Everything posted by MJCARENA
MJOTM - May, 2015 - revmaynard's '88 Sportruck
MJCARENA replied to neohic's topic in Comanche of the Month (MJOTM)
Great looking MJ. Clean but still gets used. -
I think you changed the wrong temp sender. The one for the gauge is at the back of the head.
It is down by the drivers side motor mount, not to be confused with the knock sensor which has a connector like the fuel injectors.
New tool box perfect fit
MJCARENA replied to Jacob Ochs's topic in MJ Tech: Modification and Repairs
Looks good back there and free is great thing. -
No idle until I pulled a vac line?? hmmmmm
MJCARENA replied to rustybottoms88's topic in MJ Tech: Modification and Repairs
Maybe your idle speed control valve is stuck shut or plugged up with carbon, and when you pulled the line off it got enough air for it to idle again. Like Jeep Driver asked, did you clean your TB?- 8 replies
- plastic ball
- no idle
(and 3 more)
Tagged with:
Whats wrong with this ad?
MJCARENA replied to RochesterMJ's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Must be the rare full time 4wd version. -
selling my mj on ebay
MJCARENA replied to 1CLEANMJ's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Nice looking truck. Did they make a Metric Ton short bed? -
has anyone tried this on their MJ yet?
MJCARENA replied to dustyinthedirt's topic in MJ Tech: Modification and Repairs
I thought our trucks came from the factory with a cold air intake. The opening is right behind the grill. -
without wheel spacers with 1.25 wheel spacers 31x10.5x15 tires, no lift, and they are inside the wheel well.
column shifter cable removal
MJCARENA replied to MuddFoot's topic in MJ Tech: Modification and Repairs
I think he was talking about the cable bracket inside the cab. I had to remove my cable from the shifter to get to one of the nuts holding the booster on. -
Read the reviews on it.
Rescue needed!
MJCARENA replied to johnny quest's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Just does not look right. -
10 grand comanche
MJCARENA replied to sweet home AU's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
For what he is asking, you should not have to do any work on it. I would say $3500-$4000 in my area. -
Replaced my ignition switch. On the way home from work my AC, radio and turn signals just stopped working all of a sudden. Traced it to the brown wire on the ignition switch, the terminal on the switch was melted. replaced the switch and all is good for now.
help! stuck on side of road.
MJCARENA replied to 88ComancheMitch's topic in MJ Tech: Modification and Repairs
Glad you got it fixed. -
Try unplugging and replugging in your crank position sensor. -
Is this part necessary (pic attached)?
MJCARENA replied to mjtjnj's topic in MJ Tech: Modification and Repairs
My MJ has them, and also the axle and springs I got from the junk yard has them. -
Sounds like it was in the wrong place. Should be under the spring plate like the diagram shows. -
Don't worry, your not alone. I backed out of my garage and hit my wifes car, that she never parks in the driveway and bent my rear bumper that was pretty straight. My fault for not really looking back.
I'm Stumped! 4.0 Ho Crank/no-Start
MJCARENA replied to benjy_26's topic in MJ Tech: Modification and Repairs
On a 4.0 HO, the CPS should be open/infinite when checking resistance between the B and C pins.I now have spark coming out of the coil (Had a defective MSD Blaster SS on our hands). Now, I just need to properly index the dizzy (messed up the 1st time, apparently) and we should be golden. Sorry, I thought it was the same as a Renix CPS. -
The CPS should not read infinite. Disconnect the CPS and hook your meter to it and crank the engine over. Should read around .5 volts AC while cranking. -
Renix Dead Spot And Idiling Low
MJCARENA replied to 1989 Eliminator's topic in MJ Tech: Modification and Repairs
Post #8 says he changed the o2 sensor. When you changed the TPS did you adjust it also. My 89 XJ did this problem a couple of times. One was a bad TPS, changed it out and was good for around 2 years. Started doing it again and this time I just had to unplug the IAC and replug it in. I assume you cleaned the throttle body where the IAC goes. -
Front Brakes Always "on"
MJCARENA replied to crouse's mj's topic in MJ Tech: Modification and Repairs
Are you sure the Master Cylinder is the correct one, if it is then you might have the same problem I had. I had a problem when I went to the dual booster upgrade. My problem was the push rod from the booster was not adjusted correctly and was not letting the piston in the Master completely move back to unblock the hole to relieve the pressure to the calipers. Then the heat generated from the dragging brakes expanded the brake fluid in the calipers and made the problem worse, almost could not move. By loosening the nuts that hold the Master onto the booster, the brakes would release. Had to measure the push rod length and the piston hole depth that the rod goes into and adjusted the rod to the correct length by turning the adjuster on the tip. No more problems after that. -
That is the vent line for the axle.
X2 Sounds like it will just be a Grand Cherokee.
