hbhp5
Everything posted by hbhp5
  1. Will do. Have checked for vacuum leaks, none I can locate.
  2. 91 Comanche 4.0. 5 spd stick. Replaced head gasket, radiator, all water hoses. Just upgraded intake, added riser. New PS steer pump. New plugs, throttle control, air intake control, fuel pres reg, exhaust sensor, breather. Now: Idling at 1200, starts hard, with warm restart stumbles twice within 30 seconds. Then runs perfect. Has me puzzled.
  3. 91 4.0 Recently replaced head gasket. New coil, plugs. Upgrade intake, riser, tuned header. Air control valve, Throttle control, fuel pressure regulator.. Now idles at 1200, hard start, stumbles after warm start. Any ideas~?
  4. Will do, thank you so much. Will let you know when we're back on the road.. JohnA
  5. Soooo, finally got the bracket, pump, etc. Hooked up, but, old belt is too long. Bought a belt for 98, it's too short. Any ideas~? Part numbers~? Thank you, JohnA
  6. Soooo, finally got the bracket, pump, etc. Hooked up, but, old belt is too long. Bought a belt for 98, it's too short. Any ideas~? Part numbers~? Thank you, JohnA
  7. I have a 91 Comanche 4.0. Just installed a high output intake plenum. Now power steering pump mounting bracket doesn't fit. Is there a different bracket for this set-up~?
  8. Cleaned & Dried Connector, Re-Assembled, Good as NEW~! Not bad for 350k miles. Replies MUCH appreciated. John
  9. hbhp5
    Prayers needed
    Prayers to our Creator.
  10. 91 4.0, Was in town, stopped at store, came out, started, and seemingly out of NO where would not accelerate. Limped home (8 miles) with several times had to pull off road, NO power. Fuel pressure test showed 15#, replaced pump, now 41#, but, still no power. Will idle rough, try to accelerate, stumbles and blowback etc. 2 yrs ago similar problem when cold was computer connection, cleaned terminals and used dielectric grease on re-connection, NO go. Timing chain, distributor assy, ALL sensors replaced 2 yrs ago. ANY Ideas world be appreciated. JohnA
