Jtslick89 Posted April 26, 2022 Share Posted April 26, 2022 replaced the starter and refreshed the ground along the dipstick/valve cover Link to comment Share on other sites More sharing options...
OldSch88L Posted May 1, 2022 Share Posted May 1, 2022 Not exactly today, but in the last few weeks, restored the parking brake pedal assembly (springs+Jeep ZJ park brake switch) painted pedal arms and all new pedal bushings, installed a new clutch master cylinder and steering intermediate shaft. Oh, and replaced the glove box latch that broke and kept me from opening it... Real fun... Link to comment Share on other sites More sharing options...
OldSch88L Posted May 1, 2022 Share Posted May 1, 2022 39 minutes ago, OldSch88L said: Not exactly today, but in the last few weeks, restored the parking brake pedal assembly (springs+Jeep ZJ park brake switch) painted pedal arms and all new pedal bushings, installed a new clutch master cylinder and steering intermediate shaft. Oh, and replaced the glove box latch that broke and kept me from opening it... Real fun... And by the way guys, don't neglect your steering intermediate shaft... It's crazy how a hair of play in the shaft will feel like lots of play on the steering wheel! It feels like a whole new truck now!!! And on another side note, if you want to replace the intermediate shaft, do yourself a favor and don't attempt to remove the steering box to take the shaft out. A good shaft won't collapse except in an accident, and your steering box bolts will most likely be seized either because of rust or electrolysis to the spacer,and you'll be in a world of hurt. Instead, take off the lower dash (not even a dozen phillips screws), the two steering column to dash bolts, and the two column to firewall bolts. Then unplug all connectors attached to the column and take it out. Took me about 30-45 minute start to finish to replace the intermediate shaft that way. Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 6, 2022 Share Posted July 6, 2022 Got a set of 1984(?) Jeep emblems (brushed finish) that were in excellent condition and proceeded to polish them: 220 grit mechanical sander to remove texture, sequential 1000, 1500, 3000 grit wet sanding then polishing with a DA polisher and Meguiar’s 105 followed by 205 compounds. Hard to get a good picture of the final result but you get the idea. Link to comment Share on other sites More sharing options...
Pete M Posted July 6, 2022 Share Posted July 6, 2022 bling! Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 7, 2022 Share Posted August 7, 2022 Not today but recently recovered and installed my headliner, also added an overhead console with lights, temp and compass. Thanks to @Gjeep for the custom wiring harness and working temp/compass module. Link to comment Share on other sites More sharing options...
Minuit Posted August 7, 2022 Share Posted August 7, 2022 47 minutes ago, fiatslug87 said: Not today but recently recovered and installed my headliner, also added an overhead console with lights, temp and compass. Thanks to @Gjeep for the custom wiring harness and working temp/compass module. That looks excellent. Exactly what I'm going to do on my 91, except mine will be between the visors like they are on XJs. What did you do about the front bracket? Also, is that vinyl wrapped or painted? Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 7, 2022 Share Posted August 7, 2022 Thanks. It’s painted SEM burgundy over a Krylon sand finish plastic paint for some texture, the panels and buttons are silver to match the Laredo dash surround and floor console. I wanted to keep the long visors so I added an aluminum 2x1/8” strip from front to back and used part of the XJ front bracket. For the rear, I added a rivetnut with the long end pointing down. Clearance when visors are folded up: Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 7, 2022 Share Posted August 7, 2022 What year is the over head console from? Link to comment Share on other sites More sharing options...
Minuit Posted August 7, 2022 Share Posted August 7, 2022 2 minutes ago, eaglescout526 said: What year is the over head console from? 90-96 XJ. ZJs and later XJs have a similar console but the "extra" functions like MPG and distance to empty aren't supported by our ECUs. Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 7, 2022 Share Posted August 7, 2022 1 minute ago, eaglescout526 said: What year is the over head console from? I don’t recall exactly but it was RENIX era. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 7, 2022 Share Posted August 7, 2022 13 minutes ago, Minuit said: 90-96 XJ. ZJs and later XJs have a similar console but the "extra" functions like MPG and distance to empty aren't supported by our ECUs. I had a feeling but I don’t recall ever seeing such a small one. 13 minutes ago, fiatslug87 said: I don’t recall exactly but it was RENIX era. Now I kinda want to add such to both my Jeeps. Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 7, 2022 Share Posted August 7, 2022 Yeah, it’s a cut down full length XJ console patched in the back and fiberglass reinforced. Then sanded to fit the contour of our headliner. Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 7, 2022 Share Posted August 7, 2022 Also cargolicious Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 7, 2022 Share Posted August 7, 2022 Looks well done Mike. Link to comment Share on other sites More sharing options...
Gjeep Posted August 8, 2022 Share Posted August 8, 2022 Not enough MJs (or XJs) came with Jeeps cordovan interior. Mikes white/ cordovan mix looks awesome in-person. And the updated replacement seats, panels, and now overhead console make it a really sharp one of a kind Comanche. Good work! Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted August 8, 2022 Share Posted August 8, 2022 22 hours ago, fiatslug87 said: Not today but recently recovered and installed my headliner, also added an overhead console with lights, temp and compass. Thanks to @Gjeep for the custom wiring harness and working temp/compass module. Oh man, there's one of these ceiling consoles in a junkyard I found. I want to do this sooo bad. Excellent. Link to comment Share on other sites More sharing options...
MancheKid86 Posted August 9, 2022 Share Posted August 9, 2022 actually worked on it for once! send it back for mediablast and paint this week Link to comment Share on other sites More sharing options...
Pete M Posted August 9, 2022 Share Posted August 9, 2022 the half-a-jeep came in handy the last couple days. Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 12, 2022 Share Posted August 12, 2022 Added a custom MOLLE panel. Link to comment Share on other sites More sharing options...
Pete M Posted August 14, 2022 Share Posted August 14, 2022 nice Link to comment Share on other sites More sharing options...
Tsalagi Posted August 15, 2022 Share Posted August 15, 2022 VERY nice!! Link to comment Share on other sites More sharing options...
MancheKid86 Posted August 23, 2022 Share Posted August 23, 2022 dropped it off for mediablast and paint! Link to comment Share on other sites More sharing options...
Pete M Posted August 23, 2022 Share Posted August 23, 2022 I don't see the pic Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 23, 2022 Share Posted August 23, 2022 1 minute ago, Pete M said: I don't see the pic How about now? Link to comment Share on other sites More sharing options...
