Everything posted by DesertRat1991
"Scout" might have been a better name than "Pioneer," but International Harvester had dibs on that one through the 80s. A Comanche Scout would have been a nice companion to the Chief model. "Comanche Eliminator" is a real curiosity. I imagine that would make for an awkward drive through the many reservations we have here in So. AZ. lol...
what is the peice under the rockers
DesertRat1991 replied to the-sandman's topic in MJ Tech: Modification and Repairs
What makes you say that? Wasn't there an optional OEM rear tube bumper? -
Plus HO motor and OBD1.
If you're resigned to butchering the truck then why stop at 33's? Hell, you could run 35x12.5 with 3" lift and "some trimming." R.i.P. clean '92.
Great info! Def looks like you could trim a universal mud flap to work with these. Thanks.
Do you need OEM mud flaps to run with these brackets? Or, can you trim any piece of rubber to the right shape and bolt them to the bracket?
Tail Light Extruded U Nuts
DesertRat1991 replied to amsuco's topic in MJ Tech: Modification and Repairs
We call them u-nuts or speed nuts. I found them in the bins at the local ACE hardware. -
I've recently been mapping out parts for an (eventual) A/C install. This bundle at RockAuto has the compressor, condenser, o-ring kit, expansion valve, and accumulator/drier for $195. I think that's everything under the hood, except hoses. https://www.rockauto.com/en/moreinfo.php?pk=9827000&cc=1181775&jsn=407
2018 Midwest CC PowWow - Badlands, Attica IN on August 25th
DesertRat1991 replied to 89eliminator's topic in The Pub
Great pics! That guy is in quite a jam. What was the fix? Did you guys have the gear to swap out the studs? -
So if MJ bench and bucket floor brackets are the same, and MJ/XJ seats are the same -- then MJ bench floor brackets will readily accept XJ bucket seats? Then I guess I'm sorta confused as to why so many MJ owners are in the market for new floor brackets? Is there an advantage to the new production brackets that I'm missing?
Thanks for sharing. Observations: 1) All that shiny, new - and straight - chrome! Beautiful! 2) It's interesting that the grill on the blue truck is "upside down" in this 1986 dealer promo vid. Guess that debate will go unsettled. 3) I thought side mouldings only came on Eliminators, but there weren't any Eliminators in 1986, right?
Picking up a new hobby I've always wanted to learn!
DesertRat1991 replied to Knucklehead97's topic in The Pub
Serious question, is it safe to weld inside an attached garage? Or do you guys have a separate shed out back for flinging sparks? -
Sliders with up-angled tubing like JCRs, but follow the body line like yours do.
There is an MJ D44 on car-part.com listed for $1500+shipping at the moment. Dude said he sells them "all the time" for that price... lol.
1) Are you aware that a D30 out of an XJ Cherokee would be a direct swap for your truck? 2) Are you aware that the XJ/MJ D30 is driver drop, not passenger drop? 3) You do not have a Dana 44 rear axle in your truck.
1990 Black Eliminator Decals
DesertRat1991 replied to Parei_doll_ia's topic in MJ Tech: Modification and Repairs
How are the side moldings attached? Did you have to drill holes in your sheet metal to accept some kind of push rivets? -
adding AC to a non AC truck
DesertRat1991 replied to ICEBOX's topic in MJ Tech: Modification and Repairs
I've been looking into this recently myself. I think I have the hardware mostly figured out, but the electrical part has me confused. Biggest questions: 1) Does anyone know if the 91+ trucks are pre-wired for A/C? 2) Where is the "cabin thermostat" (temperature sensor) located? Or, what tells the compressor to cycle on/off? -
At scrap yard now.
DesertRat1991 replied to ftpiercecracker1's topic in MJ Tech: Modification and Repairs
What did they charge for parts and labor? -
Scavenger hunt! this month: guess the package!
DesertRat1991 replied to krustyballer16's topic in The Pub
Congrats KB! We just had our first (a boy) on 06/07/18. You're in for an awesome ride! I'll guess: 6lbs 8oz 18.5" tall August 25 7pm -
http://www.rhinorack.com/en-us/products/roof/roof-racks/vortex/batwing-awning-left-_33100
Crossed a couple of easy ones off the to-do list this weekend. First, was swapping in the Putco light harness. And second, was installing cruise control. To activate cruise, I did need to buy a new turn signal lever. Interestingly, I couldn't find a part number for a turn lever WITH cruise control and WITHOUT wiper delay. Was that combo never offered?? Anyway, I had to buy one that is labeled for cruise + wiper delay. It works great, but now my wiper nodes are labeled wrong. Which, of course, means I get to have fun researching wiper delay components. Woohoo!
jeep lighting mods...
DesertRat1991 replied to mikekaz1's topic in MJ Tech: Modification and Repairs
Yes, lights on, engine running. It was like 14.14V at the battery, 14.12V at the Putco socket and 13.9V at the stock socket. I changed only the harness. Still running stock headlights for now so the load is the same and there shouldn't be a change in current draw. But I do agree that there should be a little less heat generated through the conductor -- which is a good thing. -
I've read this a few times around here. Just finish swapping in the putco harness and I'm underwhelmed, at best. There was only 0.13V difference at the headlight socket between the stock harness and the putco harness. IMO, that means the stock harness performs just fine. I think my next move will be Hella E-codes and some 80/100W bulbs to get better bang for my buck out of the putco harness. -
Pizza Oven interior temps
DesertRat1991 replied to KANTANKRUS's topic in MJ Tech: Modification and Repairs
