beaterheep
beaterheep's Achievements
Comanche Fan (3/11)
so the damn jeep started running like crap 2 days ago. anything over 1/8 of the gas pedal and it popped through the intake stumbled and surged under load. but if i pushed the clutch in it still revs up just fine. replaced the fuel pump, replaced the fuel filter,replaced the cap and rotor, plugs and wires are fine, regulator is dry-- no gas in the vac line so that tells me its still good(?) now it idles fine but pops/surges/stumbles under any kind of load. revving it up it pops and stumbled around 1200rpm and clears up over 3000 rpm. I'm sick of freezing my @$$ off in 2ft of snow trying to get the p.o.s. to run right and i kind of need to be able to drive it, right now the plates from the jeep are on my beat @$$ plow truck so i can get around(rotted fenders, squishy brakes and a 2007 inspection sticker...yeah can't drive it on the road much!!) anyone have any ideas??? help!!
stepside conversion ideas?
beaterheep replied to beaterheep's topic in MJ Tech: Modification and Repairs
i saw the scrambler pickup, like the idea. and the f150 mid 1980s box is light as hell too cause the fenders are fiberglass. thought of using one of those, cutting the wheel openings to the same shape as the manche, and reusing the rear flares off of my bed. oh, and i hate the damn ranger bed everyone keeps posting lol. ive got a set of mid 80 something chevy stepside fenders. just need a box now, theres an old dodge fullsize up the road with an 8ft stepside bed, guy died a few years back, his kid takes care of the place, theyre trying to sell the land for a housing development, i might have to go leave a note saying i want the bed...swap the jeep lettering from my tailgate to that one, narrow it a foot, bob it a foot, perfect... -
my bed needs some help and i want to bob a little off the rear of my truck, ive got 3 options i can think of--- 1: narrow stock comanche bed and graft on 80 something stepside fenders 2: 1980 something fullsize stepside bed narrowed to comanche width 3: mazda/toyota/s10/ranger stepside made to fit leaning towards option 2 because those would be the easiest beds to find. no one made much for a stepside bed when it comes to smaller s10/ranger style trucks, newer beds look too modern. thinking a 1980 something bed and swap on a waggy header panel, paint the whole thing 2 tone, use the "jeep" centersection of my tailgate grafted onto the stepside gate...any ideas or opinions would be appreciated!!! pictures too!!!
whats the hydraulic valve go to?
How to patch heat valve vacuum line?
beaterheep replied to 91coMANche's topic in MJ Tech: Modification and Repairs
cut the line back by the firewall, slap a dab of epoxy or jb weld on the end of the line. done -
Frame Rot...how long can I go
beaterheep replied to robfg67's topic in MJ Tech: Modification and Repairs
my 88 had one really bad spot when i bought it, by the pass front spring hanger, patched it with 3/16' steel, found 2 other spots and patched them too, just plated the last 2' of the rear frame when i built the rear bumper. -
"Old Red" 1988 Comanche Long Bed 2x4 to 4x4
beaterheep replied to Fire4755's topic in Member Projects: Your Comanches
your going to want to throw that d35 away and find an 8.25 out of a cherokee. the 35 sucks. running 33's your chances of blowing it up are high. i broke my stock d35 on the street with little 215/70/15 tires, tires spun a little in the rain, grabbed again and pop no more rearend. ive got an 8.25 from a 94 cherokee and i welded the diff and i havent had any problems yet -
ive got an arb bumper but the vac can is still there. thinking ill ditch the stupid valve on the heater hose under the hood and see what that does. should help a little, then if need be ill unhook the heater door and just move it manually to hot for now lol
so, why the hell does my heat blow decently hot from defrost, but when i put it on heat it blows barely any warmth? truck can run for hours, defrost is warm but not hot, and heat is barely what youd call "room temperature" it friggen sucks!! any ideas?
why not get one of those military trailers, looks like the back off an m715? or use a stepside off an early 80's or late 70's truck and cut it down to size? just trying to think of something different, stepside beds from the 70's and 80's were kind of generic, unlike the guy who put a ranger bed on his manche....
Cargo Light Switch Question
defrost switch might work, youd be better off using a fog light switch of the power/comfort switch from aw4 manches, ive got a bunch of em here but thats a bit of a drive for a switch lol... -
finally wired up the led strobes ive had here for a week. put the tailgate back on, loaded the jeep and the trailer with 85 bucks worth or scrap, next is the trans swap, add 2" front spacers to the coils, new clutch, trim the rear quarters and add to the rear bumper, come spring new rims and 35's. go figure its too damn cold out now...
sams u pull it in worcester, i think its 2 bucks to get in, usually has a nice selection of jeeps
so, ive got an internal slave ax15 from a 95 cherokee, along with the attached 231 t case. it will be replacing the peugot $#!&box and the attached 231 t case. problem is the 95 t case dosnt work, i can get another t case, or is it worth it/easy enough to swap the 95 input shaft into my perfect working 88 t case? also-clutch master/slaves---peugot has a brand new master cyl, can i just splice the line into the ax15 line and use it? ive heard of just using brake line fittings and it works fine, seems like the best solution. clutch--they use the same clutch so as long as my clutch is still good i can reuse it(peugot) and not have to change anything? other then the tcase linkage needing some tweeking(i may just make a custom setup) everything bolts in once i change the pilot bearing correct? I'm doing this swap on my dirt driveway in an unenclosed carport in the friggen winter so i want to make sure ive got everything figured out before i freeze my @$$ off!!
What is this part???
beaterheep replied to ComancheKid45's topic in MJ Tech: Modification and Repairs
spare parts. you don't need that
