Pete M
Administrators
    114
Everything posted by Pete M
  1. no one likes poo water in the basement. been there, done that on 2 houses.
  2. imo 4 grand is a lot to ask for a non-perfect XJ with that many miles. but rustfree Jeeps in the rust belt always pull a premium. pull up the carpet and verify that "rustfree" claim before buying. XJs are no different than MJs and I've see really clean Jeeps with more hole than floor.
  3. the treeline is a nice touch! I love it!
  4. MacGyver would be proud, both in your skills and your willingness to help out those in need.
  5. yeah, those pesky docs. always trying to remind us of what the body's actual needs are.
  6. sorry I forgot to hand them to ya. it'd been a long day.
  7. she didn't make it. there was just no coming back from the heart damage. but she was in good spirits on her last days! :) I'm up in michigan for the "funeral". we'll have a proper get together in the spring once everyone feels it's a bit safer.
  8. yes, I kinda figured you meant 0-60
  9. damn. rest in peace man.
  10. science can be a blast what happens if you swap back to the old ECU?
  11. taking one up north tomorrow so I'll be down to only 4 loose ones again.
  12. jack up on rear tire, put the trans in neutral, and then rotate the tire around exactly twice while counting the number of times the driveshaft spins. 3 and a half will be 3.55, just over 4 will be 4.10, etc. the link in my signature has a thread all about rear driveshaft lengths. that will help you find out if your new one will need to be longer or shorter than is is currently. and if you're new to MJs, this thread is a gold mine
  13. front axle and front shaft is the same MJ to XJ if they have the same drivetrains. the rear axle will need leaf perches burned into the proper location but will otherwise be the same. the rear XJ shaft will be a foot or so too short for an MJ. what gear ratio is in your MJ's current axles?
  14. Pete M
    F**k salt
    you just need a winter beater that won't make you cry when it falls apart. because they all fall apart eventually.
  15. Pete M
    Face mask
    too many skeeters 'round here.
  16. you can easily drop a few more pounds and not worry about the bead. the tires should be flexing and grabbing, not bouncing. get yourself a gauge!
  17. stress?
  18. it's going to be a bumpy road. it took a bit to get my uncle dialed in, but he hasn't had an episode in many, many years now. I just wasn't expecting bumps due to "doctor shuffling".
  19. dammit.
  20. heavy duty springs, heavy duty shocks, heavy duty rear axle, steel wheels. if you're lucky it might have a small rear window sticker or even maybe the coveted emblem that designated it as a "Big Ton" or Metric Ton.
  21. what am I looking at? did it re-crack along a welded joint?
  22. no real surprises there. it's end of the season in a very tough year.
