what did you do to your MJ today?
JeepcoMJ
ordering metal ring 5/8" OD,1/2" ID and 3/8" length. 10 of them to help center my rear rotor up.
and contacting to my best friend's dad(steelworker) to see if he can make metal wedge and/or cut and drill it up for me to fix my annoying bowing front coils.
Traded my old 8 slot grill for a 10 slot. Its off of a 85 XJ that was built in 84. My grills now 27 years old :nuts: lol I just wish it wasnt raining so much so I could put it on
Brandon
Finally replaced the tired stretched original MJ e-brake cables that didn't perform with the recent D44 axle install. I used new AC Delco flex cables and modded them to give me plenty of adjustment for the Ford Explorer disk internal e-brake. It's now a true emergency brake as it should be, not just for parking. Smoke tested by slamming it on at 50 MPH and it stopped quickly. Not locking the rear wheels, but was a nice controlled stop.
well lets see. new JCR bumper, new Midland CB and 9ft whip, new adj. mirrors, more front end chrome, rock krawler long arms, used 33s, new driving light covers, uhhhh sh*t i know theres more but I'm got to get to work!!!
I swapped out all the shocks with KYB gas-a just shocks that I got from a wrecked 86. The shocks were only 6 mos. old so they are like new. I also installed the spare tire mount mechanism from the 86 since my cable was snapped. I swapped in my rotating receiver bar due to the 86 being a LB and the bar is much longer.
I took apart the D44 drum brakes for a full inspection. I cleaned up all the hardware and installed new wheel cylinders. I have never worked on brakes before and putting it all back together correctly was a lesson in patience. I think Mike Rowe should work on brakes for his next Dirty Jobs episode. What a dusty, rusty mess. :wrench:
Replaced old seized fan clutch with a new thermal clutch. It spins!
Replaced both u-joints on rear driveshaft. Used the cheapo Harbor Freight press thing and have to admit it worked pretty well. Was my first successful u-joint replacement (had some issues with the front d-shaft!) so I was pleased I was able to do it myself.
Removed front d-shaft. Am trying to track down a high speed vibration and can't seem to find it. I've replaced nearly everything that moves. Maybe time to look at the tires again, maybe a weight detached :dunno:
In for inspection either today or tomorrow, fingers crossed it passes with no drama :ack:
Today I greased the nipples, replaced the rear bumper license plate light cover.
Went to check the oil filter adapter to see what I need to replace the o rings.
And this is what I saw,
The oil filter gasket sticking out, Ummm, might be why I've been going through so much Mobil 1.
I noticed also when I backed up the rear end squealed a bit, that can't be good.
minibeast-37" lok good! i just got my 35" yesterday. will post pic up tonight after install them on my mj :brows:
got them for 600 dollars for 5 of 35" with rims that can fit on my axles. four of them are mastercraft courser M/T(95% threadwear left) and spare tire is brand new Micky thompson M/T MTR i think. Its brand new by feel hairs on tires and still see color line on it. jamminz.gif
great deal!
The POR15 paint job didn't survive the winter to well.
Repainted the bumper with flat black. The dark spots are where the paint hasn't quite dried.
Cleaned a spare carpet with a rug shampoo machine, scary how dirty the water was after cleaning it.
Looking a lot beter now.
