coon.hunter_21
Everything posted by coon.hunter_21
I'm taking the aw4 out of my 87 comanche to put a ax-15 out of a 96 cherokee in it.i know all of yall r gonna say thats a cray idea but its what i want to do. what do i need to make the tranny work? the ax15 is out of a 2wd.how can i get my np231 to bolt on it? what can i take a drive shaft out of for this to work? i know il will have to change the input shaft..can i use the input shaft from my aw4?? do i need to order a clutch for a ba10.5 since the input shaft will be for a 87?? what about sensors and such?? sorry for all of the questions I'm just hoping someone on here knows more then me haha thanks yall!
port throttle body on a renix?
coon.hunter_21 replied to coon.hunter_21's topic in MJ Tech: Modification and Repairs
haha.thanks guys.il stay away from them!! -
oh.alright! thanks! can you explain to me how a tb spacer works? -
ive heard of doin this on dodges.basicly you just take a dremmel or a mill or anythign else and mill out a bigger hole above your butterfly valve whic gives more air and in tern more power.or so its said.. :dunno: i was wondering if anyone has tried this on a renix 4.0? is it possible? outcome? thanks yall!
equipment operator on a 1200 head dairy farm.
as it says i flushed my heater core and still the same problem.when the engine is cold there is completely no air hot or cold coming out of vents.as it gets warm it blows warm air but hardly any.the fan controll is like it doesnt even work.high or low stilll the same amount of air comin out.my bro got mad the other day and kicked under the dash and we heard somethin squeeaking and then it was like the high fan controll started workin and it started dumping the air out. what do i need to do?? what could be the problem??
i was shootin for the interior. the outside of mine don't look too good.and i aint too worried about it too muich
just wanted to see what you guys have been doing to make ur mj look nice. custom ideas? parts store goodies? what have yall done?? pics would be sweet :clapping:
the 2 inch lift for cheap..?
thanks yall. ill probably get some soon!! :D and i won't NEED new shocks will i for this 2inch?? -
mine is doing the same thing. my cat isnt screwing up is it??
so ive herd u guys talkin bout the spacers and drop shackles. is there a certain type of spacer thats better than another?? and certain year of chevy?? do you need new shocks if u do this?? I'm only 16 so I'm not rele smart as u all..can someone explain how a DROP shackle LIFTS?? haha sorry if thats a dumbb question. :rotf:
i really like the 2 inch idea so the chevy 2 ich drop shackles.I'm guessin u take the mj shackles off the back and put them in?? and is there a certain type of puck or spacer thats good??like snap ins or wrench adustable?? can someone put some pics or url that shows me?? sorry I'm not reallty smart bout these things :doh:
i need some 4.10 gears for a dana 35 and a dana 30
no catalytic converter??
i thout your 02 sensor was on your manifold on a 4.0 renix? -
thank you! and yea i know it is illegal. i was just wondering what the purpose actually was and if you could run without them. i am amking a trail jeep so i was thinking about taking my cat off but didnt know if it woulod run right or miss or be underpowered?? -
what purpose does a catalytic converter serve?? will a renix 4.0 run right without it??
I'm doin a SOA on my mj.that is about 6" right?? I'm only wanting 4.5". is there any way i can put my stock springs over my axle and do somethin to keep the rear at 4.5"?? rustys has a kit that is 4.5" SOA.has anyone used this?? i don't see how it will sit level so is there any way to make it do that??
gauge cluster and quick connects
and what kind of sending unit do i need to replace the old 1s with?? -
alrite guys! thanks for the help! -
ok first is the gauge cluster.ive got the idiot lights.I'm wanting a new cluster with a tach and gauges. what is the best and easiest way the take the old cluster out? where to unhook the speedo cable is the best?? and is there any other cluster that will plug back into the plug from the stock idiot light cluster??i can do without the tach but would like it.just lookin for tips and ideas? my next question is the quick snap things as found on the fuel rail and tranny coolant lines. my concern is on the transmission coolant lines.has anyone rigged up a way to go without these? or a way so they won't leak or crack? any easy or better way to use them? once again just lookin for tips and advice.
want to buy a set. if they are over $200 don't bother tellin me bout em thanks.
Brake Light switch Issue
coon.hunter_21 replied to Nate C's topic in MJ Tech: Modification and Repairs
can someone put a picture on here of what yall r tlkn bout -
i just changed my brake booster too.and i don't have brake lights until i press my pedal to the floor.i really need a answer to this question too -
SOA options.DIY CHEAP
alright.ill keep them ideas in mind.and are the add a leaf lifts like rough country makes any good?? i cut fire wood and haul scrap metal so my mj takes a load a lot.will the add a leaf decrease my hauling ability? -
I'm sorry but that didnt answer my question..
