DesertRat1991
Everything posted by DesertRat1991
  1. What's going on with the engine hoist in the first pic? Are you lifting the vehicle by the swaybar bushing bolts?? Are those your old UCA bushings on the ground in the 2nd pic? How'd you get them out in such good condition? I had to bore the rubber out with a 1/2" drill bit and mangle the outer metal sleeve with an air hammer. They were unrecognizable by the time it was all said and done.
  2. You can reuse them, but after overhauling the rear suspension it really seemed like half-assing it to reuse the old fasteners. I bought new ones from Mopar Parts Giant: https://www.moparpartsgiant.com/parts/mopar-bolt-hex-flange-head~34202118.html
  3. Holy cow, a 5+1 leaf pack?? Well, one thing is for sure, the springs you took off were not OEM leaf packs. Even metric tonne springs were only 3+2, and OEM springs are kind of rounded off at the ends. The overload leaf in pic 2 looks squared. I would agree that it looks like your new leafs are too short, but the cracks at the front mount are concerning. I hope someone didn't cut it off and try to re-weld it in a new spot to fit that bastard pack. Take a wider angle profile shot of the truck.
  4. http://tinypic.com Upload pics. Paste the url here.
  5. Snap a picture of the shackles you took off the truck as well.
  6. Grab shackles and leaf spring plates. Someone in the rust belt will need a set. Out of curiosity, what would you guys say is a good price to pay a U-pull yard for a tail gate?
  7. The link below was a pretty good write-up until about a week ago when Photobucket disabled 3rd party hosting. You can still see the pics you just have to open each in a new tab: http://www.jeepforum.com/forum/f11/how-i-just-put-new-floorpans-patched-holes-xj-lots-pics-372669/
  8. Awesome truck! Congrats!!
  9. Great list! Thank you! I like seeing which graphics packages have managed to survived. Don't think I saw a single truck with the squiggle graphic this time. Which is most assuredly the greatest of all the graphics packages. But I may be biased... :yes:
  10. What's your beef with the BFG A/T? The KO2 is a fine tire in the wet and capable enough for light mud use, and comes in the size you want. There were complaints years ago about the KO being kind of squirrelly in wet conditions but the KO2 seems to deliver improved performance in that area and is snowflake rated. I ran the KO for years and had no problems in the rain or snow back east, but opted for Grabbers this time around. I would have no issue running the new KO2s. You're also probably aware that moving down to 31x10.5 would open up a huge range of options for you. What difference does 1" less GC make for a truck that will mostly see pavement use, and won't do any mudding serious enough to actually need mud tires? My best advice would be to drop down to 31x10.5 and get the best wet weather AT you can find since that seems to be your main concern.
  11. Thanks guys. Maybe I'll try ordering that Dorman part and seeing if I can find a shop to weld it up. I would prefer to keep as much of that smooth shank as possible since that's bearing all the load. My only other idea would be to dremel loose that weld and put the air hammer to that nub. Assuming it's some sort of rod connected to the shock mount, that might punch it out of the socket. Or is that a crazy idea? Don't suppose anyone has cut into that section of the frame rail before that could confirm how that shock mount is fitted to the frame?
  12. Well, needless to say my rear shock install didn't go as planned. The upper rear shock mount threads snapped clean off. How screwed am I? Any ideas on how I can fix this or replace the mount? It looks like some kind of rod passes through a tube in the frame rail and is welded into the wheel well. Does this assembly have a part number?
  13. Who manufactured the bull bar?
  14. Test the Throttle Position Sensor. You may have disconnected or damaged it while messing around with the throttle body. http://comancheclub.com/topic/11634-renix-throttle-position-sensor-tps-testing-adjustment/
  15. BRB, heading out to lunch... in Arizona...
  16. Here's the reply I got when I contacted them through their website back in April:
  17. I just went through this. MJ specific kits are hard to find but I researched 3" XJ kits from Zone, BDS, Rusty's, Rough Country, Rubicon Express, Skyjacker and Iron Rock Off Road. I could not find a more complete kit for the money than the IRO XJ 3" Premium Lift Kit which included adjustable UCA/LCA, double shear track bar, shackles, and Bilstein shocks. If you call them, IRO will delete the XJ leafs from your order so you can source your own. Then they knocked another 10% off during their Memorial Day sale and I had to jump. All the parts are here and they look great. Haven't had a chance to install yet.
  18. Congrats to DirtyComanche! With a truck that isn't afraid to flash some Krylon, why not color match the topper too?
  19. Adding A/C to my truck is on my list of dream mods. A DIY write-up would be AWESOME!
  20. A huge wheel base Jeep on all-season tires with a bed too small to sleep in..? *sigh*
  21. These are great threads! Useful and informative. Didn't see one for May, hopefully there will be one for June..? Bonkers, thank you for taking the time to gather all this info together!
  22. That sounds... dangerous.
  23. Wow, great link. Thanks!
