I also have a squeal and when I put water on the belt it stops. So does that mean either I need a new belt or I need to check and see if it is tight enough.
yes, alternatively my old XJ has a squeal that was incurable, even after multiple belts. I found a squirt of tire shine on the running belt would keep squeaks away for atleast a month or so.
If you've verified it's a belt issue with the water test, and verified your belt is in good condition, and properly tensioned, then it's most likely that your pulleys are out of alignment. The water test can help you identify which pulley is the culprit. It could be bent, or running off balance due to bearing wear.
In my case, the previous owner had replaced the harmonic balancer and idler with aftermarket parts. Neither was in proper alignment with the power steering pump, which was where the belt chirp was coming from. The PS pulley on the 4.0HO isn't fixed in place with screws, it's just pressed onto the shaft. So, I rented a pulley puller kit from Autozone and was able to adjust adjust the position of the pulley on the shaft by about a millimeter.
Chirp cured.
