For those who have a 4.0 stroker in their builds, do any of yall run an aftermarket ECU or did you get the stock one refreshed? I'm doing a 4.0 HO swap into my 86 after I build the motor and want to know the best way to do this correctly
is anyone running a fuel cell on their MJ's? I'd like to see some setups and would like some advice, I'm thinking about getting rid of the stock tank and running a fuel cell
What is fitment like for older dodge Dakota tail lights on the comanche? I've seen some things about it but I'm not really getting a clear picture as to what it's like
Been reading mixed things about spring over and spring under axles and was hoping to have some questions answered here. Going from spring under to spring over, does it increase ride height? What are some benefits of going to spring over?
Hey all, been doing a 96 4.0 HO swap into my 87 comanche. Been doing all my research and everything to make sure I do it right. Just wanted to know one thing, should I swap the break booster and everything from the 96 to the 87?
I'm trying to find a fuel pump for my comanche because I am putting a 4.0 in it. Can I buy a sending unit and replace the one in my truck currently or would I need to buy a new housing and assembly as well as a pump or is there some sort of alternative?
i've been looking everywhere or one that isn't new preferably right now bc i'm on a bit of a budget. apparently here in central florida they are just about non existent
No idea what the gear ratio is, I've just now started to do modifications and upgrades. What are leaf perches and are there adapters to add to the rear shaft or will I need to get a new one?
Am I able to use a Cherokee drive shaft and axles on a Comanche? I'm doing an engine and transmission swap for my Comanche going from the 2.5 l manual trans to the 4.0 auto trans
I'm at a bit of a loss. My comanche keeps draining the battery and I have no idea what could possibly be draining it. I figured it was the radio fuse or the dome light fuse so I took those out but it didn't seem to help. Is there anything I could possibly be missing that could be draining my battery?
when doing an engine swap, would I be able to salvage the wiring harness from the donor vehicle? if not, does anyone know where I would be able to buy one?
