MJCARENA
Everything posted by MJCARENA
  1. Yes, there is a rubber gasket/oring on the master cylinder.
  2. You said it doesn't blow air out of any of the vents. Does it work on any of the fan speeds. Sounds more like a blower motor issue then AC isuue. If I read this right.
  3. You might want to move the ground to the sensor itself and not on the T fitting if you used teflon tape to seal it.
  4. Did you ground the sensor ?
  5. After you remove the screws for the defroster trim, and remove the trim, there should be 4 10mm screws under it that need to be removed, one by each end and two in the middle.
  6. Are you sure it will fit your Comanche. When you click on the blue words, the description says it will fit Ford Rangers. I would give them a call and make sure it will fit. If they say it will, but it doesn't after you get it, ask them if they would pay for return shipping.
  7. Both my 89 XJ and 88 MJ have the bracket. Maybe just the Renix engines had this.
  8. NOS New Old Stock. Older parts that have never been used.
  9. Are you sure it is a limited slip. Sounds like a Lock Right type of locker ( lunch box locker)
  10. Picked up a factory shell for it today. Will try to post photos tomorrow. Sure does fit a lot better then the one that came with the truck when I bought it.
  11. You should be fine with the correct hardware. Had this style rim on the muscles cars i used to own back in the early 80's. Never had an issue.
  12. Look up temperature switch in autozone. part number tu108 is for gauge it says.
  13. You know that the TrueTrac is not a locker, just a limited slip.
  14. He says his neighbor bought it for his teenage daughter to drive.
  15. On my 89 XJ with 33's and an automatic I run 4.56 gears and I like them.
  16. Welcome and good luck on your trip.
  17. Thanks, do you have the measurements of the stripes, how tall they are and the size gap in between them.
  18. If it was all original with that low mileage it might be worth close to that. Otherwise its just a clean 2wd with a fancy paint job. Probably worth about 3000 in this part of the country.
  19. Rear brakes out of adjustment? Lightly apply the parking brake and see how the brakes feel.
  20. Want to make my Comanche into a Chief clone. Would like the measurements of the stripes and lettering, also photos would be appreciated. Googled it, but did not find any close up photos of the graphics. Are the graphics gloss or like satin black? Thanks.
  21. Restored with a CD player and an upside down grill
  22. I always like when they say "the AC works, but just needs a recharge". What about fixing the leak first,that could cost you hundreds. Lots of ads in phoenix say this.
  23. When I got the axle from the JY they only charged a $20 core charge. I think it was just for scrap weight.
