How many miles on your engine?
362 members have voted
  1. 1. How many miles on your factory MJ engine?
    • 0-50k
      15
    • 50-100k
      40
    • 100-150k
      84
    • 150-200k
      95
    • 200-250k
      64
    • 250-300k
      42
    • 300k+
      33
    • who knows. I swapped it out.
      9
all good. ive been swapping parts on mine for over 10 years now and it sat for a few years. that will never happen again. i believe neglect to be abuse. my poor baby. :sad: :comanche: on the road again.
Posted (edited)
I got 224,000 on mine. Owned it from 154,000. No issues with motor or ba-10 trans. Most reliable truck i've owned so far.
Edited by jeepsouth
On 4/14/2019 at 12:29 PM, gogmorgo said:
Well 498,400km on the first 4.0 in my first MJ before I pulled it puts me in the 300+ club, by just. I also added one for the ~270,000km that are now on the engine that replaced it (240,000 of which were accumulated by the XJ it came out of). I've also got 172,000km on the other MJ's original 2.5 when it came out, but it's death was due to neglect from the previous owner. Sometimes when your crusty old radiator is leaking, the fact it quit leaking on you doesn't have much to do with the stop-leak you were pouring in the top as quickly as the coolant was coming out, and more to do with there only being a finite amount of coolant in the system...
My 87 MJ - 154K, My 90 XJ 252K, My 98 XJ 335K
  • 4 weeks later...
  • 7 months later...
175k on the 1986 Jeep Skamanche 4x4 with original [GM 2.8l v6 LR2] <- POS ENGINE [IMO]
I hate the 2.8l v6 or it's the Varajet II Carburetor. Whatever power you thought you had is now gone at the ax5... It's perfect if you wanna do 35 mph on the main road.
My 95 XJ had 390k on the engine before I bent 4 rods and flattened the cam and lifters. :roflmao:Currently sad that I have to rebuild the original motor. But it never blew the head gasket. So I am pretty impressed with the 4.0l H.O. engine. Guess you shouldn't pull 3/4 ton & 1 ton trucks.:thumbsup: Now it has 390k on the Body with a built 4.6L L6/Ax15/Np231 SYE kit... and other add on's....
I have 298000 on the original 4.0 engine.  My father bought it new in 88. I drove him to the dealer to pick it up.  Valve cover and pan have never been off the motor. I know it needs either a rebuild or a replacement, as I am running straight 50 weight and it still takes a few seconds for the oil pressure to come up in the morning. It has had a long hard life pulling trailers with very heavy vintage Chevys on them.
Question, do I rebuild it with new bearings and rings, or do I just buy a rebuilt 4.0?
drainback valve leaking?
My 1986 Comanche got a little over 90K out of the original 2.8l Chevy V6. (Threw a rod.) My replacement 3.4l has a little more than 75K on it.  It is running strong, but it is time to ditch the crummy carburetor!
On 4/14/2019 at 2:33 PM, Pete M said:
partly playing with the poll feature, partly looking for a graph showing how the stock engines are doing. :L:
multiple choice answering is allowed for guys owning more than one.  If your trucks both have 175k, then I don't know how to accommodate that  :dunno:
171k on the stock 4.0.  After sitting for 11 years, I pulled the engine and head to replace a dead lifter that just wouldn't pump up as well as all of the expansion plugs.
Purchased mine just recently, has 252k on the original engine.  First owner put 237k on it in 16 years.  Then it became a parts runner for the original selling Jeep dealer for 15 years getting few miles but probably beat on.
Now I beat on it. 🙂
177k original miles and growing strong. Bought on Halloween on 2020 from my grandfather because his vision is getting terrible and wanted it to go to a good home where he knew it'd be taken care of. When he does see it pull in the driveway. He always smiles. Been owned by him since '87
  • 4 weeks later...
300000. Just replaced the rear main seal and pan gasket,
runs perfect, used as a everyday work truck.
But I’m retired and just work on a property I’m going to be building a new home.
