Bigbike
Bigbike's Achievements
  1. Bigbike
    Pass Tail light
    As the title states, I need a Pass side tail light for my MJ any one have an extra?
  2. I recently picked up an 88 MJ 4.0, 5spd, SWB for a whooping 300 bones. Now I got it and the dip stick is covered with $#!&, it leaks like a sieve (what 4.0 doesnt), and has a lack of power. Now my buddy just rolled his 98 XJ and offered me the engine and wiring harnesses and $#!& for 300-350, should I go that method and do a 97+ conversion or just throw a newer renix engine in? Is there a write up for the 97+ conversion? How difficult is it to do?
  3. The name is Caleb, I live in Cheshire, CT. I have a fairly built XJ, 35s, 30/44, locked f/r, geared all that stuff. So I picked up this MJ for $330. Its run ok, but needs an exhaust and lots of body work. I put this 97+ front end on because I had it laying around. And the XJ
  4. Long arms arn't terribly hard to build just measure 3 times and cut and weld once. O Calebs with "C's" are better -Caleb
  5. So I'm thinking I could make some cash plowing with my MJ. Any tip? What plows to use? What mounts can I use etc...
  6. Ive got the frame rot too :(. Question It is on the edge of the frame under the pass side frame rail under the doors. Would you suggest a piece of angle iron over or graft a piece in to the rotted section?
  7. What kind of fluid goes in my pukegoat 5 speed? How much fluid
  8. What are you guys getting for fuel economy? Normaly.
  9. Does some one have a write up?
  10. So yeah, pre 95 XJ seats bolt in???
  11. I know its probably been cover 100 times but to do bucket seats would I just have to get seats from an 84-94 XJ??? Perferably 2 door seats. Is there anything else that will bolt in? I also have a 97+ center console that I will be putting in. Any tips on that too?
  12. Yeah I saw it right after I posted. My thoughts and prayers go out to His family and him.
  13. Anyone else?
