11
88 Comanche SporTruck Project Daily
DirtyComanche replied to Jeepzahn's topic in Member Projects: Your Comanches
Looking good. Interesting intake mod there, was there a reason to not use a factory one? I love your rubber floor... Wish mine had one. -
So they're likely Venezuelan market only and unless I want to dodge gunfire from feuding druglords I'm probably not going to see one. 10-4.
Green Mesa is on the numbers there. Personally I would not buy a diesel one and plan on driving it long term, even if it is currently working. However, they're extremely rare, so it's unlikely you'll run into one. Parts aren't really available, and they have massive inherent weaknesses. Since it's very unlikely you are looking at buying one of these, that's all I will say. The 2.8L GM V6 is a pile. Be very cautious if you buy one. If it has been kept in good shape they are pretty easy to work on, and it will run a long time if you baby it though. Personally I'd only ever buy one if planning to swap the engine out. The 2.5L was by far the best engine offered in those years. As Green Mesa says, they're good quality but lacking in power. If you're not needing to boot it onto the interstate or pulling a trailer, they're perfectly fine though. Honestly, the MJ/XJ chassis is very easy to work on (the MJ is easier than the XJ even) and there is a massive amount of aftermarket support for the XJ along with a little for the MJ. So everything but some of the MJ specific parts are easily enough sourced. Most autoparts stores will stock nearly every regular wear item. I spent a ton of money fixing up my 88 to daily drive it... But I modified a lot of stuff at the same time, and it was absolutely clapped out and undriveable when I bought it. If the truck you're looking at just needs some odds and ends, fluid changes, and a cleaning, you'll probably be able to get it back to roadworthy for only a couple hundred bucks. If it has been run long term with zero maintenance and hack modifications, costs might spiral...
HO speedometer question
DirtyComanche replied to DirtyComanche's topic in MJ Tech: Modification and Repairs
Exactly, a guy could just put three little pigtails on it and terminate them into a Weatherpack/Molex/Amp/Deutz or whatever connector, so you could still pull the whole cluster out easily. -
Good choice.
Fix your seals first. That's where most of the noise leaks in. I honestly don't think I'd be willing to use peel and seal... but I've thought about it before. B-Quiet Extreme is the bang for the buck stuff: https://www.b-quiet.com/collections/50-sq-ft-rolls/products/b-quiet-extreme-50sqft The performance of these products on a roof is minimal, it will just knock out some of the tinny sounds. Otherwise you need to add mass... There was a thread here that I started on that, I believe. If you to spray something into the B-pillar or whatever, there is sprayable products. I don't know how well any of them work, but Lizardskin seems to be the most commonly used. https://www.amazon.com/050220-Spray-Deadening-Unwanted-Vibration/dp/B001URKV0G https://www.summitracing.com/int/search/part-type/sound-deadening-coatings
Poh-ta-toh, poh-tah-toh. If the HO speedometer drops in the Renix housing and is easy to add wires (and a connector) to, that will likely be easier than messing with the fuel gauge or sender. But it's going to depend what a guy has on hand for parts and what he's trying to accomplish. If you had a HO fuel sender, or were using another gas tank, it might make more sense to use the HO cluster. Either way, it's on my list of things to scrounge parts for. -
I believe they are in fact outfitted as such, and I believe there was pictures on NAXJA. That said, if I don't quit my jerb I'll probably be working down there next winter, so I WILL be looking for them. And if I can get one, I might well attempt to smuggle it back for 'research.'
Yes, there's lots of confusion with people assuming that J trucks were Comanches, and people assuming that a Grand Wagoneer is a Cherokee or vice versa, along with SJ Cherokees being confused with XJ Cherokees, and whatnot else. The XJ I bought from a very grumpy guy who refused to answer any questions on the phone and had no pictures. I thought I was going to buy a SJ Cherokee because the ad said it was an 82 Cherokee, and there's no XJs in those years. I showed up with a trailer, and it turned out it was a turd of an XJ, but hey it was still cheap enough that I wasn't going to go home empty handed.
Both of those options likely exist and were installed in MJ Comanches. When they say "XJ Metric Ton Truck" they mean Comanche, as they were using the MJ designation for military stuff because they're Dana/Spicer and not AMC/Jeep. Somebody on here posted an 86 MJ with a D44 in it that appeared to be factory by all indications, yet it was not the same D44 that was used in the 87-92 Metric Tonne MJs. I bet the BOM quite possibly would have matched that first one. Yes, we commonly believe all 86 Metric Tonnes got the AMC 20, but there is likelihood that some got a D44, but few enough that disorganized AMC never included it in their parts manuals. AMC was notorious for bolting in whatever was around, switching suppliers mid year or midday, buying whatever fell off the truck, etc. Also dates from Dana/Spicer don't always line up with what the vehicle manufacturer uses, as Dana will build axles in batches to supply production for an assumed timespan, which may not be the actual timespan.
I''m assuming you meant 88, because you certainly could get a D44 front in a FSJ in 81. Well, you could in 88 too, for that matter, the Grand Wagoneer used them until the end of production in 91ish. That said, you couldn't just install one in the XJ/MJ chassis, since there was some rather serious differences between them. With you on that. Along with posting the Dana BOM numbers. They will tell you a lot about what it actually is...
Might just be an arrow. I hope you didn't throw out that box off the one you scrapped.
Over heating issues
DirtyComanche replied to dustyinthedirt's topic in MJ Tech: Modification and Repairs
If it doesn't boil over or blow coolant out of the rad with the cap off, it can't be getting that hot. If it's getting hot and the water pump is dead, it will heat the coolant above boiling in the block and when you pull the cap off it will flash to steam and blow coolant everywhere... -
Yup, that needs a cleanup.
That section would probably blind you if it was silver...
1990 Comanche sport truck build
DirtyComanche replied to cbreiter's topic in Member Projects: Your Comanches
Especially when you're going from a cold place to a hot place... All the problems of your cooling system are suddenly exposed. -
The Golden Eagle MJ
DirtyComanche replied to jbain's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Those solenoids do tend to fail. Lots of guys upgrade to solid state contactors instead. -
Good thing it's only got like 63HP, or those portals would get destroyed.
It's good to know that Walker stuff fits that well. Is it all aluminized pipe, or is it just bare steel? It's a little unclear on their site, but it looks like it has some sort of coating on it in your pictures.
Wow, that track bar bolt, no surprise you had death wobble. That radiator looks a little crusty, and like it has seen some trauma (cores squished together at the top). However, I would be tempted to leave it... At the same time, you should look at your coolant pressure bottle, if it's looking like it's starting to crack (they all do eventually) it might make sense to just order up a newer style radiator, a universal overflow bottle, and convert it to an open system. Maybe. Maybe throw some new loom over that wiring harness that's exposed (in front of the radiator), if that gets chafed it can easily short out and melt the whole mess into a blob... Make's for a bad day. -
Intake bolts...Any secret?
DirtyComanche replied to coolwind57's topic in MJ Tech: Modification and Repairs
I don't recall them being any harder than anything else, but I'm used to having to put vaseline on my arm so I can get it through an undersized access hole to get at some fastener that nobody has ever actually laid eyes on. I normally get at them from the top, not lying under the truck. Firstly pull more stuff out of the way for access if you haven't already. The airbox is the obvious big thing, but even things like the washer bottle being out of there might allow you to get a better angle. You can try a magnetic extension or two, like these: https://www.mactools.ca/en-ca/NoValue/NoValue/f0b0964e-1523-48c8-aac4-a2fb01851610/Magnetic-Extensions That way you can just fish the socket/bolt with a short extension on it to where it needs to go, then turn the extension with your fingers to start the bolt. You can also tape the bolt into a socket and do the same thing. Even a wobble/ujoint socket. You can also sometimes just stick the bolt on the end of a telescoping magnet and finagle it into place and turn it with the magnet, you definitely won't cross thread it if you do that. -
Yes, a comealong being ejected at highway speed could be pretty spectacular.
I like how this got hijacked into a beer thread. I used to drink that all the time when I worked in PA. Can't get it west of the Mississippi I'm told, and I've certainly looked. I quite enjoyed it for being a competitively priced brew.
