what did you do to your MJ today?
JeepcoMJ
In stalled some new Bilstein 5150 Series shocks on the rear!! Awesome shocks, 10" Long and have a separate piggy back reservoir. I can actually feel the difference in the ride and driveability, I run no sway bars front or rear, so it is pretty amazing to be able to go around a corner and not feel like I am going to roll over!! :yes:
New track bar and clutch master cylinder. Took her on the highway for the first time. She did great and was a volunteer vehicle for the Step Out and Walk for Diabetes this morning.
You can see the Purple People eater sticking out and so small right now next to all the other Jeeps...
The Boss's MJ blew the heater valve the other day, and the upper rad hose looked questionable, so I replaced bloth. Was suprised at how long it took to get the air bubble out of the system. Once it was gone though it was all good. He also complained about a death wobble incident, so I balanced and rotated the tires, and threw on a Rancho RS5000 steering stabilizer. The old one was pretty well shot. All the steering parts and track bar seem fine, so we will see what happens. I'm throwing these fixes at it because he don't want to spend any money on it unless he has to. So it is turing into a fix it one piece at a time as he complains about it job.
I worked on the 88. that's right, I actually did something productive to one of my MJs. :banana: pulled the spooled 3rd member out. Hopefully tonight I'll get a chance to put the open diff in. :yes:
re-installed the tailpipe, (a little longer this time so it won't hit on the shackle again!)
replaced the BLEEDING oil filter adapter o-rings (did yuo know the ford FL1A filters fit!? its HUGE)
and removed some funk off the side of the truck / washed the engine.
next up, heater core.
Okay, control arm job kinda sucks...Hopefully will finish tonight after work...and get my guage cluster in, I got the Tach cut out for the PRNDL strip and sensors in...I'm so ready to start driving it again.
:fs2:
If I EVER find the sonofa that invented the scotch lock, I am going to beat him with a wiring harness.
Those retched devices seem to make stupid people think they can wire stuff. Went to hook up the trailer to the '92, and the lights were dim. Knowing the trailer was good, went straight for the throat on the '92, and found this:
Some idiot decided that was a good way to extend the trailer wires, which were about 10 feet longer than they needed to be. Now its properly done with heat shrink butt connectors.
And the lights actually work now! Imagine that! :fool:
Rob L.
got the new-to-me plow frame setup on the arb bumper, ended up fitting friggen awesome, tomorrow ill slap the pump together and mount it all up---fyi i paid a whopping 100 bucks for the arb(its for a toyota, made my own brackets and youd never know it is for a different truck) and i got the plow blade, frame, push plate, pump, wiring, controller, lights etc etc for a whopping $25. i love massachusetts...
Pics.
I too, have an ARB, MJ variety though, and thought about mounting the factory MJ plow up somehow.
Inspire me. :D
Rob L.
time to look thru brake electric wiring diagram to see why turnsignal didnt blink only while hazard is on. even while depress the brake pedal. the headlight switch will light taillight up so i got drink coffee and start highlight thru the wiring diagram to see the result.
i have pink highlight with me and time to highlight now!
Got all the Control arms and such done last night, not fun but really not that bad on a lift. getting it aligned today and getting my guage cluster installed... I will get to start driving it again next week. Getting married Sunday and evidently am not supposed to spend all day Saturday working on the Jeep... :nuts: :nuts: :nuts:
