11
Wasn't available for an automatic :( 91 4.0 Manual 2X4 Shortbed with 225k St. Louis MO That's too bad, I knew you could get one but didn't realize it was only with the 6spd. I don't understand why they won't offer the lockers or the low range tcase as separate options for any configuration.
Hmm, makes me curious to check my collection of Moab wheels.
Stripped harmonic balancer bolt
DirtyComanche replied to 64 Cheyenne's topic in MJ Tech: Modification and Repairs
If the threads are hoopajuped I would buy the correct helicoil kit and not look back. You will need some access to do this properly, not sure how far apart the truck is now but be prepared to strip the header panel off and the rad out. -
Ataki's 88 no real direction build thread.
DirtyComanche replied to Ataki's topic in Member Projects: Your Comanches
Looking clean so far. -
Bilstein Shock Question
DirtyComanche replied to kill_burst's topic in MJ Tech: Modification and Repairs
I'd measure everything and not take anyone's word on what will work ideally for you. If you're running larger tires and stock fenders, you're going to want to add length to the bumpstops, and thus a longer shock may work out better than what is normally considered to be 'correct' as you're going to be limiting up travel and using the down travel. Or, if you're not going for the maximum tire size you may be bumpstopping a lot less; I actually run the stock stops, and then a shorter shock is better as it will allow for more up travel. My lower mounts are relocated slightly (I'm SOA) but I'm actually using stock length shocks. -
Rambler 6 a Lifetime Engine
DirtyComanche replied to texasjack's topic in MJ Tech: Modification and Repairs
Neither is a Comanche body with a Chevy engine in it. So all the 2.8L Comanches are fakes? -
No rear locker?
It sounds like you need very few MJ specific parts. Hit the junkyard. You will have most of what you need without even trying.
Amsoil MTG. What?
Help! Where do I get....
DirtyComanche replied to ruralandalone's topic in MJ Tech: Modification and Repairs
Rockauto.com is selling reprints of the actual factory service manuals for many years of Jeep vehicles. They aren't cheap, but they're worth 10x what they cost... Or look on ebay or use the ones linked off cruiser54's website. -
Full size jeep + Renix or HO + tranny??
DirtyComanche replied to omega_rugal's topic in MJ Tech: Modification and Repairs
It's won't be a speed demon. But it will be way better than stock... I've debated throwing a 4l in my 76 because the 258 is seeming less than healthy. -
AX15 Torque Arm Bracket part number/source?
DirtyComanche replied to johnj92131's topic in MJ Tech: Modification and Repairs
I made mine out of an AW4 mount because I didn't have an AX-15 handy... If you're stuck, it is a fairly easy piece to make. To do it over I would make a different mount for the exhaust anyways, because the previously mentioned 'sad face' one isn't the best for what I'm normally doing. -
HF tools (or PA here) can't do what a lot of the higher end stuff does. I can not physically fit most of the import tools into places on the stuff I work on. To tear an engine down I might be removing several hundred bolts with 7mm 12 point heads, and many of them are in places you can't get a conventional socket or wrench on them. So you're using a swivel socket, or dropped box ends, or long flat box ends, etc, and the only stuff that will actually fit and not round off is the high end stuff. Plus you need a plethora of line wrenches to get at all the inconveniently located B nuts. I still have a bunch of stuff that's been bent, ground, or milled, but there is no avoiding that. Working on a truck, meh, lots of the stuff isn't gonna matter, just have a backup for when it breaks. I won't go back to cheap ratchets though. Or screwdrivers. And I'll admit I have some Snap-On impact sockets at home because I got them cheap.
"The Cure" from RuffStuff.............
DirtyComanche replied to HOrnbrod's topic in MJ Tech: Modification and Repairs
Not many people know about it, and like I said, no idea if the part is available anymore. It was a steel shim with rubber bonded to both sides, so they only lasted so long before the rubber fell apart. As they say, there really is no new ideas, just retakes on old ideas. :laughin: -
I'd like to see how you installed them (plural?) on an inverted T steering system. Got pics? It's installed the same way, where the drag link meets the tie rod. I have hydro-assist and it removes a lot of the load from the actual drag link, so it stiffens it enough that it stops the drag link from wanting to roll the tie rod as bad. I also sucked the tie rod ends in more than you normally would since I had to modify the steering knuckles/arms, so the tie rod won't roll as much to begin with, but it did make a noticeable difference in road handling having The Cure in there. I ordered it on a whim, prior to deciding how the steering would work anyways, and if I really intended to street drive it all the time I would probably order two of them and put them under the TREs, or get the actual FSJ part that does the same thing (elastomeric puck that goes between the TRE and the steering arm). That's assuming the FSJ part is actually still available. Steering looks like this: Image Not Found Which doesn't show much. :rotf: -
Well, I ordered that Luk clutch kit and flywheel. I will see what's going on when I pull the old one out... I went snow wheeling and the clutch wound up slipping in at least one instance, when I got back the disengagement issue was worse and the clutch was making noise. The more I read it looks like there's about a 100% failure rate with machined flywheels, however some of them take longer to show up than others. I think snow wheeling (loading it heavy constantly) probably accelerated the problem on mine, as it most likely was only a couple thousand kilometers since the clutch was changed. That said, I still don't know what parts the PO used or what condition they were in.
They work. Helped a lot with my XJ that uses inverted T steering. -
There's some good pictures of the differences in some other threads on here.
I wouldn't cut the baffle. It is there for a reason. I would swap the arm for the MJ one, or bend it different, or something.
There is no 'new' sending units for these. They sold you an XJ one.
Proto is the actual industrial grade tool line, and is equal or higher quality than Strap-On. No, it is not made in Chindiawan. Strap-On has removed the "Made in USA" from many of their products to "better represent their global market." I do not know what that actually means regarding COO. The wrenches, sockets, and ratchets are all still USA made.
You're getting closer. Check your brake light switch isn't stuck... Give it a cleaning with some contact cleaner and work the pedal a few times.
I have their the full set of both standard and metric 12 points in 3/8 drive. And maybe a few other odd things. I can only get it through Grainger so it's not exactly cheap. I've got some old Plomb hydraulic wrenches, which I believe were absorbed into the Proto brand. I need to try to track some more of those down actually.
If there's money involved then they might be... It's too bad they killed the Comanche helicopter off before production. It was pretty bad @$$.
