DesertRat1991
Everything posted by DesertRat1991
  1. Nice build! What's the source on that front bumper?
  2. Well, that would depend on what parts have been replaced...
  3. Welcome! Let me help you out -- these are the pics OP posted to the CC gallery:
  4. 1991- 2001 XJ/MJ use the same drag link as the ZJ. In this case, you just need the upgraded tie rod. 1990 and older XJ/MJ use a smaller drag link TRE and adjustment sleeve. In this case, upgrade both drag link and tie rod assemblies.
  5. Flagstaff? Happy New Year! They say we might get some down in Tucson too.
  6. Picked up an HD Tie Rod and new TREs from Iron Rock Offroad during their Christmas sale. This thing has gotta weigh north of 12lbs -- 1.25" dia and solid.
  7. XJ soft lines will mate up fine with the MJ hard lines. I can recommend the Rough Country kit, P/N 89715. Includes front and rear SS lines spec'd for 4-6" lift. Well made. Hooked right up.
  8. Looks like a mild lift consisting of taller coil springs, extended sway bar end links, and aftermarket lower control arms in the front. Find stock replacements to return to stock height. Track bar, Steering and upper control arms look stock. Front brake lines look newer. They could be extended aftermarket lines. When returning to stock keep an eye on them to make sure they don't bunch up and interfere with tires or suspension. You've got an add-aleaf in the rear. Remove it to return to stock height. You didn't include a pick of your shackles. Check them. People often swap in longer shackles to complete the budget boost in the rear. Can't tell if those shocks are new, old or just dirty. When returning to stock, take some ride height measurements and select the appropriate length shocks for your application.
  9. Post a pic of your front and rear suspension setup. It isn't hard to spot what is stock and what is not.
  10. Here is what the '91 Owners Manual has to say:
  11. Sorry to hear. Get well soon!
  12. You're not gonna push around 3500lbs enough to actually see anything while laying on your back. You need a buddy to bounce on the font end and rock the hell out of it Left/Right while you're under there. Or, slide your cellphone camera under there and film a video while you do the rocking. Were your lift components installed with red Loctite? If so, those nuts aren't gonna budge without heat, even if they need it. It can be deceptive. Your bushings break in, hardware needs to be retorqued, but the torque spec checks out because the nuts are super glued to the fastener threads. Solution is to loosen and retourque. My money is on control arm bolts.
  13. You can make a replacement rod.
  14. Heads up that LA Police Gear has 25% off everything and free shipping over $125 until midnight tonight. Med supplies included. Good chance to stock up or swap out aging items. Use code: SB2018 https://lapolicegear.com/more/first-aid.html
  15. Finally a price drop on the dually. $4500 --> $3900. I'm surprised it hasn't sold yet. Been listed for nearly a year. What do you guys think it's worth..? 89 - $3900https://mohave.craigslist.org/cto/d/1989-jeep-comanche-dually/6745473060.html
  16. Seems like the bed was designed just big enough to fit one of those roof top tent setups and not much else. It supposedly has a removable roof and doors, and a flip down windshield. I wonder if there are roll bars around the passenger compartment? If not, and they end up offering a sport bar setup like the old Scrambler, then you won't even be able to run your tent setup. I think it's pretty clear this was not aimed at the F150 crowd. It's a Wrangler for guys who didn't want to tow an adventure trailer to haul a few extra items.
  17. You ran 32s with a 3" lift? Any trimming required?
  18. I often go shooting out in the desert by myself. I suppose the thing I worry most about is an ND through my foot/leg when I'm miles out in the middle of nowhere. To me a good tourniquet is most important, everything else is just comfort/convenience stuff. I built two vehicle kits by bundling the three items below from Rescue Essentials and added extra consumables where necessary. I keep one kit in a Pelican 1400 behind the bench in the Jeep at all times. In truth, the only thing I've ever actually used in the last 3 years were the bandaids and antiseptic ointment -- which brings up another point -- if you can swing it ($$$), remember to buy extras to train with, izzy bandages and tourniquets come to mind in particular. And don't forget to train your wife how to use them too. She just may be the one saving your bacon after you roll your truck/ flip your quad/ put a round through your leg. https://www.rescue-essentials.com/combat-application-tourniquet-c-a-t-tactical-black-gen-7/ https://www.rescue-essentials.com/hunter-safety-kit/ https://www.rescue-essentials.com/the-nick-fixer/ Hunter Safety Contents: 1 QuikClot EMS Hemostatic Gauze (3" x 48") 1 Israeli Emergency Pressure Dressing (4") 1 Compressed Gauze (4.5" x 4.1yds) 3 Gauze Sponge, Sterile (4" x 4") 1 Pair Nitrile Gloves (Black) 1 Petrolatum Gauze Dressing 1 Duct Tape (2" x 36") 1 Immediate Action Card 5 Wound Closure Strip Nick Fixer Contents:1 Ultra Lite 2.0 Silcoat Bag10 Adhesive Bandages (1" x 3")3 Plastic Oval Bandages (2" x 4")2 Fingertip Adhesive Bandages4 Gauze Pads, Sterile(2" x 2", 2 /pack)3 Flexible Knuckle Bandages5 Medium Butterfly Wound Closure Strips1 Conforming Gauze, Non-sterile (2" x 5yds) 1 Trauma Pad, Sterile (5" x 9")2 Non-adherent Pads (2" x 3")2 Moleskin Pads (2 " x 3")1 Tape Roll (0.5" x 5yds)1 Cohesive Wrap (1" X 5 yds) 2 Triple Antibiotic Unit Doses2 BurnX Burn Gel Foil Packs1 Tincture of Benzoin Ampule2 Iodine Prep Pads3 BZK Antiseptic Wipes1 Antimicrobial Hand Wipe1 IvyX Cleanser Towelette2 Sting Relief Pads2 Acetaminophen (NSAID) - 325 mg Unit Doses (2 caplets /pack)2 Calcium Carbonate (Antacid) Unit Doses (2 tablets per /pack)2 Ibuprofen - 200 mg Tablets (2 per /pack)2 Diamode Anti-Diarrheal2 Safety Pins1 Mini EMT Shears1 Mini tweezers kit2 Nitrile Gloves Large1 Backcountry First Aid Book
  19. I've run several sets of KOs over the years and I'm on my first trial with AT2s now. So far, I've encountered no appreciable difference between the two in street comfort or light-offroad performance (mostly sand and coarse rock desert trails). They both sling gravel equally bad. Can't say yet if they will match the KOs in tread life, but overall I'm very pleased so far. The difference in price can't be overlooked. The AT2s have a lower list price than KO2s and you can have Amazon deliver them to your door for free with Prime membership. Plus, GT usually has some kind of rebate program running. I think I got a $60 rebate on a full set. A few weeks back I saw an ad offering $100 cash back. It's worth looking around.
  20. Looks like the bed boxes came out pretty nice! How is your topper secured to yhe bed? I don't see any bed rail clamps in your pics..?
  21. For the parts that we share with the Cherokeesyou can hit up any of the sites listed previously. There are only a handful of companies still making lift kits, bumpers, and armor upgrades specifically for the Comanche, to name a few: JCR Offroad Nates 4x4 Hell Creek Rusty's Offroad Zone BDS
  22. Same tag in mine. Creation Windows made windows for lots of RVs, busses, and camper shells. The shell itself was likely manufactured by someone else. Got any details on that light bar? Bought or made?
  23. Terrible news. Did they get the wildernest too? Keep an eye on clist in case they dumped it.
  24. That's called a Bronco...
