Ataki
    San Antonio, TX
1058 profile views
Ataki's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Not sure, but I think you may have a problem.
  2. Mine is done like in the pic above, in place of the factory distribution block. Same valve even. A note- This valve will not keep full pressure to the fronts if you lose pressure in the rear. When I blew a wheel cylinder, even with the bias set completely to the front, I was still losing fluid at the rear, and had barely enough pedal to stop the truck.
  3. Please, Hijack away.... It'll be a boring thread if it's just me in here.
  4. No worries, That's perfect. Now I can get that knocked off my list. And thanks, I tend to get a bit OCD, which strangely is a good thing and bad thing at the same time..
  5. I'll get in on this
  6. Well, USPS showed up and dropped off a couple of packages. The terminals for the a/c harness came in Also, a used shifter from an AX-5 Cherokee. (On right) They appear to be very similar, but I noticed the knob position was different while in gear.. (New shifter on right, or bottom depending on how photobucket screws up) The lower section is shorter, and the upper section is longer. Hopefully this will stop the knob from slamming the dash. Now, stupid question, but... Does the lower section go in like this: Or like this? I've flipped it back and forth so many times I just can't recall.
  7. Hmm, Okay. maybe I'll just keep that in storage for now. I think the main issue was not having wheelwell liners, and the fenders just catching the wind.
  8. Well, I blew out a wheel cylinder on the freeway the other day. Used my proportioning valve to try to isolate the front brakes, Turns out it doesn't completely disconnect the rear output. Still managed to get me home, but the ability to hold pressure in that rear line would be nice. Think I can come up with something So I'm putting off that repair for a bit, and tearing back into the interior. Our last trip up to D/FW, was just too loud. I just installed new fender liners which should help a lot, But I also have 25 sq.ft of dynamat that I'm going to install. Besides, this gives me a chance to fix all the wiring and dash shortcuts I took, since I was in such a rush earlier. I may go ahead and finish one project I set aside. So, I promised a few more pictures, so here's how she sits currently.
  9. Thanks, I tend to get a bit OCD on my engines.. Thanks, I'll do my best to keep adding more and updating the thread.
  10. Thanks for the confirmation. I'll try to hit pick n pull again this weekend, or hopefully source one somewhere for a decent price.
  11. It was a lot of work, but so worth it. I actually did the everything from the cab forward, Underneath and inside as well. Thanks! Actually, I did replace them all. The major components are all from different years, so I had to get creative with the hoses. They still don't fit quite right, but they hold pressure.
  12. Tomorrow I'll flip that lower section around the proper way and double check, but from the picture it does seem to have less of a bend on yours than on mine. Strange.
  13. Mine came out of an ax-4 Thanks for the pic, I'll have to examine that. You picked the proper interior color, btw.
