mm's mj Posted April 26, 2009 Share Posted April 26, 2009 Replaced the starter - pushed it way beyond my first notice of a problem and still got lucky enough to fix it at home instead of having it fail in some parking lot somewhere. Was surprised to see a Mitsubishi label on the old piece. Sometimes I feel more like an archeologist when I work on the truck, just peeling back the layers of years of curious repairs and replacement work. It's never boring. Link to comment Share on other sites More sharing options...
TNT Posted April 26, 2009 Share Posted April 26, 2009 Cut out the top of my raised inner fenders and started reworking them for another inch of space. The cutoff wheel, torch and welder have been my main toys... Let's not forget the BFH thou. :brows: :cheers: Link to comment Share on other sites More sharing options...
dfreeman616 Posted April 26, 2009 Share Posted April 26, 2009 applied my 12" ComancheClub.com decal in the lower left of my rear window, and a Great Lakes 4x4 decal in the right side of the rear window :cheers: Link to comment Share on other sites More sharing options...
mvusse Posted April 27, 2009 Share Posted April 27, 2009 Added 2" lift blocks I had laying around to my XJ. Before: After: I also replaced a bad front axle U joint yesterday and noticed the (1994) shaft itself is quite a bit thicker than my original (1987) MJ axles. Why would they redesign axles make them bigger and I assume stronger, if the weak point is the 5-260x U joints? Inspected the rear brakes as well. Driver side needs a new adjuster, everything else is A-OK. Link to comment Share on other sites More sharing options...
Darren Posted April 27, 2009 Share Posted April 27, 2009 I didn't do anything to my jeep today but I might do something to it tomorrow. go blazers f the rockets Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 27, 2009 Share Posted April 27, 2009 I cut the drivers side firewall out of the 97 XJ and modified it to cover the stock holes in the MJs firewall. It came out looking factory. Now I can run the wiring. Link to comment Share on other sites More sharing options...
TNT Posted April 27, 2009 Share Posted April 27, 2009 I didn't do anything to my jeep today but I might do something to it tomorrow. go blazers f the rockets This was another wasted moment of my life I will never get back. BLAZERS SUCK!!! Link to comment Share on other sites More sharing options...
BPB Posted April 27, 2009 Share Posted April 27, 2009 talked about it at a bar Quit wasting bandwidth and padding your post count with you stupid BS responses.... :thwak: I noticed that your post count has been padded on this page of the thread just as much as mine. :dunno: Oh yeah I just remembered that yesterday I thought about my jeep while making a sandwich Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 27, 2009 Author Share Posted April 27, 2009 talked about it at a bar Quit wasting bandwidth and padding your post count with you stupid BS responses.... :thwak: I noticed that your post count has been padded on this page of the thread just as much as mine. :dunno: Oh yeah I just remembered that yesterday I thought about my jeep while making a sandwich you, and goblazers, need to stop being immature dumbasses. Link to comment Share on other sites More sharing options...
Darren Posted April 27, 2009 Share Posted April 27, 2009 you, and goblazers, need to stop being immature dumbasses. Speaking of dumbasses, I'm leaving in my MJ right now for Bens house to work on my Jeep. Link to comment Share on other sites More sharing options...
pilotblake Posted April 27, 2009 Share Posted April 27, 2009 Just received my comanche club swag in the mail...patiently waiting till quitting time to go home and install my new decals, with a cold beverage in my new CC coozie. Link to comment Share on other sites More sharing options...
smithe1811 Posted April 28, 2009 Share Posted April 28, 2009 I installed a sunroof today, pics will be in my project thread. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted April 28, 2009 Share Posted April 28, 2009 I installed a sunroof today, pics will be in my project thread. THIS IS ONE THING I WOULD LIKE TO DO DOWN THE ROAD.... I'll check out your pics!! CW Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted April 28, 2009 Share Posted April 28, 2009 I pulled the bed, dropped the gas tank and started cleaning up the frame.. LOTSA RUST is an understatement!!! As always.. pics up shortly, in the build thread... :D CW Link to comment Share on other sites More sharing options...
pilotblake Posted April 28, 2009 Share Posted April 28, 2009 CC Swag installed: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 29, 2009 Author Share Posted April 29, 2009 successfully recovered my friend's cherokee...which easily weighs 1000 lbs more than my truck with the exo cage, winch, etc. on it. my tires were bald. also, not so succesfully, attempted to recover a full size 90's bronco, which weighs 5800lbs. the rescue truck was stupid and had bald tires, so he got stuck trying to get to the property we were at (friend's house near his field). go figure, it's a ford. then on the way out, I got stuck...everyone was attempting to get the "rescue vehicle" un-stuck, so I figured I'd rock it out. I did, but it seems like it may have cost me an aw4. so, looks like we may be able to chalk up an aw4 to my long list of blown transmissions :clapping: the trans is draining now, I will be flushing it and putting lucas trans fluid in to see if I can get her to make it a while longer. was real doggy on the way out lol. *shrug* Link to comment Share on other sites More sharing options...
comanche87 Posted April 29, 2009 Share Posted April 29, 2009 i put my truck on the lift at work to make sure the bolts for the front diff were tight. i ended up snapping one of upper bolts that bolt it into the unibody. i was sooo pissed. but at least i had spare ones at maddzz1's house. had to borrow a car to go get it. yay!! I'm bout half way to having 4x4!!!!!! Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted April 29, 2009 Share Posted April 29, 2009 Sanded, wirebrushed and rust bullet painted "most" of the frame. :D :D CW Link to comment Share on other sites More sharing options...
offroader461 Posted April 29, 2009 Share Posted April 29, 2009 cut holes in my hood and install new hood vents :cheers: Link to comment Share on other sites More sharing options...
skaterguy58 Posted April 29, 2009 Share Posted April 29, 2009 Sanding rust out of floorboards till 1AM, that counts as today right? Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted April 30, 2009 Share Posted April 30, 2009 I made my patch panels for the MJ frame and took off my rear shocks. I am altering the mount so I don't have to tip them at such a steep angle. (They work better straighter.) CW Link to comment Share on other sites More sharing options...
offroader461 Posted April 30, 2009 Share Posted April 30, 2009 here are my vents; Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted April 30, 2009 Share Posted April 30, 2009 Looks GREAT!! I also like the Waggoneer nose!! CW Link to comment Share on other sites More sharing options...
offroader461 Posted April 30, 2009 Share Posted April 30, 2009 Looks GREAT!! I also like the Waggoneer nose!! CW Thx...i really need to take my bumper in to have it powdercoated! Link to comment Share on other sites More sharing options...
Red 1989 MJ Posted April 30, 2009 Share Posted April 30, 2009 I will replace the front brakes tonight. 8) Any advices ? Link to comment Share on other sites More sharing options...
