11
AW4 fixed...but not now.
DirtyComanche replied to ParadiseMJ's topic in MJ Tech: Modification and Repairs
If you just pull the vent line off and fire it up, does it puke oil? As long as it is dry out, you can go for a drive without the vent line on with very minimal risk. If it does not puke, that may be all your problem is. If the seal is broken it could have been defective, or there is a score/burr that's cutting it. If I'm visualizing this correctly, that's the one that rides on the torque converter? If there was paint on the converter where it rides, that can do it even. Also, your converter might be cracked, or the crimp came apart, depending on design and construction. Just because it's new doesn't mean it's good. -
1989 4.0 renix will not start.....
DirtyComanche replied to fire797's topic in MJ Tech: Modification and Repairs
If you don't want to test pressure, you can at least verify if the injectors are firing or not. The preferred method is to use a NOID light, or a test light, or a multimeter with fast reaction or frequency capability. Pull all the connectors off, hook the NOID light up to #1 (or whatever) connector, crank engine and observe consistent blinking. Same with a test light. A good (if there is such a thing) analog meter will throw the needle back and forth on DC voltage, a good digital meter will show the pulses on voltage (it's not super fast) or you can get a low frequency reading on it using A/C frequency. Or you can pull the rail off, leave everything else hooked up, and crank and see if any fuel is coming out. If you burn your truck/garage/house/neighbourhood down doing this, please don't blame me. -
I missed that. Yeah. That doesn't work. -
Did the seal 'blow' or did it fall out? Stuff wears out, things aren't made to spec, and the factory may not have just put the seals in dry. I put new seals in with RTV on them when things get old, seems to help most of the time. But I'd check your vent line and the little vent cap thing too. -
So this only happens when hot? It will run every time after it cools down? And it's definitely not overheating the injector rail or fuel lines and causing vapour lock? -
You're right. It looks quite wrong when you see it up close.
I don't trust that truck as being rust free. Well, it might not have any rust on it now, but I bet they wire wheeled the rust off the lower quarters before they put that liner on it... Hopefully they did it right or it will still bubble through. That said, it looks solid to me and I'm thinking if you got it for $2k it would be good. Be prepared to spend some time learning what's happened with the swap in it, nothing like trying to get a wear part and not knowing which year/model you need.
Assessment of damage.
DirtyComanche replied to Knucklehead97's topic in MJ Tech: Modification and Repairs
Yeah, you could just cut the rubber hose and use a double ended barb, however, typically if the hoses are original (which they normally are) the rubber will have gone very soft and it will be weeping around the crimp connector. I just cut it off with a brake tubing connector and put a small 45* flare on the end, it's just to make it so the line can't slip off, decent hose clamps will seal correctly without a barb. This is not textbook correct but has always worked for me. If I owned one of those fancy flaring tools to do barbs/push connect flares I would use that, IE this one from Mastercool: https://www.amazon.com/Universal-Hydraulic-Flaring-Tool-Set/dp/B00063YR2I If you wanted to get more fancy there is other options. You can get a metric to AN adapter fitting that threads into the transmission, and then run AN fittings/stainless hard lines/braided hose. I've been debating buying them for the future, but it adds up to a bit of money for all the needed fittings, and you would need a 37* flare tool to flare the cooler for an AN fitting. -
I'm not certain, but do Cruiser's ground cleanups and such, check the CPS output for the sake of it, and maybe verify that the MAP and IAT are ballpark correct, because if you have spark and the injectors are not firing at all it isn't good (broken wire, bad ECM, maybe some things I don't know about). -
Try bypassing the fuel pump ballast resistor, it's a white porcelain block with two wires and a mount bolt, on the driver's fender up front, by the EGR solenoid thinger and airbox. Just pull the two connectors off and shove them together with some bailing wire or something. I wouldn't say I'm on the right track with that, but it takes 5 seconds to do. -
Won't turn over = won't crank = starter isn't turning = not a fuel problem. I'm assuming you mean it will crank, but will not fire or run? -
you wouldn't happen to have a part number for the clip and orings, would you? Oreillys full of idiots and had never heard of it before. I'm not home, so I can't check for sure. But they're GM disconnects, don't ask for AMC/Jeep because the parts guys don't know they used them. But I believe the clip you want is a Dorman 800-006, they come in a package of 5. The 800-013 o-ring pack should work, but I don't know much about automotive o-rings and normally use aircraft ones. There is a few different styles of disconnects though, so it can be hard to match them up. http://www.dormanproducts.com/documents4rb/135-145QuickDisconnectBuyersGuide.pdf But I'm serious when I say I would replace it with bulk hose and clamps. They're not actually quick disconnects, rather they're quick connects, so the factory could put things together faster/easier. If you take them apart without replacing the clips and o-rings, more often than not they will leak or come undone and blow the line off, so there's nothing quick or good about them. I cut the hard line off where they crimped the hose onto it under the engine, clean it, put a flare on it, and then use 3/8 transmission cooler line. The nipple for the quick connecter to go on at the cooler is conveniently already flared perfectly for use with regular hose. -
Axle and Ubolt pics.
DirtyComanche replied to outlaw star's topic in MJ Tech: Modification and Repairs
Hmm. I'm going to measure the XJ D44 I have when I get home, and see if it is a Trac-loc or not. It seems really odd to me if you got two with 3" tubes when that isn't something that's ever been documented before. The good news is going to 3" tubes is considerably stronger than 2.75". -
Got a BOM number on that axle? -
Renix junkyard parts to grab
DirtyComanche replied to 90comancheman's topic in MJ Tech: Modification and Repairs
Take everything, including the harness and ECM. The later ECMs are more desirable. That said, you can still source everything with a little creativity and adaptation. -
An 86 MJ shouldn't have had a D44, AFAIK........... -
Not really any different doing a rad with an auto trans, you just make a mess when you pull the lines for the cooler. I flush the cooler area on the new rad out with some brakeclean just to make sure everything is good before you hook it up. The top fitting is just a 45* flare fitting, so it comes off easy and makes sense. The bottom one should be a quick disconnect, so you'll need a new clip and o-rings (do NOT lose the backup ring between them) if you intend to keep it. Personally I'd buy some tranny cooler hose and some stainless hose clamps and delete that stupid thing. -
I'd suspect that rad will crack where it has been 'joggled' by the impact. It's just a matter of when, could be tomorrow, could be 10 years. If you keep an eye on it you can probably run it, but I would replace it for piece of mind. If you plan on recharging that A/C at any point (any idea where it leaked? Or was it a different problem?) you're best to leave the system as sealed up as possible to keep it as uncontaminated as you can. So I would just bend the condenser back straightish and leave it in place. -
Rear Windshield Gasket Where can I find one
DirtyComanche replied to gai092460's topic in MJ Tech: Modification and Repairs
I'd probably do that how I do aircraft windows. With the window already in, masking tape around the opening and on the frame, then fill the groove mostly full of urethane and run my finger over it to smooth it out and make it even, pull the tape and clean up any oopsies. As Eagle said, you probably could build up a profile if you wanted. It would be harder though, it's much easier with something like that if you only fill the gap partially and use a finger to give it a nice even slightly concave profile, but a completely flat profile would also not be too hard. How Leenewtonleon did it looks fine to me also, and it's how my 89 was done when I went to a non-slider in it since a gasket could not be sourced. -
Drag Link Replacement
DirtyComanche replied to buckwheat's topic in MJ Tech: Modification and Repairs
Unless you have adjustable ball joints, camber shims, or a desire to bend your front axle, camber isn't really adjustable. Knowing what I know now, and owning a tape measure, ratchet straps, two pieces of angle iron, and an inexpensive digital angle finder, I would never take a SFA truck to a professional alignment shop. Do you have a lift? The factory method of adjusting caster is to place shims in the rear of the LCA pockets, there is a fork assembly in there which is loosened and shims are added or subtracted between it and the pocket to slightly move the mounting hole. Personally I think it's a completely terrible setup and normally the nuts/studs break off if you try to do it. If you have a lift I would suggest buying some adjustable control arms. Caster can then be set by adjusting them, place the angle finder on the face of the differential housing to determine relative angle. In actual practice I often skip getting too technical on that, and instead I set the toe by ratchet strapping the angle iron to the tires, measuring across in front and behind the tires, and adjusting for 1/8"-1/4" toe in, then drive it and see how it is. Add caster until it feels better. Unless you have nowhere to start, in which case I'd suggest starting around 3* and expecting to wind up in the 5-6* range. If it still won't drive well, something is worn out, the axle/C is bent, or you should add more toe in. If you have an adjustable track bar, make sure the axle is centered first before doing anything. Make sure this is set with normal driving weight on the wheels, the axle moves side to side as the suspension compresses/droops. The easiest way I've found to do it is with a plumb bob taped to the fenders on each side, but there probably is slicker ways. When adjusting the inverted-Y type steering, make sure all adjustments are done with normal driving weight on the wheels. The toe changes as the suspension compresses/droops. Also, start by centering the steering wheel with the P/S tire straight, then set the toe on the D/S tire. I don't recall if the D30 center section is in line with the caster though, I haven't aligned one in a coon's age. You might want to look that up. Anyways, I guarantee you if you do follow those steps you will get it aligned as well or better than will be done on a professional alignment rack. -
Anone here the administration of Jeep Comanche on Facebook
DirtyComanche replied to pitbull4x4's topic in The Pub
And yet less than 12 hours later I'm in. [emoji2] Wonder if he read this? -
Could very well be this. The Renix and HO AW4 transmissions use different throttle valve cams. CAM PACKAGE, Throttle Valve 87-90 83504338 91-01 4637026 Good luck finding the newer cam package. Since the pump is fried and may have taken out other hydraulic parts with it, you might be better off replacing the tranny with a 91 and up AW4. :dunno: I have a renix AW4 in my HO truck and I have no TV cable issues..... and my internet works great too! :thumbsup: How did you route it? The Renix cable is 6" shorter or so. I'm running a HO intake/TB with Renix controls and tranny, I made it work but I had to cut up the brackets and some other creative nonsense.
1987 comanche first car
DirtyComanche replied to Jackrabbit41's topic in Member Projects: Your Comanches
Sucks. There's lots of them out there though... -
He seems quite useful. -
Aftermarket Tachometer
DirtyComanche replied to jdritch's topic in MJ Tech: Modification and Repairs
You do realize that both of those links are for universal tachometers that use a magnetic pickup (the reference to "Hall sensor") rather than picking up a signal from the ignition system ... right? It means you would have to mount some kind of bracket, probably near the crank pulley/vibration damper, for the sensor to "read" the rotational speed of the engine. Hijacking. Is there decent analog display tachs like this? Like what? This thread seems to be about digital tachometers. What analog tach are you asking about? Sorry, I could have been more clear. Analog tachs with their own hall effect sensor, so if you don't have an ignition system it isn't a big deal. I know there is some marketed to diesels but they generally seem to be terrible.
