11
installing 1998 to 01 glass in 90 door?
DirtyComanche replied to dustyinthedirt's topic in MJ Tech: Modification and Repairs
AFAIK it's not feasible. I wouldn't say it isn't possible. But they did significantly change the door construction. Try it and let me know how it goes? -
wheels 89 manche
DirtyComanche replied to wheelsaz08's topic in MJ Hardcore Tech: Epic Journeys to Greatness
And make sure you weld that tube to the center section where you cut it. A lot of the support for the tube is generated by that 'cuff' area that the tube going into, since it's only the press fit and plug welds keeping it in. Try not to mangle that tube anymore either. If you score it badly and weld the scores up, it tend to warp the tube. Not a huge deal, but not super desirable either. On my setup I elected to weld the bracket to the cuff area and brace it. But I'm not using the same brackets, and there is a lot of other things that are different about the build in general. -
wheels 89 manche
Does your tie rod clear the track bar mount like that? I had to really move mine back. Remember you need a bolt through one of the holes too, so it will have to clear the head or the nut, if it's going to line up with it at least. -
89 MJ - Refreshing a Beater
DirtyComanche replied to scguy's topic in Member Projects: Your Comanches
JK takeoffs are cheap/available if you're willing to go to 17s. -
Sounds to me more like you just found the perfect engine donor instead. :rotf:
That looks like it should be about level, given what's missing. :thumbsup: -
Anyone running the Goferit flip insert?
DirtyComanche replied to Tj1's topic in MJ Tech: Modification and Repairs
And that's the problem. Somebody can't weld. Therefor I, or other competent individuals, are not allowed to do it. So with that, if I plate my knuckles, making them stronger, and specifically addressing the issues with D60 kingpin knuckles cracking from street usage, well that's illegal. If I weld a sleeve over a tie rod or drag link to make it stronger, that's illegal. If I use weld in bungs in DOM tubing and use TREs that are 10X stronger than anything the factory ever offered, illegal. Build your own pitman arm because nothing off the shelf will fit correctly, illegal, so you use one that's wrong and live with bumpsteer. Add hydro assist, oh, illegal to weld the mount on, so you use a clamp one and it's probably going to slip at some point and limit your steering. And in this case guys aren't allowed to weld the flip insert ('flipsert') in, so they just stick it in there and suck the nut down. Legal. Probably okay for a while, people have reported good results doing this. Unless it starts to move at all, in which case it will wallow the hole out and eventually cause the entire insert to mangle its way out of the knuckle, which will result in at least a partial (more likely total) loss of steering. Ahhh, well, that law did a good job of protecting people. Never mind factory welded steering components and the ensuing argument about their validity. Anyways, rant off. -
I'm thinking it would pretty much be junkyard only. If there isn't any local yards, I'm sure one of them will pull it and ship it to you (for a price....).
Rough idle won't rev up
DirtyComanche replied to trinity5007's topic in MJ Tech: Modification and Repairs
That's weird. Cam to crank timing issue? -
Which is stupid, but good point. -
I'm guessing they changed the mirror style and sizing, so they've covered them so Hyundai doesn't steal them for their next car. So is this a whole new platform? Or is it still a JK? The idea of a turbo diesel does something for me, along with lightening up the fat pig that the JK is. Edit. You called it a JL. So I'm guessing new platform. I wonder what, if anything interchanges.
New Leaf Spring Issue
DirtyComanche replied to Francesco's topic in MJ Tech: Modification and Repairs
If it was a 1" lift spring it would not require a longer shackle. Deaver probably has some screws loose if they told you that. Judging by how good of a job they did making these springs, well, they just might... Keep the shackles if you want, it's not like its going to matter. -
My 88 Comanche Restoration and Modification
DirtyComanche replied to RustInMyEye's topic in Member Projects: Your Comanches
The Treadwright's are retreads? -
There's nothing wrong with them as long as you weld them in. Might as well do it, unless you have plans of going to the '1-ton' TREs in the future. -
This is just the Jeep ones they own: Jeep CherokeeSRT8.com CherokeeTalk.com GrandCherokeePhotos.com GrandWagoneer.org JeepCherokeeClub.com JeepCommander.com JeepRenegadeForum.com Jeeperos.com JeepForum.com JeepPatriot.com JeepsterForum.com JKOwners.com MyJeepCompass.com NAGCA.com RubiconOwnersForum.com WranglerBoard.com WranglerForum.com
I figured I might as well start a thread here too... VerticalScope, which owns about 90% of the 'big' forums out there, was hacked sometime early this year. They were using a very poor method of encrypting user data and passwords, which meant that the hackers have been able to decrypt passwords. If you have an account on any VS forum, your password is not likely safe. Not a big deal if somebody logs in as you on a forum... But, if you use that password for anything else, it might be, since they have the email associated with it. Forums that you might be part of that are VS: Pirate4x4, JKowners, Yellowbullet, Layitlow, Cumminsforum, Jeepforum, and who knows how many others. Lists that are probably relevant: http://www.verticalscope.com/automotive/site-list.html http://www.verticalscope.com/outdoor/site-list-outdoor.html http://www.verticalscope.com/powersports/site-list.html I am a member of 13 different ones, most of them I had no idea were VS owned. VS has offered a few limp-wristed replies to all this, and made some factually incorrect statements about security. So, if you're using any of those forums, go change your passwords. But more importantly, if you use that password anywhere else, change it there. The big problem for me is I use a lot of passwords, and could not remember which ones were used on some of those forums (I do not visit a lot of them often), and thus I am unsure if there is overlap in password usage with other accounts.
Anone here the administration of Jeep Comanche on Facebook
DirtyComanche replied to pitbull4x4's topic in The Pub
This. And who cares if you list your truck for sale there? I'd rather sell to somebody that cared. The whole reason I wound up with the two I have is the guy didn't want to sell them to somebody that would just thrash them or part them out... -
I got one windshield out without breaking it once... It was quite time consuming, but it didn't go that badly. I just used a really big Olfa knife to cut the urethane from the inside, while applying gentle pressure. Eventually it popped out. I did have a used one put in my 89 back in the day. I had the wrecker pull it though, they had 3 or 4 good ones and would just move on to another if they broke the first one.
Looking at the arch in those springs, there's no way they're only a 1" lift spring. I'd send them back... And I'd probably ditch the adjustable length shackles too, but that's up to you. My gut feeling is the factory shackle is the 'correct' length for even a 3" lift spring. So maybe go back to normal length shackles and order a 3" lift spring? Which should have less arch than those springs they sold you... -
Codename Bumblebee: Now With Oil Pressure!
DirtyComanche replied to Minuit's topic in Member Projects: Your Comanches
That crimper has some interesting jaw options. I've got a Blue Point one like it (probably comes out of the same Chinese factory), and it only has 4 jaw options. Hmmm.- 60 replies
- frankenjeep
- project
(and 2 more)
Tagged with:
I'm on a well and septic, I can't really waste water, it just winds up back in the well. :rotfl2: Bathroom ones make more sense. I wish I could get (for reasonable money) the motion activated ones you see in commercial settings.
Are you not allowed to do that there? -
I operate on a very similar system. However, for optimal efficiency the staffing positions have been consolidated. That is to say that the maid, the butler, and myself are all the same person. Oh, and as said, Samsung fridges are bad news. Also, most of the 'smart' or 'fancy' fridges are bad news. The current trend of french doors is also bad news, lots of sealing problems. Also, touch activated faucets are stupid.
I passed on it. The body was not as clean as I was lead to believe. I also believe there is very little chance that the head was not cracked.
I've honestly never understood the point in the wireless controller. My wired one has a long enough cord that I can use it from the driver's seat, or from anywhere I reasonably would want to be while winching. Maybe I'm getting old, but the newfangled things just don't do a lot for me.
