Comanche Dawn
  On 7/3/2020 at 6:08 AM, thecodemonk said:
Weird...I don't have that issue. o_O
It's so exciting to hear it run the first time...loud, but exciting!  You're going to love driving it!
Expand
It was only on the initial start, Had me baffled why it wouldn't fire. So I stabbed the throttle and bingo fired right up.
Got the clutch dialed in. Not totally happy with the way I got it to work. Had to extend the Jeep slave cylinder rod by 2". Will probably pull the trans at some point and change the thrust bearing and bearing arm. Dealt with a bunch of leaks, mainly because I am not very good at tightening connections!! Learned that Wilwood's are a pig to bleed.
Getting the exhaust done next week.
Got a leaking heater core (brand new) more Chinese junk. Luckily I was going to pull the dash anyway to wrap the wiring harness. Still annoyjng.
