Oizarod115
    Santa Cruz, CA
  • Interests
    jeepin'
Oizarod115's Achievements
MJ Maniac
MJ Maniac (8/11)
  1. I recently 4wd swapped my truck and used the 4x4 shift kit from BoostWerks and it works awesome. don't need any of the stock brackets for it. Saved me a bit of headache there. 60$ to the door! https://www.boostwerksengineering.com/231-HD-Shift-Linkage-Manual-Trans-V20_p_29.html Good luck!
  2. Hey, I found these at quadratec new from Crown. they also sell the pieces individually if you search https://www.quadratec.com/p/crown-automotive/fender-flare-retainer-kit-cherokee-xj-55003232K
  3. I have this set of white wheels below. Off my 87 in Santa Cruz for free.
  4. I think SYE is worth it just because it allows you to lift the pinion up a few inches to set the proper angle getting you extra clearance at the driveshaft/pinion
  5. both of my california trucks have plastic ones, and 87 and 89
  6. For anyone looking for this in the future, I used the Novak universal AX-15 mount, and had "send-cut-send" make me a plate to go from the 4 hole MJ/XJ mount pattern to the 2 hole Novak mount pattern. Ended up costing 125 total. https://www.novak-adapt.com/catalog/rear-mounts/rmax15-rear-mount Spacing on the 4 hole crossmember mount pattern is 8mm bolts at 65mm wide x 55mm front-back, novak mount is 7/16 bolts spaced 5" wide, the drivers side novak bolt will line up just about where the rear drivers 4 hole pattern bolt is.
  7. hey guys, this truck should have factory 4.56 gears, appears to be a 4cyl automatic... I ran a d30 from a 4cyl auto for years on my last build!
  8. Looking for a front driveshaft from a 4.0 manual xj/mj let me know what you have! the right shaft should be about 29.25" when collapsed
  9. dang! just bought one a week ago. GLWS
  10. No, I need the steel plate that bolts to the bottom of the transmission, has studs to put a rubber trans mount, and has the exhaust mount.
  11. This axle came out of my LWB metric ton truck, 133k miles smooth, quiet and trac lok feels tight, brakes worked great, selling complete drum-to-drum with e-brake cables asking 500$+shipping
  12. Hey Crew, I'm looking for an AX15 mounting plate for an MJ/XJ hope someone has one! if you have it and don't want to sell it I could use some measurements off of it!! Thanks, -Nick
  13. Thanks guys, i'll check theirs out.
  14. Hey Folks, Looking for a complete battery tray, including the brackets, bolts, hold-down fasteners, top strap, support strap from radiator core support. Shipped to 95073 Let me know what you've got! Thanks, -Nick
