tallon2064
    MARYLAND
Contact Methods
  • Yahoo
    ianblackhawk
tallon2064's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. I will have to look but I did have two sets at one time, one good, one passable if I still have them I will take $60.00 for the pair + shipping. Will check in the next few days and check board again to see if you still need. I live in Maryland to give you an idea on shipping cost. I no longer need Comanche items as my motor exploded a few years ago. If you need anything else llet me know and i will look if I have.
  2. I will have to check, but I am fairly sure I have one. I will let you know as soon as I can.
  3. I may be able to help you out with a sending unit, but I need to know what size tank you have and if your truck is a renix or a ho motor.
  4. Didn't even trim the opening for the 4WD lever just cut a hole for the shifter. :hmm: :doh:
  5. The holes to mount the front plate mount are actually on the underside of the front bumper. A front mount from a Cherokee will work they are a dime a dozen here in Maryland at the pick and pulls
  6. Congrats, and remember regardless of what you are doing in the military it should be considered an honor to serve your country. This is coming from a retired :USAflag: US ARMY INFANTRY SOLDIER. :Canadaflag: BE VERY PROUD
  7. The title says it all my motor blew up yesterday, the #6 piston ended up in my driveway, or at least part of it did with parts from the block and connecting rod. Still trying to figure what I am going to do with the Jeep, motor is done. I am trying to figure out how much to spend if anything on fixing it.
  8. Just being curious but to which side the said control arms are mounted too make a difference or doesn't it matter? :dunno:
  9. At least he didn't damage the stock rear bumper that is still on it :banana: :wall: As for the rest consider the source :wall:
  10. The one in the first pic may be for the under hood light. Looks kinda like the wire in mine.
  11. I received mine in 1982, welcome to the club. :bowdown: The % is actually less then the % that pass special forces or seal training. :bowdown: And on a historical note the reason that the first lunar lander was called EAGLE is that all three astronauts on the mission are Eagle Scouts
  12. Did you have to reinforce where you made the cut in the bed for the winch? :dunno: If you said what you did I must have missed it.
  13. All states should have this doctrine, then if someone wants to enter you home they at least know that it might not be worth the risk.
  14. After reading ad it sounds like more of a commercial for the dealership than the vehicle. :dunno:
  15. Have you looked under cherokee lights on e bay and other sights?
