cbreiter
    Saskatchewan, Canada
1289 profile views
cbreiter's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. About 200 km from saskatoon, so maybe close to home for you? Sent from my iPhone using Tapatalk
  2. Been foggy over the weekend, got a few pictures from in our small town here. Sent from my iPhone using Tapatalk
  3. I realize that, a bench is in the works for my shop, right now every flat surface gets used. I got a few more new parts, but I’m off this next weekend to Alabama. Decided on taking a different route to get the car home. I’m going to drive down with my Honda Fit, (mileage is waaayyyy better, lol) fix the car up, then fly there this October, go to classic Honda’s on the dragon, and then drive the car home. Once the Comanche is all done, I do want to do a longer trip with it, however I’d kinda like to add cruise to it before then.
  4. Got a few more things done, new U-joints, and driveshaft is back in. Also got the cooling system finished up. Got a nice shiny reservoir, lol.
  5. Sounds good, where are you shipping from? Sent from my iPhone using Tapatalk
  6. I actually bought a new module. The panels for the fog light switch would be great, I wasn’t thinking of it, but I probably would need one. Sent from my iPhone using Tapatalk
  7. Well, got the rad put in, and all the closed system stuff removed, I’ve got a heater valve from a ‘95 XJ to plumb in. Been slow going. My redline mt-90 showed up today, also got a daytime running light relay. Plugged it in, and now the high beam indicator works! Sent from my iPhone using Tapatalk
  8. Well, this has signal, and tail lights now. Probably will be upgraded to a rear disc brake soon too. Possibly a small electric motor too, lol. Sent from my iPhone using Tapatalk
  9. Got 4 quarts of mt-90 today, slowly picking away at the truck. Sent from my iPhone using Tapatalk
  10. Got myself a used open style rad, and a overflow bottle from the wreaking yard. Got a few things done over the weekend, took my starter and alt in, went through them, and replaced a few parts, although they pretty much just needed a cleaning and a few new bushings. Pulled the timing cover and replaced the gears and chain. Old New Put stuff back together then. Also got the valve cover gasket replaced. Gapped and put in new plugs, and “windowed” the old cap so I can make sure the rotor is hitting the right spot in it. Replaced the thermostat, and put on a newer style housing, so I could thread the probe for my electric fan controller in. Sent from my iPhone using Tapatalk
  11. Am looking for a daytime running light module, and connector for a ‘90 Comanche. Also would like to find a factory fog light switch if possible. Could also make use of a black centre for my steering wheel (3 spoke jeep) Willing to pay shipping. I’m in Saskatchewan, Canada. Sent from my iPhone using Tapatalk
  12. I’ve been talking to krustyballer16, probably will get a hitch from him Sent from my iPhone using Tapatalk
  13. Didn’t get much done today, had a huge amount of snow to move before and after work. Did get the new waterpump on though This is the radiator I’m thinking about getting. Sent from my iPhone using Tapatalk
  14. I’ll order a new coolant bottle. Was looking at a triple core aluminum rad, maybe that’s overkill though. Sent from my iPhone using Tapatalk
  15. Got one started if anyone wants to check it out. Sent from my iPhone using Tapatalk
