  • Replies 279
Well about 2 hours later and I am no where near to getting the old donut off :brickwall:.  I did manage to get the bolts loose, that was fairly easy.  And that allowed me to move the pipe enough to get some access to the donut.  I thought I was on a roll and could knock the old gasket off, put a new one on and just maybe fix something.  But I had no idea the old donut gasket would be made of of granite, or something about that hard!  It had no interest at all in coming off.  Decided the only chance I had was to remove the pipe to get it out of the way and give me as much room as possible to work, but I could not get the nuts loose just before the cat.  So I guess I'll take it to the muffler shop this week and get them to do it.  Probably have them straight pipe it to the muffler while they have it torn down that way if the cat is damaged and contributing to my issue, that will be gone also.  The project continues...
Good on ya for pressing onward. A lot of folks don't have the patience to go through it all, ask for help/ advice when needed and would have given up.
I hear ya and thanks!  I've had this thing for too many years to give up!
Got my new test case spark plug wires in the mail ($6 ebay) and put them on.  I wanted to test the theory that different wires would not arc and it was worth $6 for that experiment.  These plug are all the correct length (11" x4 and 13.5" x2) according to figure 8-5300 in the parts cat.  All wires in place, no arcs I can see in the daylight and none heard.  So my $6 set of wires may be all I need.  They are all I need for now anyway.  I'm taking it down to the muffler shop at close of business today so they can put it on the lift and let if cool off overnight and install the donut in the morning, and probably eliminate the cat but not 100% convinced of that yet.
Do it. You might even come out ahead on it. Some cats are expensive.
Wellll, I talked to him about that and the answer was he can't do it, it's against federal law:(.  So for the moment at least the cat stays.  He did say he would do some kind of check by poking a hole in the pipe before and after the cat but I didn't really catch what that was going to do.  The ride down to the shop was very noisy since I didn't bother to reattach the pipe at the donut since they were going to take it right apart anyway, the shop is only a couple miles away.  Sounded like I was ready for the drag strip!
Got back from the shop with the new donut.  First stall was before I left the shop :(.  That seems to be the most noticeable issue with the engine right now.  If I can keep it from stalling right at initial throttle, it runs.
The tech used a tube in the ear to check for leaks at the new gasket and he was satisfied it was not leaking.  It does sound better, a sign that perhaps the leak seen before at the donut is gone.  I will repeat the air-vac bubble test later when it cools down.
I did tell the mechanic about the other small bashful bubble leak I had seen off and on, his opinion was that if it was that small it should not cause any problem.  However if I can find it my plan is to try to plug it with JB Weld.  If it is really a pin hole and I can scrape it down to clean metal, JB weld should at least provide a temporary fix long enough to tell if it makes any difference.
He put a small hole in the pipe near the cat and fished a stiff wire through to check for possible flow blockage.  He said it seemed to him it was already vacant at this point and is essentially a straight pipe.  The guy's a 30 year mechanic at a muffler shop, seems like he would know.
I currently have the battery disconnected to do another ECU reset just in case it's off at the moment because it has not learned yet that the donut leak has been repaired.  A Hail Mary I know, but easy to do.
I'm beginning to wonder if there isn't a mechanical problem. Like maybe the hard acceleration broke a rocker arm, stuck a lifter, popped a head gasket.   These are all just possibilities that haven't seemed to have been discussed.  At this point I think your on a goose chase with any kind of air leaks. Seems as though between you and the shops the air flow situation seems normal enough to run well. That's why I'm leaning towards something mechanical that may have been weak already and that accel was enough stress. :dunno:
Might be a good idea to pull the plugs and see what they look like. Maybe check compression while you there.
See pics on 5/26 and 5/27 (page 5 of this discussion) for what the plugs looked like back then.  The consensus was running rich.  I cleaned them all and put them back in.  Checked again on June 15 (page 9) after a lot of the work has been done and the couple I pulled that day (to allow me to do the index check) looked clean as far as I can tell, but you can tell me if you think differently?  I don't know that I have the tool for checking compression but I can probably find one somewhere.
It is idling pretty smooth now and other than the tendency to stall at maybe a 3%-5% throttle, the rest of the time engine seems to be running pretty well, would these other things you mentioned be an issue at minimal throttle but not be noticeable at idle and throttle above maybe 5%?
without reading over the last 10 pages have you cleaned the throttle body out?does it run and start fine, just stalls out at low speed?
It does start fine and idles fine when I start it.  It might cycle up/down at idle a tiny bit but it is not much.  It's just when I advance the throttle just a smidge, it wants to stall, that's my guess at maybe a 3%-5% throttle.  Once past that spot it seems to be running pretty well again, until I approach that same spot on decel, and when it gets down there it again wants to stall in that same small window, but if it get past that to 0 throttle without stalling, it goes back to idle without stalling.  It's really that 3-5% spot right now that is problematic.  I'll hook up the REM and see if I can identify an RPM range that is a problem and report back.
I cleaned the TB and the IAC thoroughly maybe around 18 months ago, it was stalling when I came to idle at a stop sign or light.  With this new issue I have inspected both to see if they were dirty again, but both are clean.  In fact cleaning these is what fixed it at that time.
Back 18 months ago when I was battling a stall, and before I cleaned the TB and IAC, I installed a new TPS because I had one.  Nothing changed but I left the new one in.  I kept the old one, I might put it back in just to see what happens.  (I have adjusted TPS to 17% at idle based on REM reading).
I did get 1 single small backfire earlier today as I took the throttle up and dropped it maybe a dozen times listening to hear anything useful.
I went with video instead.
This 43s video demonstrates the "want to stall" state a few times, the most noticeable instance near the end.
https://drive.google.com/file/d/1FJgFQBm6sbe5DL0OHUJR9BRpVZYLkjcQ/view?usp=drive_link
As a reminder, this video is the original before any of the work has been done, or at least before most of it had been done,
https://drive.google.com/file/d/1y7lS4y-ZxsylCh9y-odN4-UIrnIeS3lh/view?usp=sharing
i would reinstall my old tps and try that.you could possibly have a sticking or failing iac.when i worked for jeep back in the 90s/earlys 2000s we had an iac exerciser that you hooked to the iac and you could manually increase or decrease the iac to make sure it worked.
Before pulling the new TPS I monitored it with the REM as I very gradually increased the throttle, and it seems to be working perfectly.  See the video starting at about 11s, I increased from 0 to 100% throttle as consistently as I could, and I don't see how it could be working any better, as long as a linear response it expected.
https://drive.google.com/file/d/1eOZWdCA8HX7o_pE6bi6GLOq3v5kk8PqL/view?usp=sharing
I think I'll take a look around the web to see how to test my IAC.
The REM has an IAC readout.
Quote from the REM readout summary.
IAC = Idle Air Control Valve Turns (4.0L)
On 4.0Ls, idle speed is controlled by an IAC stepper which provides extra air to the throttle body.
This is an REM only reading that shows the estimated number of IAC rotations open or closed, with the count starting at 128. The IAC is a stepper motor, which requires the ECU to send individual pulses to rotate. Each pulse is indicated by an open or closed arrow, even if the counter has hit a limit.
Note: The ECU does not have position feedback of the IAC so it does not know if the valve is stuck, fully opened, or closed. The ECU will still continue to send pulses to try and correct the idle speed, which could cause the count to eventually hit a limit.
Note: The datastream will tell us if the IAC is currently being commanded open or closed, but not exactly how many pulses were sent so this number is only an estimate. The ECU can send multiple step pulses much faster then the datastream updates, and they will be missed by this count.
– (< 128) The IAC is being commanded closed more often
– (> 128) The IAC is being commanded open more often
– If the number continues to rise or fall at idle without stopping, the IAC is either at fault or their is an air/fuel imbalance that is preventing the IAC from fully controlling idle speed.
I don't see this happening much.  At idle with AC off it I see 120-122 and it isn't moving constantly.  With AC on it bumps up to 123-125, but in both cases it stays within a couple and is not jumping around.  This is probably not what is meant by continues to rise of fall.
I went back to the EGR delete config because I had notice back around May 21 that the EGR plunger moves sometimes at accel, and sometimes it doesn't.  And I also noted at that time, when the plunger does not move, the stalling at 3%-5% throttle didn't happen, OR, it seemed to happened way less.  Now that I have possibly corrected some issues, I decided to go back to this again and with minimal testing, I am not getting any attempted stall at 3%-5% throttle.    The HAS to be a clue of some kind, ether the fact that the EGR only moves sometimes, or the relationship between it moving or not, and it stalling or not or both.  So, I think I'll leave it like this for the moment and see how long it will continue to not stall.  Also worth adding as a reminder (and for the folks that understandably don't want to go back and study the entirety of this very long diagnostic thread:smile:), shop #1 told me the EGR solenoid was bad and it has now been replaced.
Why would the EGR move sometimes rather that always at initial throttle movement?  It was previously noted here that the EGR "operates at part-throttle conditions", that sounds to me like it should be moving every time I hit the throttle not just sometimes.  Of course if it did, I would stall almost everytime and that doesn't make things any better, but the question still seems valid.
If you did the EGR delete didn’t you remove the EGR valve from the intake manifold and cap that hole in the intake?
Sorry, I used the incorrect wording.  I didn't "delete" the EGR, I "disabled" the EGR by capping off the control hose as noted in the pic.
Since doing that I have driven around the area maybe 5 miles or so in basic traffic, no stalling, no sputtering or hesitation.  This is only day 1 of this EGR Disable experiment, so not drawing any conclusions on my end, just noting how the first 5 miles went.
Probably put on another 15 miles today across a few smaller errand runs.  No stall, no hesitation, idle not perfect but close.  All local street driving so mostly 40-45 MPH with lots of starts and stops at traffic lights.  EGR still disabled.  I don't like this fix, it wasn't necessary to have the EGR disabled before so something is not quite right, but after close to 3 months of effort to get a 100% fix, I may be forced to accept this repair since it seems to be a working solution (knock-on-wood) with only a small band-aid.  @Gojira94, you might be getting you loaner back before too much longer!
Before that happens, at idle, can you post up INJ PW and fuel trim values, both ST & LT. Thanks
56 minutes ago, Ωhm said:
Before that happens can you post up INJ PW and fuel trim values, both ST & LT. Thanks
For sure!  I'll get out there in the morning before the Texas heat kicks it!
Absolutely no hurry whatsoever. Let’s get you all the information possible and answer all questions first :L:
OK here's that data!  Some of the number do move around which seems appropriate, so best I can do it try to capture the range.
First, back on June 8 those reading were:
6.9ms, ST 135-154, LT Locked in at 128 - These captured at idle.  Things that have been changed since then are:
- clean grounds at the oil dipstick brace mounting bolt
- reset ECU (disconnected battery) a few times
- executed ECU relearn procedure
- drove 15-20 miles with EGR disabled
- cleaned all the injector harness connectors and injector electrical contacts
- replaced low resistance arc-ing spark plug wires with OEM resistance wires that are not arc-ing
  (it was not a goal to get higher resistance wires, just a goal to confirm different wires would not arc)
- checked distributor indexing
- replaced crumbling/leaking exhaust manifold to pipe "donut" gasket.
- verified TPS linear output throughout throttle (with REM readout)
- re-cleaned IAC although it did not look dirty.
Today, with EGR control hose still capped of, so, no EGR activation:
At Idle, 7.3ms, ST 128, LT 130 (This was right after first start up of the day so engine cool)
At Idle, 5.4ms-6.3ms, ST 120-145, LT 130 (This was after idling for 3-4 minutes)
At 3%-5% Throttle, all of these stayed essentially the same.
Today again, but with EGR control hose reconnected and EGR activation
At Idle all the numbers essentially the same (no difference in how the engine sounds)
At 3%-5% Throttle and with RPMs dropped due to EGR activation:
  PW stayed essentially the same and LT remained 130
  ST dropped with RPM drop.  I did not let it stall only let RPMs fall noticeably, ST was as low as upper 90s
My STMD (Shade Tree Mechanic Degree) doesn't give me the knowledge to know if any of that says anything useful.  But I have to wonder, if the ST went up instead of down as I hit 3%-5% throttle and the RPMs began to fall, would that be good or bad?  I also have to wonder why the PW didn't move right along with the ST numbers when the EGR caused the RPMs to drop, seems l like the ECU, if it understood the RPMs were falling, might adjust that too?  I have just enough knowledge to be dangerous, but not enough to know what to do with said knowledge :dry:
