11
Will my Comanche break in half?
DirtyComanche replied to Gene's topic in MJ Tech: Modification and Repairs
That will take some major fab work and effort to repair... And by repair, I mean rebuild in a way that's not factory at all. -
I could probably put a set of Ruffstuff XJ frame stiffeners up against the MJ frame if you're curious if it would cover enough to partially fix that problem. They're only an L shape, so they would really only work to bridge another repair and make it more proper. I've never tried fitting them against the MJ though. -
Track bar mounting hole elongated?
If it is oblonged I would probably get a wrecker bracket. They changed at some point, early stuff uses a smaller taper and smaller TRE. I believe it's 84-90 and 91+ for the two generations, but it might not be... Either way, I'd get as new of bracket as possible and buy the track bar for that bracket. Alternatively a guy could buy a later track bar, and a Snap-On R121 and ream the oblonged bracket out to fit the bigger TRE. That would be a pain in the @$$ and more money than a wrecker bracket. I wouldn't try to repair it by welding, it's actually some higher carbon hardened steel that they put the taper in, it's a pain to work with at best and would be terrible to try to rework after welding it and could easily damage a reamer. Normally it's the hole on the bracket at the axle that gets all hoopa-jooped. -
Aux Fuse Block qestions
DirtyComanche replied to SBpunk's topic in MJ Tech: Modification and Repairs
Spade connectors and low amperage. I wouldn't use that fuse box. Yeah, those things suck. -
'68 Plymouth Barracuda Notchback
DirtyComanche replied to Rymanrph's topic in Member Projects: Other Cool Stuff
Wow, that's really nice. Love that colour. -
Seems like it's an internal issue in the tcase at that point. Unless I'm forgetting something obvious. The good news is they're easy to take apart. The only real 'special' tool you need is a large pair of snap ring pliers, and a 1-1/8" (IIRC) socket to get the front output nut off.
If there is too little initial preload, as the bearings/races wear in there will be no preload and/or actual slop. That will allow for the pinion to deflect away from the ring gear much more under load, which will cause the actual contact pattern to move up to the top of the teeth, which may lead to a failure of the gear set. It will also decrease the bearing capacity of the pinion bearings, as it will result in them being loaded much more unequally, which will lead to a failure of the pinion bearings and potentially the gear set.
So my 2dr XJ seats didn't work out as well as I hoped. The driver's seat was pretty thrashed, so I planned to swap them side to side anyways. However, when I drilled the brackets off the driver's seat I found that the rails were badly cracked. I think I can just drill the 'stop' rivets out of the rails and swap them over too, but I'm not sure if I am that interested because the seat isn't in great shape anyways. I honestly would like to pick up a set of 2dr JK seats and try to make them fit. Somebody on here did try it (who has long since sold their truck and moved on), and got the driver's seat to fit fine, but had no luck with the passenger seat. I am not sure why the passenger one wouldn't be able to work... So I may try hitting the boneyard and seeing just how spendy such a pair of seats would be. Anyways, I did put the passenger one in on the driver's side, which I am happy with for now. At least I have reasonable access to back there without having to take the seats out. It also meant I could put my first aid kit where it 'belongs' - which is on the back of the seat.
Codename Bumblebee: Now With Oil Pressure!
DirtyComanche replied to Minuit's topic in Member Projects: Your Comanches
8 ohm speakers, that's pretty weird. Trust AMC to decide to do something like that. :rotf:- 60 replies
- frankenjeep
- project
(and 2 more)
Tagged with:
I never check preload once the carrier is in. I have no idea what it would be, and I'm not sure it's a very valid measurement at that point. I just add shims equally to each side until it's quite difficult to hammer the carrier in with my large deadblow.
I found the pedals to be a bit slick, mostly the clutch, so I figured "Why not get some grippy 'race' pedals!" So, Amazon I went, and BAM, in my mailbox: The clutch and brake one went on easy enough, other than there wasn't much for flat surfaces in the right place to drill through and bolt them on. The gas pedal was a different matter completely. It wound up pretty butchered. Back side: I moved it around a bunch of times trying to find the best place for it. I wound up shaving the sides down a bit, and centering it on the pedal like this: It wound up being way too close to the brake pedal, and test driving it confirmed that. So I flipped it upside down, moved it over, and cut one row of holes off it: All in all I think I'm happy with it. The clutch and brake pedal are good, the screws are a bit wonky because there isn't a flat spot to put them into, but I can forgive that. I might pull the gas pedal back out and trim it some more, I haven't decided. I also regret not looking for a matching pedal for the parking brake, but I think I can live without if need be. One thing that has me puzzled is that I grabbed a gas pedal out of the shed rather than jacking up the one that was in the truck. After I put it in I realized it sits way higher. Pedal I pulled out of the truck: If you look at the final picture of the pedals installed, you can see the pivot is in a different location. So, did I swap a HO pedal in by accident? It should not have been one, as it was the gas pedal that went with the clutch/brake pedals out of a parts XJ that definitely was a Renix. Or was the original pedal in my Comanche wrong? I compared it to the pedal in my XJ (also Renix) and it is the same as the one I swapped into the MJ, BUT my XJ has a HO throttle body on it and I don't specifically remember if I bent the Renix pedal or put a HO one in and then wound up bending it too (the floor is not normal in my XJ because there is a doubler and a NP205). I actually had doubts if I was getting full throttle out of the original pedal in my MJ, since it sat so low to the floor to start with, but I never investigated. Anyways, this was another one of those projects that should have taken about 15 minutes but turned into about 3 hours. :rotf:
map sensor operating voltage??
DirtyComanche replied to DirtyDeeds's topic in MJ Tech: Modification and Repairs
6 pounds is 6 pounds. The M90 won't be capable of producing 6 pounds with the increased displacement of the stroker, that's the issue. It just can't move enough air. I think realistically it might make about 3 pounds on an engine like yours, and yeah, not much gain there after parasitic loss. A M90 came up for sale locally, so I was doing some reading. :yes: -
One thing I noticed with the new injectors is that if you lug the engine down way low, it is able to recover from it much better, and it has more grunt in general while being lugged. So that is certainly a worthwhile improvement. I tracked down some 2dr XJ tilt forward seats, just gotta clean them up and swap the brackets. The guy I got them from was parting out several XJs, I didn't have much time but I did manage to snag the center console brackets out of the same rig. My console was put in without them, basically it was just held by the screws up front and the seats. IIRC the MJ rear bracket isn't exactly the same as an XJ one, but it works well enough. Brackets: So at least my console isn't flopping around anymore. Of course I'm just going to have to pull it back out to replace the inner shift boot, whenever I track one down that isn't destroyed.
Yup, 12-15 in-lbs of preload, 6-10 thou of backlash. Having to really hammer the carrier in is a good thing, it sounds like you've got it right. Just avoid the first drive being a long stint on the highway, it's going to make some heat the first couple times its driven. And I suggest using a decent synthetic oil. The factory normally shimmed between the head of the pinion and the bearing, so some install kits come with those shims.
That's really bringing a new meaning to 'base model'. I have no idea though.
The race is the easy way if you don't have setup bearings. But yeah, add .005 and see how it goes. I'm thinking it will be more than that, but it's always a guessing game. Make sure you get the pinion preload in spec, or if you can't that it's just on the tight side and then take it easy on break in. Likewise, carrier bearing preload is your friend, unless you use a case spreader and hammer the carrier in it's pretty much impossible to have too much.
You need a whack more pinion depth. Are you shimming under the race or the bearing?
Where did you pick up the carpet? And what did you paint the interior with? It's looking really nice.
What line is it, anyway?
DirtyComanche replied to Comavalanche's topic in MJ Tech: Modification and Repairs
It goes under a non-critical bellhousing bolt, I can see you have them in the picture... I think on the other side though. None of my stuff is set up like that though. -
You could try swapping it but my gut says it isn't the problem.
TPS adjusted correctly? IAC is actually functioning? Throttle is actually closing?
Does it currently work? There apparently isn't much difference between them.
Use a wrench with it on stands like that. If it really won't go, something is broken. It should come out of 4wd with very minimal force, only the spring pressure on the detent ball will be holding it at that point. At that point if it still won't go I'd take the linkage off the tcase (14mm nut/stud holds it on, IIRC) and try shifting it with a wrench on where the linkage attaches (has two flat spots to mesh with the linkage), if it's still bound up the problem is likely in the tcase. With my home built linkage I can shift it with only one finger on the lever.
1991 short bed metric ton DD build
DirtyComanche replied to mikekaz1's topic in Member Projects: Your Comanches
beds kinda trash, didn't bother me to drill through bondo. No loss then. -
1987 comanche first car
DirtyComanche replied to Jackrabbit41's topic in Member Projects: Your Comanches
Nice Dodge. I've had a couple of those. The last one tried pretty hard to kill me. I recommend replacing the ubolts in the rear if it's had a lot of miles, or been abused.
