coon.hunter_21 Posted February 22, 2011 Share Posted February 22, 2011 how many miles does your comanche have on it without anything done to the motor? trying to get a idea if i lucked out or not.mine has 278k! Link to comment Share on other sites More sharing options...
cocy Posted February 22, 2011 Share Posted February 22, 2011 220k on the ticker and going strong. Link to comment Share on other sites More sharing options...
mvusse Posted February 22, 2011 Share Posted February 22, 2011 My 87 trail toy shows 136k, but I swapped in another cluster to have a tach, so in reality it has 146k. My 87 daily driver is at 80k. I also have a 96 XJ with 183k on the clock. Link to comment Share on other sites More sharing options...
buxmj Posted February 22, 2011 Share Posted February 22, 2011 245,000 and going strong! Stock engine, actually almost stock everything. Link to comment Share on other sites More sharing options...
valis Posted February 22, 2011 Share Posted February 22, 2011 My '92 has somewhere around 230K on it, but I really don't know. The original idiot light cluster was swapped out with another by the PO. Original engine that still runs great and has good oil pressure, but the 5-speed AX-15 was definitely replaced. The rear of the engine is covered in oil/grime but the trans is nice and shiny :D Link to comment Share on other sites More sharing options...
SubSonic Posted February 22, 2011 Share Posted February 22, 2011 Bought with 280K on original motor (bad), but obviously someone failed to change oil regularly because the sludge was such that it could not hold pressure. Core was fine, put it new motor. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted February 22, 2011 Share Posted February 22, 2011 Odometer shows 346,000 but PO said he replaced everything at 140,000 with a Jasper engine and trans.... so that makes over 200,000 on the rebuilt unit. After talking with him a while back about his XJ, I get the feeling he only replaced everything before because it was leaking oil.... not because it really needed it. And there was a story linked to here recently about an XJ with overb 600k on it with no internal engine work.... so you never know. Link to comment Share on other sites More sharing options...
Pete M Posted February 22, 2011 Share Posted February 22, 2011 all 3 of my MJs that have motors have over 200k each. In fact, 200k seems to be an easy threshhold for a 2.5/4.0 to reach. you really need some serious neglect or abuse to not get one that far. :D 300k is a little harder. not because the engine can't do it, but because the truck itself seems to be cast aside from some other calamity before then. Link to comment Share on other sites More sharing options...
valis Posted February 22, 2011 Share Posted February 22, 2011 all 3 of my MJs that have motors have over 200k each. In fact, 200k seems to be an easy threshhold for a 2.5/4.0 to reach. you really need some serious neglect or abuse to not get one that far. :D 300k is a little harder. not because the engine can't do it, but because the truck itself seems to be cast aside from some other calamity before then. Usually rust from those north of the rust belt. Those southerners have no excuse, though. They should be able to keep an MJ forever! Tie rod ends, control arm bushings, and ball joints also get pretty interesting around 200K miles :D Link to comment Share on other sites More sharing options...
xjrev10 Posted February 22, 2011 Share Posted February 22, 2011 87, 98k 88, 218k 89, 130k till the 2.5 started having issues from neglect before I got it 91, 177k Link to comment Share on other sites More sharing options...
MJRemi Posted February 22, 2011 Share Posted February 22, 2011 When I bought my 88 a few months ago I saw the paper work for the rebuilt motor and the mileage was listed at just over 300,000. I have since only put a few hundred on it. Link to comment Share on other sites More sharing options...
coon.hunter_21 Posted February 23, 2011 Author Share Posted February 23, 2011 :agree: i can't argue with you there.I'm from loudon tennessee which is about 30 minutes south of knoxville.my comanche is mostly rust free the floorpans are probably the worse rustspots on the truck! :cheers: Link to comment Share on other sites More sharing options...
2360 Posted February 23, 2011 Share Posted February 23, 2011 Bought the comanche with about 36,000 (miles) it now has 316,000. The only things I've changed on the engine are spark plugs, a few starter motors, one or two injectors, injector o-rings and a water pump, which turns out I didn't need to change. Link to comment Share on other sites More sharing options...
pitbull4x4 Posted February 23, 2011 Share Posted February 23, 2011 My 89 Comanche 2.5 has 190,000 My 99 Grand 4.0 has 165,000 Link to comment Share on other sites More sharing options...
CTswampyankee Posted February 23, 2011 Share Posted February 23, 2011 my current 1990 MJ 4.0 has 173k all original other than like 90 valve cover gaskets an tune up. Holds revlimmitor every day! New project 1988 MJ 4.0 120k blown engine locked up tight. unknow prolblem but made for a cheap deal on a mint body MJ! :banana: Old beater 1986 MJ 2.8 133k Blown engine chucked rod only lasted me 2 months (2.8s SUCK!!!) Link to comment Share on other sites More sharing options...
coon.hunter_21 Posted February 24, 2011 Author Share Posted February 24, 2011 2360 i praise you!! :bowdown: Link to comment Share on other sites More sharing options...
Justin_k Posted February 24, 2011 Share Posted February 24, 2011 '91 cherokee: 248,000 km's starts as good if not better then moms 06 expidition in the cold '91 cherokee:303,000 km's, little tired but ran good '89 cherokee 488,000 km's, chucked a rod '92 cherokee 358,000 km's, P.O. took a chunk outta the piston somehow? '88 comanche 346,000 km's needed rings, a litre of oil every 20 minutes :roll: '89 comanche 268000 km's Best running most powerful 4 litre I have ever rode in, would smoke 31's on wet pavement in 1st 2nd and chirp 3rd Link to comment Share on other sites More sharing options...
Cody Posted March 25, 2019 Share Posted March 25, 2019 I just for a 86 comanche, has 125xxx miles, any idea how much life it has left? Link to comment Share on other sites More sharing options...
Pete M Posted March 30, 2019 Share Posted March 30, 2019 a million if you take good care of her. but seriously, we've got a couple members who have over 500k on original engines Link to comment Share on other sites More sharing options...
DirtyComanche Posted March 30, 2019 Share Posted March 30, 2019 On 3/25/2019 at 3:13 PM, Cody said: I just for a 86 comanche, has 125xxx miles, any idea how much life it has left? Lots. 2.5L or 2.8L? Either way, you can just keep repairing or replacing things. Unless it rusts out completely. Link to comment Share on other sites More sharing options...
olddude Posted March 30, 2019 Share Posted March 30, 2019 218K 89 Pioneer, bought it new in 89, change oil and filter every 3K miles. Never use anything but Castrol. Link to comment Share on other sites More sharing options...
89 MJ Posted April 2, 2019 Share Posted April 2, 2019 I have a 97 XJ with 303,XXX on it. Needs a crank sensor. Link to comment Share on other sites More sharing options...
MJXJjeepguy Posted April 3, 2019 Share Posted April 3, 2019 Old cluster came out my 91 MJ read 379k miles I ask PO if its the same engine and he wasnt sure he only own 6 years so we never know and by the way look under hood engine look like it never been change so I don't know, maybe original Link to comment Share on other sites More sharing options...
1989commanche Posted April 13, 2019 Share Posted April 13, 2019 My 1989 MJ has 345xxx on it was bought brand new by step dad. Still going strong Link to comment Share on other sites More sharing options...
