even with adjustable arms, as it takes unbolting the arms at one end to adjust them. Call around to different places to find someone who knows lifted Jeeps. It might cost more due to the labor to adjust them, but it will be right in the end..... -
I used an 86 donor for all the swap stuff in my 87 2.5. Including the external slave bellhousing. The actual bellhousings for internal and external are the same, theyre just set up differently. I did have an issue with the clutch master, as I think the bolt pattern is different between 86 and 87. You won't have an issue with the CAD, especially with the 2.5. Just make it work properly or lock it over permanant, or buy a cable lockout to connect or disconnect at will. If your truck is a shortbed, youll need to have a rear driveshaft made or get the 86 one cut down. The 86 donor truck will also have the NP207 transfer case, which is weaker than the 231, but its a 4 cyl, and you don't expect to heavilly modify it, so again, you shouldnt have any issues. This is also a good time for some front end upgrades, like WJ control arms, ZJ V8 tie rod, bigger sway bar from ZJ or XJ, Dual Diaphragm.
O2 sensor replacement woes...
dasbulliwagen replied to Vineyard86manch's topic in MJ Tech: Modification and Repairs
The 2.5 uses that sensor for proper fuel ratio with the TBI. When I bought my truck it had been sitting for 4 years. It ran like crap, but it ran. I did tune up and several bottles of fuel system service to no avail, it would still stumble at time and run rough.... until I replaced the O2 sensor. Once it kicked in with the computer, it started running great and has been fine ever since. There are several types of O2 sensor wrenches, some of which work better than others depending upon the sensor location. Try different styles on it, and again, it won't hurt to get it hot before trying, even if you do it with a torch or MAP gas torch. And PB blaster.... NOT WD40. Good luck. -
You can't just swap the gears and carriers without setting them up properly. The housings have minor differences and the gears need to be set up to the individual housing. Just swap the whole thing over and inspect/replace whatever you see is bad.
2.5L 4x4 conversion question
I had the same issue. The Azzys linkage would not install. I bought new bushings for the OEM linkage and will be installing that. -
Another for Hyundai Kia. My wife and I are on our third, starting with a 97 Accent, 05 Tucson, and 14 Elantra. Just sold the Tucson to the Father in law to tow behind his motorhome. Ive had very few issues with any of them.... None on the Elantra so far at 50,000 miles. Just a couple of electrical things on the Tucson 120,000 miles (turn signals/ hazard lights blow fuses when its hot out). The Accent had a few but were easy fixes. Sold it at 170,000 miles. We test drove a new Santa Fe, but its really not that great looking and opted for a used Grand Cherokee. My mom just bought a new 19 Sportage AWD. So far so good!
