dasbulliwagen
    3
  1. I removed the mechanical fan for straight electric using a fan controller. I can't comment on putting one in front of the radiator, I know there isnt much room there, but if you can make one or two small ones fit, it would just be a matter of mounting them and wiring them up.
  2. Ive had a 2015 Grand Cherokee Limited for a year and a half now. Love it. Its the nicest vehicle ive ever owned. With the wife working from home, I'm trying to drive her car every once in a while to keep it from sitting too long, a 2014 Hyundai Elantra 6 speed manual we bought new.
  3. On late model Chrysler vehicles, it only got a sensor in the spare if it had a full size matching spare, which is fairly rare, but was an upscale option on some. This includes 07 up wranglers with TPMS.
  4. I was looking for a cheap truck (anything but a Chevy) when I found my MJ, specifically I was leaning towards older Ford pickups as I was always a Ford truck guy. I still love the older 96 and older Ford trucks. But my Comanche fell in my lap at just the right time, and Ill never get rid of it.
  5. Mine is used as a 3rd vehicle for me and my wife, as toy project.... the only one I have right now, and as a truck as needed. Being able to use it as a truck still is priority. And in cooler months Ill daily drive it.
  6. I'm sure as you know living in Michigan, driving ability matters more than having 4wd in the winter. I spent the first 28 years of my life there and never had a 4wd, and rarely got stuck..... I take that back, I did have a Grand Wagoneer for a little while toward the end. That thing was a tank through the snow!
  7. I can't see through it, but I can see over it, its not bad, but it probably helps that I'm tall.
  8. With the help of a friend I've added some decals. I originally just wanted a back window setup, but my friend thought the tree line down the sides would be a nice touch too. I felt the name fitting for a lifted white Comanche.
  9. Bolt on brake upgrades from newer model Jeeps, cooling system upgrades depending on year, recovery points, go over all regular maintinance, electrical checks as mentioned. Most of these items are covered in the DIY section. And of course, if you have ANY questions, feel free to ask.... after a quick search of the site.
  10. Ive also been in love with the M715 forever. Its probably the only thing Id give my Comanche up for. I also love the FC's, and any of the other SJ's (trucks or Wagoneer), and any of the Willys trucks and Wagons.
  11. Ill third the area around Raleigh/Durham NC. There are a lot of smaller quieter areas outside Raleigh that have lower cost of living, but are close to the big city, and close enough to the coast. The mountains would be 4-5 hours to the west if you wanted. Gun laws are decent, we do have state inspections on vehicles, but they aren't overbearing or hard to get through... right now anything up to 20 years old gets a safety/ emissions check ( we plug into the OBD2 port to check for codes and readiness), 20-30 is just safety check (make sure all lights and horn, wipers, brakes are OK), older than 30, no checks. Snow is rare, maybe one snowfall a year.
  12. the AC mounting brackets, the idle control for the throttle body, I'm not sure what else other than the fuel pump assy, and normal MJ stuff.
  13. Several things keep getting put off. The exhaust leak from the manifold... I have a new aFe manifold to put on, it needs a tune up after 12 years, inside cab lights, new carpet to install, front axle disco cable kit to install, High Lift jack setup to install..... stuff like that. I have made progress with things though. The front and rear hitches got installed, the front light bar and lights got done, though I still need to permanently mount the switch, made a new plate mount and new plate light too. Right now I'm fighting with the cooling system. Got a new all alum rad installed and a new Derale fan, but now its pulling more amps than before and it keeps burning out relays in the fan controller. I need to rig that up next, along with a new ground cable from the battery.
  14. Ive been seeing this a bunch on the facebook pages, and I'm really surprised at how heartily people will defend the bronco against Jeep when the Bronc hasn't even been released yet, and then crap all over Jeep even though I'm sure they never even have owned one. I have nothing against the Bronco. Ive always liked them, I was even looking for a Ford truck when I found my Comanche. Its just odd to me the amount of arguing that is already happening.
  15. My next issue is will the condenser I currently have work with 4.0 radiator? I'm starting to think it will just be easier to put a square one back in. Considering the condenser, the electric cooling fan and other custom mounts I have on there that may be the best bet.
  16. I started a downtown cruise last night with a local Jeep group, Zoo City Jeepers, and just a few blocks in I started seeing steam, so I pulled off, and as I pulled off it blew! In the dark last night it looked like just the hose blew off, but after checking this morning, I found it blew the whole bottom tank off the radiator. It was only maybe 5 years old or so, but it was a cheap plastic tank replacement rad with a thicker than stock core. I want to go with an all aluminum one next, it seems prices have really come down on some of those. Mind you, that mine is the square shaped radiator that was used on the 2.8 and 2.5. Were the wide one's ever used on the 2.5, or was the square one the only one used for those. I ask that because I'm wondering about converting to the wide rad. That brings up issues with the core support and finding correct hoses. Let me know what you think so I can make a decision on this soon. Thanks.
  17. The later J trucks, the M715, and the early Gladiator were all on the same platform. Argument could be made for the half cab, the CJ8 Scrambler, and the CJ10.
  18. With the 5 speed it most likely has 4.10 gears in the axles, at least my 86 donor truck did with the 2.8, 5 speed. It won't be too bad to drive, and you probably won't use 5th gear much anymore. Around town you won't notice much. If youre OK with all that, do what you want with it and save up for a 3.4 swap down the road.
  19. I'm planning on a set of these for the WK2 later this year. Ive seen nothing but good ratings for them and I think they are USA made too.
  20. I had the black JK takeoffs on my truck, 2wd springs with longer shackles, and they were a bit too short at stock height and stock mount locations. The red Rubicon ones are about the same length as the black ones. I personally would not recommend them for 3.5 of lift unless you weld on new shock mounts higher up than the low original spring plate mount ones.
  21. A whole header and Y pipe kit might be an option. https://www.jegs.com/i/Pace+Setter/766/70-1208/10002/-1?gclid=EAIaIQobChMI1JKnto7D6QIVAsDICh3z1QBbEAQYASABEgK6GPD_BwE
  22. I have a solution!
  23. I looked through the 86 registry, the second lowest Vin with number under 1000 shows a build date of November 85. And the July one just really seems to stand out. I know the AMC info isn't the greatest, but it really seems odd.
  24. Was the FI badge ever stock on a Comanche? I remember a badge exactly like that on the 85 Ford Ranger my dad bought new with it's injected 2.3.
  25. When they say everything, they mean the entire engine compartment and dashboard wiring on top of all the mechanical stuff.
