bruce9
Everything posted by bruce9
  1. Ok ive got two MJs that have bad lines to the fuel rail everywhere I search, they all say discontinued. any idea what to do other than just run a new hose with the “correct” clamps?
  2. bruce9
    Tool Talk
    Ive got one and it has held up to my normal use/abuse for several years. I just don't over torque it
  3. bruce9
    Whats in your cab
    Like a good Scout, always be prepared ('specially when you live 30 minutes from the border)
  4. bruce9
    Whats in your cab
    1st aid, Fire ext. Blanket, Basic tools, Air Comp., Water, Flashlight, Fire starter, .45ACP
  5. Being the researcher I believe that I am, I followed the link above to MTS, Spoke to Steve and YES, they offer a complete assembly. They were extremely helpful. **NEW** 1987-1990 Jeep® Comanche MJ 18 & 23.5 gallon "side mounted" gas tank sending unit with fuel injected engines (w/ pump) for the 4.0L engine. Includes new lock ring and O-ring. Replaces # Top Plate View: pic 2 Ohm range: Full 80-90, Empty 0-10. Available in 3-5 weeks (Mine is on order) $151.95 plus shipping
  6. well, I got screwed. I purchased it from Advanced Auto. received it and just went to install it and found the sending unit and strainer are located on the wrong side. plus the hanger has it sitting a bit shallow so it doesn't locate at all. I called Carter and spoke with them and they quit building the assemblies for these. You can get the pump (higher pressure and GPH than Cherokee?) but no complete assembly. So I need to rebuild the existing assembly. Sorry for the misinformation. And my MJ is a '87 4.0 2wd
  7. I just purchased a comlete new assembly
  8. bruce9
    1JTMW6413HT154930
    OK, chasing back, is this the description for my MJ? I get confused sometimes with the payout on this site
  9. I am hoping everything checks out once I get it started. then for sure , regular maintenance.
  10. bruce9
    1JTMW6413HT154930
    Wow!!! that is awesome. its good to have folks at a dealership. you guys Rock!
  11. bruce9
    1JTMW6413HT154930
    and I am located in SO Ea Arizona my 1st MJ
  12. bruce9
    1JTMW6413HT154930
    1987 Comanche "Base" I think 1JTMW6413HT154930 4.0 Manual Bench Seat Interior Mouse infested exterior White w/ side emblems not running but I'm working on it want to convert to 4wd (have a donor XJ) if you can let me know a little more based on the VIN, I would be most appreciative
  13. My 87 MJ - 154K, My 90 XJ 252K, My 98 XJ 335K
  14. MACS 1987-1990 Jeep Cherokee Aluminum Coolant Tank $139.99 All aluminum jeep coolant tank for 1987-1990 Jeep Cherokee, Tank comes with new pressure cap OEM Aftermarket:1987, 1988, 1989, 1990, JST001
