Comanche Dawn
13 hours ago, thecodemonk said:
Weird...I don't have that issue. o_O
It's so exciting to hear it run the first time...loud, but exciting!  You're going to love driving it!
It was only on the initial start, Had me baffled why it wouldn't fire. So I stabbed the throttle and bingo fired right up.
Got the clutch dialed in. Not totally happy with the way I got it to work. Had to extend the Jeep slave cylinder rod by 2". Will probably pull the trans at some point and change the thrust bearing and bearing arm. Dealt with a bunch of leaks, mainly because I am not very good at tightening connections!! Learned that Wilwood's are a pig to bleed.
Getting the exhaust done next week.
Got a leaking heater core (brand new) more Chinese junk. Luckily I was going to pull the dash anyway to wrap the wiring harness. Still annoyjng.
2 hours ago, Sir Sam said:
Looks sharp. What all is left for you?
Exhaust, finish the interior, test AC,  probably will need to play with the clutch release bearing some more. That is about it!! or and find a NOS passenger tail light!!
