3
Do You Have 32" Tires and 4.5" Lift??
dasbulliwagen replied to Dzimm's topic in MJ Tech: Modification and Repairs
I agree with the 17's. JK stock 17's are right at 32" stock. I'm running stock JK size on aftermarket 17's with adapters at about 6" of lift. With the aftermarket tires I get minor rubbing on the lower edges of the fender flares. Though I ran stock JK takeoffs for a while with almost no lift. there was only minor rubbing in the front, and only rubbed in the rear under a heavy load. The front has settled at least an inch since I installed the lift. -
The 86 XJ Wagoneer Limited that I got all my conversion parts from was a cash for clunkers trade in. I was lucky I worked at a dealership where they let us take stuff off the cars. That Waggy was spotless in excelent rust free condition. I wish I knew then what I know now about them, I would have saved more stuff off of it. But yeah, that program really screwed up the used car market in the US. And junk yards were only giving $50 each for the cars, which was really low considering that scrap values at the time were high. I guess with the junk yards not able to sell engine or transmission parts, and they had to scrap them totally within a certain period of time, made their overhead cost a bit higher too.
Except that the prices are going up...
If Dennis Collins is involved, youd better bet theres going to be a high margin in it for him. Why he mostly only works with CJ's.
Whenever I need a set of tires for whatever, I go to tirerack.com and search for the size I want and then the customer reviews and ratings, then buy the best I can in my price range. I just bought a set of Cooper Discoverer AT3's for my Grand Cherokee, again based on all around ratings and cost. I havent had the opportunity to buy brand new for my Comanche yet, as Everything Ive put on it so far have been used or takeoffs, and were such a good deal pricewise that the ratings didnt matter. Right before the pandemic hit I put a new set of Continentals on my wifes car, using the same research. If theres something tirerack doesnt have then Ill go about researching through google or in forums like this one, or Facebook pages. Just do your research no matter what and you shouldnt be disappointed.
Front Engine Stabilizer 1986 Comanche 2.5L
dasbulliwagen replied to MOS86MJLB's topic in MJ Tech: Modification and Repairs
If you can't find a new one, just clean that one up, paint it and reinstall. No one else will know the difference. -
Mopar Performance Catalog - Jeep cams
dasbulliwagen replied to Eagle's topic in MJ Tech: Modification and Repairs
Eagle, here are the specs for the Mopar Purple cam you helped me get years ago. I still haven't installed it as my old 2.5 keeps on going. Sorry I can't comment on how well it works yet. -
How to spec out a smooth ride??
dasbulliwagen replied to Tentrax_Brent's topic in MJ Tech: Modification and Repairs
If your rear leaves are flat already, I would look into new ones, maybe some Metric tonne springs, especially considering youll be loaded with overlanding gear. At this point too you could go with rear lift springs and stay spring under, or go with some stock height springs and go spring over. I'm not sure one would be more beneficial than the other, but spring under does control spring wrap better, but that may not be an issue for you if sticking with a stockish drivetrain. I assume too by your signature, you probably still have a Dana 35 rear end. This would be a good time to upgrade to a better rear axle with disc brakes. With extra weight, better braking is always a good thing. -
best engine swap
dasbulliwagen replied to comancheee87jax.fl's topic in MJ Tech: Modification and Repairs
It probably too new to consider at this point, but I really liked GM's new 3.0 inline 6 diesel Duramax. It appears to be similar in dimensions to the Jeep 4.0 -
That does look like the power steering conector. My truck was the same way, no PS, no AC. I added PS and plugged that in and when the pressure gets high, it tells the computer to increase idle speed. I also added AC to mine, and the AC plug is different.
just learned that a minivan has a drop rear axle!
dasbulliwagen replied to Pete M's topic in The Pub
Promasters are as wide as a full size truck. They probably wouldnt be appropriate for an MJ Bed trailer. -
Id really wonder how well those would actually build boost, as each cylinder has its own turbo, there is a period of time between each exhaust pulse, the turbine speed would be up and down and thus boost as well from each turbo. I just don't think one cylinder could spin it fast enough to build any usable boost. When you have them all into one big one, the timing between each exhaust pulse is very short, thus allowing for more turbine speed and thus pressure buildup. Even cumulatively I don't see all those building as much boost as a single could. I wonder too if boost could be lost due to the exhaust pulse timing at each turbo. When one is building pressure, it could be lost backwards at other turbos that are in between pulses. Yes it looks cool, but I don't see it being anything other than an excersize in engineering.
Another NO for the 4.7. I was a dealer tech for several years, and these engines do not tolerate any kind of neglect, and if you overheat it one time, you might as well rebuild it because everything in it will warp, and the valve seats will fall out. Another thing is they are VERY wide, and it would be tight to the inner fenders on the MJ if not impossible to even fit in the engine compartment. As was said, there are lots of better options out there. If you really want to do that much work, Id do a 3.6 with either a NAG1, or an eight speed. Same or better power in a much more reliable and less finicky package.
It's a good quality setup. But, be advised, it will not fit a 4 cyl, AX4-5 setup. The transfer case linkage is too close under shifter being it's farther forward than on 4.0 models.
This is a modified Smittybuilt light bar, made for a Smittybuilt bumper, on a stock bumper. No winch. With a front hitch.
Just as a clarification, my intention was to buy the tires and mount them and road force balance them myself as I have access to the equipment working at a dealership. The AT3 gets top ratings and reviews on tirerack.com and they're US made. Really good snow and rain ratings. With the walmart version being half the price I had to consider them, but I think I'm going to spend the extra and get the 3's. I've never been a fan of the Generals, but that's mostly because I think they are ugly, and not based on any real issues. And there's no way I'm putting Treadwights retreads on my 2015 WK2. I don't care how cheap they are or what ratings they have. If it was an old wheeling rig, it might be a different story.
Mechanical aptitude, or natural talent can count as much as any kind of professional training. If you can show that you have a natural talent for it, some places will take a chance on you. Even places like the smaller dealerships will hire a trainable person with little to no experience for a lube tech. That can be a great foot in the door for experience and possible future manufacturer specific training. A friend of mine started out as a car washer, moved into the parts department, then out as a lube tech, then general tech. He now tunes and builds cars for Richard Petty's Garage.
Yes, Discoverers. That's what I'm asking about.
1987 Sportruck 2wd 4speed 2.5. $250, running (poorly) no rust, paint dead and covered in sap. Asheboro, NC, 2007 1986 X long bed, 2.8 4x4, 5 speed, $125, blown engine- disassembled. Minor rust, paint dead, body damage in bed. Asheboro, NC, 2008
I've been looking at the Cooper A/T3 tires for my WK2, but I've been a little hesitant on the price. I saw someone say that we should check Walmart for their prices and low and behold, they have the Cooper A/T for half the price as anyone else. I was thinking this has to be an accident, but then I figured it out. Walmart has the previous version Cooper A/T for that price, not Coppers current version A/T3. The A/T3 is $252, the A/T is $125. I looked up the reason for this and evidently walmart has an agreement with Cooper to build the previous model to sell at a lower price point. Cooper says they are made exactly the same they were before with same Warranty. Does anyone here have any experience with the previous Cooper Discoverer A/T as compared to the newer A/T3??? I'd love to only have to spend half the money for these tires. Thanks.
