Master7122
1421 profile views
Master7122's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Looking for a set of Cordovan/Burgundy halo headrests (the ones with the center cut out) and a set of factory floor mats in the same color
  2. I understand that but I'm in the process of restoring a comanche so they need to be for 2 door xj or mj. The 4 door switch would throw everything off
  3. I appreciate the generosity but id rather have someone that needs them for a cherokee get them. The driver side one wouldnt be staying in the truck
  4. I'm looking for a set of chrome power window switches for my comanche. I need everything to convert to power windows so bonus points if you have all the wiring/relays etc. I have plenty of comanche parts to trade or id buy depending on price and condition.
  5. 4.0 5 Speed 4x4 Dana 30/44 Metric Ton 92k mile Locked Rear End Ax15 w/ external slave 3in lift Plow truck during winter rig during the summer
  6. Thank you, that was all i was finding, figured i could use it but maybe hidden somewhere there was an oem one
  7. Searching online for an inner shift boot for my comanche, can’t seem to locate a specific one (non look like the one i removed) curious if anyone’s used a different style/kind with good results?
  8. Thank you! Judged ordered the 2 valves and gasket
  9. When i fill my comanche up to full, gas shoots out of the filler neck then it stops. Is there like a check valve that could go wrong? It used to stop the gas pump on its own... been doing it for about 3 fill ups now. It’s a lwb if it makes a difference with tank size
  10. What all do i take from a ZJ for the swap? There’s tons in my local junkyars
  11. Thank you guys super helpful! I’m missing parts 11,23,26 per eagles picture
  12. Does anyone have a picture of what the Dana 44 drum brake insides look like? I’m pretty sure mine are missing a couple components (mainly parking brake pieces) My comanche doesn’t have a working parking brake or lines even going to the drum for one
  13. I know this is hard to find but if anyone would like to part with one please let me know. Just looking for the switch panel
  14. I’m using Chevy 2in drop shackles and polyurethane bushings
  15. 31 bfg all terrain leads are stock metric tons and 3in lift Yes it’s been confirmed, I’ve snapped a unjoint because of this issue Will do over the weekend eagle Done, thank you for the link to explain how
