86customanche
    Hutto, TX
  • Interests
    Jeeps, sports, beer, mud, anything really
1393 profile views
86customanche's Achievements
Comanche Addict
Comanche Addict (5/11)
  1. A few of the plugs looked wet. Injectors 1-4 all ohm’d ok. Pita to get to 5&6. I cleaned an old set of plugs and tested them, then installed them and it started fairly easily. pic is of plugs removed.
  2. And is there an easy way to check the injectors? Speaking as a novice.......
  3. Update... I tested fuel pressure and it registers 40 psi while cranking. And turning the key to activate pump doesn’t register, and immediately after cranking it drops back to zero.
  4. Here’s another thread on starting issues.... ’92 4.0 4wd last week it ran ok for a short drive. The next day it started and ran for about a minute, then quit. It was very rough, like a misfire or missing a cylinder. now it cranks strongly but doesn’t start, doesn’t even sound like it wants to start. I depleted the battery trying and had to charge it. I confirmed spark on all 6 spark plug cables. I also drained the tank and added 5g fresh gas. I hear the fuel pump activation and fuel drips when I unplug the line at the rail. I plan to test fuel pressure and compression as soon as I get the test equipment. thoughts?
  5. I absolutely love easy fluid fixes! The fluid was low so I filled it and bled the system, and can now shift ok. An earlier major issue with stuck transfer case was also a fluid fix, i.e. the case was empty. I suppose I’ll go now and check the engine oil. thanks all for the assistance.
  6. The only thing I’ve bled on this truck, or any vehicle is myself. But I’ll give it a try. Thanks.
  7. ‘92 4.0 manual I depressed the clutch and turned the key, and it lurched forward. I put it in neutral and it started ok. It won’t shift into any gear, and attempting reverse offers lots of grinding. The reservoir showed some fluid so I added to it. I don’t see leaks anywhere. Thoughts appreciated for this Dad who is just trying to run the Manche occasionally for out of state son.
  8. Door hinges welded back on months ago (after door fell off) but door continued to sag like it has for years. So I added a couple of washers to the lower hinge and it appears to shut ok now without having to lift when shutting.
  9. Skanky gas issue again. Sadly this rarely used MJ frequently has stale fuel, it only gets used for a couple of miles a month, at the most. And it needs to have a few gallons in the tank to avoid stalling while on steeply sloped side hill trails. I now only use non ethanol with Stabil, but still have fuel issues. it’s like I need a removable 1 gallon gravity fed tank......
  10. It seems to have disappeared about the time I realized the tcase was dry. That was another issue solved by CC. I can now shift and the annoying squeaking is gone.
  11. skanky!!! I siphoned some gas and added fresh... she’s very happy now. The truck is used infrequently for farm use, so now will have Sta-Bil with all gallons added. Thanks for the great advice.
  12. Update from today. Started and ran for a min but as soon as throttle was released it died. Beginning to think it’s a fuel quality issue. Going to drain as much as I can out and put some fresh gas in and see what happens.
  13. Yes spark is there at ignition and pump stays on. Have not tested timing. Fuel filter is new about the same time pump was replaced in 2015.
  14. I apologize in advance, this may get long. This ole girl started and idled just fine for about 20 min the other day, went to drive off and as soon as I released the clutch it died. That’s where the problems start. The list of things we’ve checked: fuel is present, spark is present, airflow is good, CPS was replaced. It cranks normal but will not turn over. Acts like it is trying to start but something is missing and I cannot figure it out. Then today, after putting in new CPS, took out each spark plug, wiped them off, and she started right up. Idled perfectly (at least for a Jeep) and drove a little even. During the end of the drive, while trying to turn around, it would actually lose power when the gas pedal was hit ultimately shut off and hasn’t come back on today. Acting just like it did the past couple days with not turning over. Please give ideas as to what this could be. Thanks for your time and help. Fuel pump, plugs, wiring harness, distributor replaced 3 years ago with minimal driving since.
  15. A couple of days later........ the owner tells me he never checked the fluid. So I remove the drain plug and nothing comes out. I then filled it, ran it until warm while exercising the gears, then drained and filled again. It definitely is much happier with fluid, still a little stiff to change tcase selection but the manche is again usable. I’ve got cardboard under it now to check for leaks. Thanks yxmj for the fluid suggestion!
