On 8/9/2021 at 10:22 PM, MiNi Beast said:
Very nice. Doors look great. Loving them seats still. :drool:
Hard to get pics when you're driving them back roads. :shaking:
Same here, actually think they're really comfortable too. Looking forward to driving it!
On 8/10/2021 at 11:56 AM, 500 MJ said:
Love the build thread. Thanks for sharing and keep up the excellent work and craftsmanship!
Thanks! Will do
On 8/12/2021 at 5:52 PM, fiatslug87 said:
What plane is that, KC-10?
BTW, Great build!
It's a Navy C-40A Clipper. Thanks!
Thanks! Will do
Military version of the B-737 used by most airlines.:))
More sanding and buffing:
063AD145-E19E-4AC5-9924-E34FC1FCFFAD_1_105_c.jpeg.6ebe3557b516044066d08148562f6d24.jpeg
3C31833E-1E13-4A6A-BACC-029A1B78F8B8_1_105_c.jpeg.badf34c1bf2c1221ce702c1d10c215e6.jpeg
3986D03D-CF85-469C-A26B-0326FBA2416A_1_105_c.jpeg.4122428f71fbe7bf692b0aedc9ea2fd1.jpeg
The flares were sanded and buffed:
59608F5A-968D-494A-B0F3-BB6398C050AE_1_105_c.jpeg.ba5329a527ad59e4865cfa23b455570e.jpeg
Next I installed some vinyl from jeepsticker.com. came out great!
3BDA8829-71B4-4805-B4DE-E0A9D7D733A0_1_105_c.jpeg.fbf72766a83b4b0e74fa5d0cb01d14c0.jpeg
0C48CD4A-87E4-4F09-AB6B-5A884175D010_1_105_c.jpeg.ab3ccdd7324f4d510d6f6af3f87fcc8b.jpeg
D88640D7-CCFB-47ED-9856-F6DDD165FA9B_1_105_c.jpeg.257698cda905f6b9abacf0967b931d84.jpeg
Closeup of the reverse camera:
51E61CE2-0C67-4BF1-96C7-25430AC36FE6_1_105_c.jpeg.f029a9ae2d5a2abab02bfdc07f97d590.jpeg
Mocked up the JCR spare tire carrier:
B98E334E-28D7-465B-8DFE-DB8C572D27C0_1_105_c.jpeg.6418a6c25be3f402ae4ca5b02f492e6b.jpeg
Then sanded everything for some Raptor Liner:
A5F85B82-7528-4196-A22B-6C70CC891656_1_105_c.jpeg.4606a77825595624b35fb1d62b7c5744.jpeg
91B75D99-B441-4E61-A7FC-51BE87BD22FD_1_105_c.jpeg.662528eac4fd413ce04f5bd88cf45fba.jpeg
Frog tape and a steady hand made for a straight line:
74E79A7C-FB62-469A-BCCE-E3EAC5880CFF_1_105_c.jpeg.1bd1247bf1a7d808b44c902a58ff0e08.jpeg
4BB1BE85-7982-4817-B325-FCCF7A8003E6_1_105_c.jpeg.2aedeedd19527ff3e8a172bb21abf7ec.jpeg
22FAE12E-5E12-45EF-81C7-95738FC8E449_1_105_c.jpeg.4fa4600ffeffdba00c1cf8432671dedf.jpeg
C80F5971-3BA7-490D-94CA-F0961948908C_1_105_c.jpeg.9f2d34aa62f07f5cae27f4f3e1445597.jpeg
FD83E547-11AD-4582-BB79-25A6AE7E7986_1_105_c.jpeg.5f7d97bc2c4fd51649501fe79af4b4b0.jpeg
4AC6E40A-22F3-4AE1-8ED4-EF106F6444C4_1_105_c.jpeg.0504a9bbbb8a223fe78cb4be90a57b93.jpeg
18554ADE-2EC7-4276-8EF8-253684ADDF8A_1_105_c.jpeg.d01b3aea2c85235bfe54a9b2f35f469c.jpeg
7E0E5DCB-A6AB-47E6-AB8D-C736876D3A64_1_105_c.jpeg.ca3a55b19d717996d5cae9f8bfd18d91.jpeg
B1C45820-11F0-4DBC-84F7-F89A043BC45D_1_105_c.jpeg.d85df51dcb4be6283346a9e7430b753c.jpeg
EC319A4E-C74B-4B3E-8467-340E8DF0D6D0_1_105_c.jpeg.3ff30190c95f596abdceb3b300c75f4e.jpeg
Next I scuffed and cleared the original taillights and built a harness complete with new Crown sockets and superbrightleds.com LEDs:
92BCA588-157A-437C-AD98-EC89DD0AA152_1_105_c.jpeg.c79714f9fa8d11bfeaacf42af286df8b.jpeg
73D52E7D-B121-4272-8BE2-49F82B468D24_1_201_a.jpeg.1065d299030bfe41054ba058339d6824.jpeg
4298064F-C3E5-4163-BA6C-D2E939BFABEB_1_105_c.jpeg.265786f15ecbca1ac31385839fbad0a2.jpeg
FD67EE83-72CD-4AEF-AB21-B10F9DF15DF8_1_105_c.jpeg.627ad1f3a1db71c081c4a0980524dea7.jpeg
The rear axle is delayed until November now... :(
A3E8DD80-14F2-4F39-BA78-CE199E48E383_1_105_c.jpeg.ee5e3db640c95f8f980000e972bed0a7.jpeg
With that depressing delay I decided to finally install my CG Precision downpipe and H&R springs onto the Supra. While I wait I'll button up the fuel system and fab and exhaust. Maybe start the LS for the first time? we'll see.
B3E4C2CC-516C-4004-956D-45428A1E5B1C_1_105_c.jpeg.3eab138f1215dc84914fefadba3979e8.jpeg
This is an amazing total rebuild! Absolutely amazing (kind of Jealous). Cannot wait to get back out to Montrose/Olathe and back to hunting in the Uncompahgre. As well as my own house and garage to work out of.
This is seriously an incredible build! I am working on a similar Comanche build at the moment, but not NEARLY as extreme as your build. Massive compliments to your attention to detail and fabrication work.
@USN_JeepMJI am curious if you have any more details on the way you modified the Corbeau seat bracket to lower the height of the seat?  I'm also 6'4 and will be getting Corbeau seats in my Comanche, so I plan on cutting them down a bit, however since I don't have them "in hand" yet I'm wondering how much you trimmed off of each "leg".
Thanks so much!
Thanks so much!
i also cut my corbeau brackets down.  I'm 6'1" and my head was pretty close to the ceiling and would hit the top of the door frame with any sort of side movement.  i took about 3" out of mine.  be aware that the seats may then hit the trans tunnel which will require some "massaging"
On 10/2/2021 at 2:11 PM, Pete M said:
love it!  :drool:
especially that backup camera location!
Thanks!
can't wait to get back out there... hopefully this fall sometime. Clearly I won't be going in the Comanche until probably spring now. Oh well!
On 10/14/2021 at 1:38 PM, WesD said:
Most impressive build I've seen on any website yet.
Excellent work.
Safe flying.
Thank you!
Thanks so much!
I only cut down the rear legs as that rotated the seat bottom back giving plenty of clearance for me to sit with the added benefit of giving more thigh support as opposed to the very flat position the brackets originally gave. I cut the rear legs and overlapped them about 1.5" along with trimming the support pieces and bending before welding everything back together. I also added a hard mount for my aftermarket seat belt ends. You can see what I did better in this picture:
912C7EA8-AE8E-4C88-B14F-B273E8628DCB_1_105_c.jpeg.065ae9e286d10e36b252400c5c3aba38.jpeg
I just ordered everything I need for the fuel system! While waiting for the rear axle to show up I randomly just thew the set of wheels and tires I originally purchased 2 years ago when I had a diesel JL on order (I ended up getting the JT instead after diesel production was delayed). I had planned on going with black wheels on this build but this setup looks so good! I think I'm convinced! Plus there's plenty of clearance for JK Wilwood brakes.
E7E9F9A4-4AC6-4E97-BB54-40A2C41DCCB3_1_105_c.jpeg.32d786a210dcc474c5fd485c1ad20af7.jpeg
Ok, it's settled. I'll go with those wheels! At least until I get a more aggressive tire and beadlocks.
On 11/1/2021 at 1:50 PM, Chargum85 said:
Been following this here and on IG.  Amazing build.  Looks amazing.  What'd you go with for rear axle?
Thanks! I've had a Currie D60 (in JK width) on order since June... The Eaton E-Locker was supposed to be in last week so we'll see if they get it to me sometime this month. Kind of getting sick of waiting.
  • 3 months later...
Another delay in the Comanche project... I spent a month flying around Europe and the Middle East. Somewhere over the Red Sea:
5D616BFB-B6C2-4785-9742-6E1C36D0FEC3_1_105_c.jpeg.6b035951572c009dae52585e9e5b307d.jpeg
891D5CB3-C897-41F9-A0E6-2F8F1D7CD541_1_105_c.jpeg.36fac9dde2d738d17e9848230154aa9e.jpeg
After I got back I got rid of the Gladiator in favor of something that can tow (I ordered a Ram 2500 Megacab Limited w/ 6.7L). In the meantime I needed a daily so I built a cheap WK:
E599BF85-ECDF-4951-916D-34996A23598E_1_105_c.jpeg.ac6c5728d4292a8ecc5684144a46c813.jpeg
And finally it was back to work on the MJ. New MJ tank:
12FDF428-F7E8-46F9-BDA8-C9EBF242486D_1_105_c.jpeg.0d08343bf750b50cfcc371ff417b7b0e.jpeg
For the LS I went with:
Walbro F20000169BX (255 lph)
Walbro 400-1016 (installation kit)
Rockauto: US Motor Works 12-104-5 (strainer)
mtscompany.com JPSU-6 (new sending unit assembly)
Racetronix BCWS-001 4-wire pass-through
Lastly to get the 97+ gauge cluster to display correctly… I bought a cheap TJ pump assembly to grab the gauge sending unit off of.
5D976820-D201-4D46-A8F4-08F3BD880DE1_1_105_c.jpeg.b15a6e304c548775417d03ba8281acb3.jpeg
A152138F-0071-453D-B61E-25AF36A2F066_1_105_c.jpeg.021af9b5a4650dc267a7aa92708715f6.jpeg
B4D1DA12-8F36-415E-88EC-3EA91B687050_1_105_c.jpeg.26e947ccd3ea77669d3fd18613647f9e.jpeg
E6AFCAE1-B681-46B4-BC0D-414E5C914B74_1_105_c.jpeg.31ced437458b77df4dc8c4f17a583295.jpeg
89CDCB5D-C370-4E35-B212-19B447BF4199_1_105_c.jpeg.b710c1045bd53f627ae1ca499a9d49ad.jpeg
New XJ hoses cut to fit and a new cap:
87867E3D-54AB-49D6-ABB6-37699737F5BE_1_105_c.jpeg.327c18f10438855e11113b592965df91.jpeg
Fuel line routed to the engine:
F33F0438-A975-468E-A209-7F112FCEAC58_1_105_c.jpeg.024da3166b6108bd25376a1ef082deac.jpeg
I'm running a Corvette regulator with a return line under the Jeep for a 1 hose setup. I'll have to get a picture eventually.
My new Welder showed up at some point. Its HUGE!
2D668504-1AAE-4CAD-B32A-ECC3D31F50ED_1_105_c.jpeg.743942376bdf7442b67d5710895ac658.jpeg
That brings us to this week. The Currie D60 finally showed up! I had to downgrade to 35 spline shafts (the 40 spline Eaton E-locker has been on backorder since June... with no ETA I finally gave up) and Aburn E-locker:
F0B4261E-68E3-4194-9EC0-628117C4EF2B_1_105_c.jpeg.27a956210c889d2e77ae2d8789d016b5.jpeg
B5960336-46EB-4D90-8879-BF603536935F_1_105_c.jpeg.0b84853fd97f301e7198b26a44df2685.jpeg
Test fit with some Ruffstuff Specialties u-bolt eliminator perches:
F8DCB276-F7ED-453E-92BC-D67B02BC19CF_1_105_c.jpeg.7318e7bd1215e9d3b0c9725c60f5af0c.jpeg
Time to test out the new welder!
B9B33352-9DC0-42B0-BE2E-60BB784B7CF7_1_105_c.jpeg.33e1d3c61d1dbb64bc85e6eb6ad5b553.jpeg
378318A1-F7E1-4C21-8E75-4DB42C570CA1_1_105_c.jpeg.949cb1ff29b2f7c88905c989d0ee1d7b.jpeg
562C8CF6-893C-478F-A007-4B952965B28E_1_105_c.jpeg.f41edb0349c883399df62e9c1c7b1846.jpeg
Thats where I'm at today. About to go pick up my new truck then get to work burning everything in.
