Project Uncompahgre - 1989/1999 MJ
Thanks!
Picked up my new tow rig! I needed something to be able to drag this Comanche out west:
5E7475A3-FA9B-4304-B152-81D3DEF2775C_1_105_c.jpeg.8860bc5ab4b9d62a9f82e4e605883c40.jpeg
This truck is HUGE. It easily dwarfs the Comanche.
88044371-E66C-4CDC-B731-76A34840DE62_1_105_c.jpeg.50747255e20fa6e7c68cba73fc12f124.jpeg
I burned in the axle brackets. Ruffstuff Specialties U-bolt elimination perches, shock mounts, and tie down brackets. JK parking brakes with backing plate trimmed to fit Wilwood brakes. Various tabs for brake lines and parking brake cables:
A84396E8-9302-4DE9-9672-5CEBD9438881_1_105_c.jpeg.ef9cd4a42d9ee6b4cd78da813db22982.jpeg
75D24BD2-6539-41DE-A6BB-0E8FD0EFECA3_1_105_c.jpeg.d3f024ec9356ef61bad8b6eb34fd15d1.jpeg
557A77C1-72B7-4DFE-92DB-7D681A92B232_1_105_c.jpeg.4396a5c63b9d430fdae4a34bb64bf5cc.jpeg
Painted! I also added some stainless brake lines and an ARB diff cover:
340FBD0C-0D5A-41AC-9E8A-59F50B9E6FCF_1_105_c.jpeg.bb32149005e66c7b37085cb92086a9f3.jpeg
I welded a steel cup (specifically I repurposed a WK rear bumpstop cup) on the spring top-plates with a 1/2" nut welded on the back side to allow the use of JKS bumstop spacers so that I can easily adjust my bumpstops:
E970E55D-4397-4BCF-9DBC-62893916EA78_1_105_c.jpeg.1397f794bd2067b98082fa410e13181d.jpeg
37803EBD-CF67-4E48-860D-EC63B078C1CF_1_105_c.jpeg.3004b22818c0212f7ecaf07c02bc4514.jpeg
A detail from a few months ago. I'm running a GM R4 a/c compressor with a Four Seasons AN fitting adapter. I then took some new XJ lines and trimmed the flex line before crimping on an AN fitting for both the high and low pressure sides:
049025A9-6AC5-4AB8-9F80-5B6BB030468D_1_105_c.jpeg.9e31530f86885f911247d4f8fdbce81d.jpeg
556C9E21-13EA-4785-A121-CADE897DB2AB_1_105_c.jpeg.7d8d97d249f274f10b9d9ed587bd8e8d.jpeg
Hydraulic crimping tool:
5143E1ED-A822-4FDE-9946-D8E656FFD16F_1_105_c.jpeg.9cb84638c53238360a5cc9cab7a9bf4a.jpeg
Detailed shots of the completed fuel system. I'm running a GM fuel filter and a Corvette regulator with all "push-lock" AN fittings and lines. The 3rd line is the fuel tank vent line with will be going to an evap canister under the hood.
2C13A7C0-7BD8-49BC-A0D7-706208B4488D_1_105_c.jpeg.36fe0707ff3ac2c72c760ac0b9dbbb94.jpeg
29E85A28-EA1D-4493-80BB-63774DE00D56_1_105_c.jpeg.cdccb755ee1025976bd7b554fd1ec590.jpeg
282A5989-BB5F-42F7-A3E8-728AC049857F_1_105_c.jpeg.445f4261dbfd31e84f10a90c8920586f.jpeg
My parking brake setup: 97+ XJ bracket with the mounts cut off and re-welded for passenger side mounting. I'm running a 2DR JK line on the passenger side and a JK 4DR line to the drivers side. Seeing these pictures makes me really wish I had painted the underbody... oh well.
949D618A-0F50-4B1B-B081-3AA283AC524D_1_105_c.jpeg.98654283b8af9cfbbccce55b88120244.jpeg
Detailed shots of the JCR tire carrier:
66A77985-E6D4-45BC-AF61-4DFC9D058ABD_1_105_c.jpeg.42e5079b98abd57a5aae4b5c8136cef8.jpeg
E03216D7-D5AD-4DE2-B466-82695270C3C2_1_105_c.jpeg.ad46d49c206327633b1a33abff380d16.jpeg
And lastly I installed some JCR rock sliders:
AE98CA39-AA86-4741-BF53-D417EC240C47_1_105_c.jpeg.7608a450701caff60291d6b265afc937.jpeg
And thats where it sits now. Building an exhaust system is the next step. I have a bunch of stainless tubing on the way!
The Jeep has a bit more lift than I was expecting. With the JKS ACOS set to +2" and a set of Clayton 4.5" springs I'm sitting at 7.5" of lift in the front and in the rear I'm running a set of factory replacement springs with Clayton adjustable shackles (currently set to +0" of lift) and the Ruffstuff Specialties U-bolt eliminator perches in the SOA configuration (they add approximately 1" over a normal SOA due to perch thickness) but it is sitting at about 8.5" of lift. The Jeep is unloaded with no fluids... but I'm still surprised at the lift height. It was designed to be sitting at about 6.5" of lift all around so I'm really hopping everything settles.
Absolutely amazing build. Your attention to detail and fab skills are next to the best. This thread makes me anxious to get mine back from paint. I’m running a similar fuel set up but I opted with a fuel cell in the bed. Where did you get the spare tire carrier? It’s exactly what I’m looking.
-Ryan
Also I made the same move as you and got rid of my gladiator rubicon and got a ram for towing. That lasted a few months I missed the gladiator so bad and got an offer on the ram I couldn’t turn down. Back in a gladiator Willys. Couldn’t afford the rubicon this go around, prices are out of control.
On 2/22/2022 at 12:00 PM, A-man930 said:
Thanks for sharing your parking brake details :L:
Anytime! I'll have to get some more detailed pictures here soon
-Ryan
I do miss the Gladiator (especially the gas milage compared to my Hemi powered WK) but this truck is going to be excellent on long road trips! Can't wait to try it out.
BE7FE6C8-1A6D-4742-8910-07DF142B7297_1_105_c.jpeg.478d20b1a377ec62729d886e6a5870b6.jpeg
So I had talked to Wilwood 2 weeks ago and they said the earliest I could expect my custom brake order (placed in November) would be mid-April due to supply issues. I was quite surprised to wake up to 3 heavy boxes sitting on my porch!
72561CB4-D15B-480D-ABF6-DF5ABCC799F5_1_105_c.jpeg.9110a153cd1fbacba3169bc78764e5f5.jpeg
Competition Blue JK big brake kit from Wilwood. Installation is not exactly plug and play. Also, keep in mind these are for a JK and will not bolt up to normal MJ axles (though there is a kit available for pre-89 spindles). First and foremost, you need to bolt the rotor hats to the disks. This is easily accomplished with a in-lbs torque wrench but the next step is the tough one. You need to safety-wire each pair of bolts... This was my first time doing it and it took me half way through all 4 rotors to start getting ones like this:
AF64A073-F745-4CA7-B5B1-043D7A642EEE_1_105_c.jpeg.d930c87a8e73bcfd4dee38f16b6cd451.jpeg
I may go back and re-do the rears as I was still learning at that point...
The fronts are THICK:
58650AA1-041C-4056-8770-90C54B2D0E3C_1_105_c.jpeg.13d7c371246a6f3abba7bb07b09fa22d.jpeg
448089D6-A250-4B0A-8121-74249577D47E_1_105_c.jpeg.50c64ef5c8f519ce3cc6407b34f3d859.jpeg
AA968E09-AB52-4442-A7B5-E71D003D331F_1_105_c.jpeg.342ae2bbdc2d6cdc4b2c99c45b26014b.jpeg
I'm running 30" Wilwood lines with Tereflex rubber brake line anchors:
245254A8-990B-43D3-B88F-7BFA9728C9A5_1_105_c.jpeg.f625c82ba416087513f95aa54a2664e9.jpeg
The rear brakes are also vented but only about half as thick as the fronts:
EFA44AA6-9FAB-428C-B33A-90CB30807629_1_105_c.jpeg.022f07fe97617e35c5c6b2953d239de6.jpeg
In the rears I'm running factory stainless steel replacement 97+ XJ hard-lines with 10" Wilwood flex lines:
760DD94F-9425-49E6-A0B0-7E72135AB7BB_1_105_c.jpeg.9b29a14de41e1bc6833851f30deeb8c8.jpeg
F+R Adams driveshafts (the front will need to wait until the exhaust system is complete):
38E0A53D-8545-4F5F-AE39-DE8D97F7662A_1_105_c.jpeg.916e083285d67d5b8e262849086c6a9b.jpeg
One last look at the Competition Blue against the Austin Yellow:
748B1F82-235B-451E-AAEA-90BD9F4222AD_1_105_c.jpeg.f817a740652d13e9545a7908155f52a1.jpeg
Oh and if anyone with stock axles is interested, here's what the XJ/TJ/LJ/MJ/ZJ/YJ kit looks like. It fits all years with a D30 front axle. It just requires pre-'89 spindles (calipers were bolted on pre-'89 before they went to the slide-pin/shelf setup in '90). Oh, and these do not utilize safety-wire so no worries about that obstacle. I had them on my previous '98 XJ:
E601C6DD-3886-469C-BA17-50ED3095F04C_1_105_c.jpeg.3f2a74db57cea5b01ced0100bb341e45.jpeg
95D2876E-9025-4DAA-A464-EE9E4A751D18_1_105_c.jpeg.c833b132b26011683f8720e2cbbd3425.jpeg
On 3/13/2022 at 10:32 PM, scguy said:
That brake setup is a work of art.
I almost changed my order to black when the custom blue was delayed... glad I didnt!
Its getting close!
I finally tried my hand at TIG... some welds were great some were not so great:
447793C9-3DC3-4724-AC1F-475EB90656E1_1_105_c.jpeg.4ca3820a7f01db9dd3ed3c4ab6e263d2.jpeg
Originally I was going to do a 90 out the passenger side just like the factory one but I decided I was just going to bash it on the rocks so I made a turn-down:
56507593-22B7-413F-9C0F-0673C6F0384A_1_105_c.jpeg.460f8f5967cb95d4b9c04058aca1a4cd.jpeg
F77B28C7-AB04-4EB1-AA70-A3001649D517_1_105_c.jpeg.a9cd357a2d84b0517b4118ab1ea3f28c.jpeg
E000E21F-244F-450F-A3A4-72C327A8395E_1_105_c.jpeg.a2a7738c01ceb00f2bcecec37200a194.jpeg
Clutch and brakes are bled and wheels/tires are on!
FD57F9AE-5D4A-497E-A8B7-47BFDF06DB9E_1_105_c.jpeg.a7dd46da15e3cb91370dd77e885f22e2.jpeg
8B97BF37-7579-40DB-ADFF-E7AFA87DD836_1_105_c.jpeg.7709b038c6aae2053abd891cdb723a45.jpeg
I still have about 1" too much rake in the rear. I figure the leafs will lose some height after the tank is full and I have my recovery gear in the bed:
DAA8BEF7-14E7-405F-9BE8-EB77A4530654_1_105_c.jpeg.9c775298699abc0f41d7969a0493b2a3.jpeg
The front suspension geometry came out pretty good! I have a fox steering stabilizer that I'll put on after its aligned.
C3C11B03-5D89-4EA9-BD75-B976B0C15311_1_105_c.jpeg.c329605844a63f92c778b62cab58b9ad.jpeg
DB193714-B2BC-4774-B04E-3CF568C621F1_1_105_c.jpeg.cc293bfac363e5d10c09da0b380213c2.jpeg
Next I need to put some fluids in the Jeep:
20E62092-E380-4E00-9985-1D28631D3170_1_105_c.jpeg.414754ac1e7aed8525676e81c2e35a15.jpeg
After the fluids are in and I wire the O2 sensors it'll be ready to start. I'm just waiting on the rear shocks from fox before its drivable!
On 3/27/2022 at 11:32 PM, MiNi Beast said:
So excited for you. :applause: you have a bit of effort in this build and you are an inspiration. :beerbang:
Thank you!
On 3/28/2022 at 5:16 AM, 89eliminator said:
are you gonna run a traction bar?  I recommend it.
looks killer.  i want that in my garage
Not planning on it now but if I have any sever issues with axle hop I'll fab one up
On 3/28/2022 at 9:10 AM, A-man930 said:
Seeing this is simultaneously inspiring and depressing.  I have soooo much to get done
Thats how I still feel haha
On 3/31/2022 at 8:08 AM, JeepFanatik said:
You might have already answered this.  What paint are you using on the chassis?  Steel-it black???
Just using Rustoleum rattle can black (semi-gloss and satin)
Its alive! I have a few videos of it running but I'll need to get them up on Youtube to view. In the meantime here's some shots of the interior powered on:
A84A4EBA-8CBC-4AAA-A660-F6BA973BA632_1_105_c.jpeg.f00bb2a72fb2977a536c240f7e4c0dea.jpeg
9318992F-5D17-4325-A74A-158E3825243D_1_105_c.jpeg.ca7b401da9c2ede9b87597cdcef39f37.jpeg
Lights!
CB2785BB-6312-4217-B7B3-4D1F21BD2FF3_1_105_c.jpeg.b84d8f89f4ca45dccb16d92c89974c7f.jpeg
So it fired right up on the first try but I subsequently found a few electrical issues that needed addressed. I've solved all but one of them... I'm getting some feedback through the interior button illumination circuit (just a few buttons) when using the turn signals or hazards with the parking lights off. I was hoping it was just a bad ground on the flasher but no joy. Any ideas? Finding the severed wire at the plug under the carpet for the right rear turn signal was a real joy:
6DD566F8-7AE0-4E38-BCFE-EA5DFA0F7648_1_105_c.jpeg.479030eeae22cb6afc2e75ae2f43e0c0.jpeg
I needed a storage solution for my tools and recovery gear and ended up going with a Pelican BX90 Cargo Case and roofrack mounts. I also installed a HiLift jack along the bedside:
A7FEB0C4-0AFC-4E64-9244-EA5EA935BB51_1_105_c.jpeg.1ffed10ef9534fed7337e2f08f8bfd4f.jpeg
B6AB0E77-76A4-4A6F-849A-1EE29A1235B0_1_105_c.jpeg.700d0394d0776fec54e0045028d2cdd8.jpeg
98C18F63-9FBC-415A-80F5-1EB9EBC1F1C2_1_105_c.jpeg.b380f2a0c09b3f39aa67ac813046d3b9.jpeg
35AB4B1C-69C0-480D-970E-02A51B262933_1_105_c.jpeg.4f736b52f7f1293784bc46be41f1efcb.jpeg
2BD7B39A-E4AC-4FE1-BB79-0615633795C5_1_105_c.jpeg.b10061aceb3fe9623451df6ae7d72907.jpeg
CF51727E-31FE-4A33-9A5B-DDA26D8BCA17_1_105_c.jpeg.c6d343ce5ab24dd1a511ee8ac2c636f4.jpeg
I relocated the Warn winch remote plug and installed the synthetic line with a Factor 55 Flat Link:
I think it'll be ready to drive it to get inspected by next week! So close!
On 4/21/2022 at 6:03 PM, 89 MJ said:
So I see on Instagram that this rig moves under its own power now... @USN_JeepMJ
It sure does!
68F6E8FC-4095-417C-BFFF-DC9B0A139572_1_105_c.jpeg.77ffc2af4770db115737fec3a391d989.jpeg
406A4F4A-7070-4A5B-8FA1-71E3A11F32DD_1_105_c.jpeg.ffb04d1f08901490d297a8e3587a637d.jpeg
CEDD7748-08B5-4DDC-898E-AC5F2FF12983_1_105_c.jpeg.265b6ceaab2a606a7b12018bd702b173.jpeg
Picked up my new plates:
BBB2EAEF-3B74-43A7-B0FA-F28B657EC6D6_1_105_c.jpeg.0ed639e1bf4d4aec0f70e11c412709aa.jpeg
Installed a H3R Halguard extinguisher:
3F5F1A01-4A07-4CDD-A666-0C7471762742_1_105_c.jpeg.1262e30ccbe6ad127109e52ab04a3385.jpeg
And a powered Kicker sub (only thing that would fit behind the seat):
89AAF521-8F63-41B9-BAEA-72374EF54368_1_105_c.jpeg.5cb40ce287673fa36b625a83698d4131.jpeg
5564AE0B-08B9-4A49-BBB5-19453D5FE787_1_105_c.jpeg.fd0ed11663bcd65a1464154e967a3b1f.jpeg
38DDA906-B026-4C3D-82E6-F8F0C1856089_1_105_c.jpeg.6c87eba4dd377f01bcd47339e88646a0.jpeg
F4E4226D-8876-4866-ABEB-093E0153D625_1_105_c.jpeg.5391f6478f8c76a60311d17f79e3d391.jpeg
233442E5-9114-4215-9019-D88F8C11153F_1_105_c.jpeg.f6b5b83d3589949ad332dba52bea7695.jpeg
Lastly what I'm currently working on:
C9AD00CA-1364-404D-8EE7-B879D7D5DA44_1_105_c.jpeg.afee7722fac151d5ea10659415f3e794.jpeg
I'll have to get some driving videos. Its an absolute blast to drive!
  • 3 weeks later...
On 4/27/2022 at 12:25 AM, MiNi Beast said:
Awesome! :comanche:
On 4/27/2022 at 8:11 AM, Pete M said:
:banana:
On 4/27/2022 at 8:31 AM, Blade said:
Beautiful truck!
On 4/27/2022 at 1:15 PM, Smokeyyank said:
Damn sexy!
On 5/5/2022 at 1:39 AM, ghetdjc320 said:
Beautiful build! Following along with this and Limey's build has given me quite a few ideas... Thanks for all the time you invested into updating us on the progress and posting pics :L:
On 5/5/2022 at 3:19 AM, Limeyjeeper said:
Truly beautiful build.
Thank you everyone! So happy to finally have this thing on the road. Trip to Colorado is coming soon!
On 5/3/2022 at 6:03 AM, SoCalJeepComanche said:
Need some video with sound of it driving.
Will do!
