11
1990 2WD Conversion and Rebuild Project
DirtyComanche replied to BabySpinach's topic in Member Projects: Your Comanches
Oof, I'd send the front housing to a sandblaster, or go at it with a knotted wire wheel, because that's some heavy scaling on it. -
What rims and what center caps?
DirtyComanche replied to Jackrabbit41's topic in MJ Tech: Modification and Repairs
I think you can just use yogurt containers to make caps for those, if you're umm, cheap. If you measure the hub bore diameter on them you can size any universal 5 bolt cap to fit (the type that go on before the wheel). -
Looks like the body is in good shape, should be a great starting point. :cheers: -
Image Not Found There's enough space in the back. ;)
Make sure the track bar is set to the correct length so the axle is centered before you do anything else. The steering wheel is adjusted to center by lengthening the drag link. Set toe first by adjusting the tie rod. Drop pitman arms are not a good idea unless you have a drop bracket for the track bar on the frame side, or a bracket on the axle that relocates that side higher.
Project "Black Betty"
DirtyComanche replied to shelbyluvv's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I've always liked the look of the visor. -
Swapping the speedo is pretty easy if you have another cluster to pull one out of. It's just in there with screws.
Swapping in a Cherokee 8.25.
DirtyComanche replied to Knucklehead97's topic in MJ Tech: Modification and Repairs
Or just buy these: http://www.ruffstuffspecialties.com/catalog/UB3.html -
You can get u-bolts made locally, often not for a lot of money. Check out a spring shop. I just use 5/8" ones for everything, better too strong than not strong enough. -
Anone here the administration of Jeep Comanche on Facebook
DirtyComanche replied to pitbull4x4's topic in The Pub
They're only good for that. And cat pictures. -
It's for an automatic. Inability to start the thing at all, and the backup light issue.
Steering for 5.5" lift
DirtyComanche replied to jeepjack54's topic in MJ Tech: Modification and Repairs
It makes sense if you want beefier TRE's. Yes, but at that point you probably want to go to a different drag link and probably a WJ knuckle. Suddenly its not so simple. -
Also, you can actually just ream the knuckle from the top down with a morse taper reamer, but you will have to go up to a '1-ton' TRE and make the entire tie rod from scratch, plus ream the drag link or find the correct metric tap. More work, doesn't really make sense, but you can actually build the entire thing with zero welded components if that's a problem. -
How do you go about flipping the TRE? Pictures? Drill the knuckle out and install one of these: http://www.tmrcustoms.com/store/index.php?main_page=product_info&cPath=143_209&products_id=1961 They're available elsewhere (Ruffstuff), but that's one of the better ones as it's a full circle with a nice lip on it so it's easy to weld in. Note, these aren't legal in all jurisdictions as they have to be welded in. Do it cleanly and nobody will know it's there. Up to you, but they will raise the tie rod by 3" or so, and it makes a big difference. -
Giving them directions on where to look for next time doesn't count as giving them a hard time. :dunno: Or linking good previous threads. -
That's what it's like here too. :yes: You don't spend much time on Facebook groups. I blame the easy user interface for allowing people with single digit IQs to be able to curse the world by sharing their stupidity. Seriously. It's ridiculous what gets posted and actually replied to on there. -
My 88 Comanche Restoration and Modification
DirtyComanche replied to RustInMyEye's topic in Member Projects: Your Comanches
If you made a new mount using some sleeved bushings you could get the crossmember a little higher. Not sure if you care though. -
There are a lot of people who don't use or join forums but are comfortable with fb groups/pages. If a few of you set up and Admin the page there, you would see an increase in member traffic while also allowing you to help a broader range of members. Facebook has killed forums. People are more comfortable with it, find it easier, and they're already logged into it anyways (gotta like and share those cat pictures, they ain't gonna do it themselves). Which sucks because Facebooks formatting does not lead well to cataloging technical information, IMHO. -
update, licensed M2 Aircraft Maintenance Engineer, working on obtaining an M1 license now to grandfather in structural repair and avionics licenses as well I did my M1 last year because I needed to renew anyways. Thus far I haven't used it for anything but at least it's on there before they change the rules again. Well worth it for the minimal cost and the bit of time I had to invest.
$100-200 is pretty normal for a price. -
Going to look at a 99 XJ to buy not running.
DirtyComanche replied to rustybottoms88's topic in The Pub
Offer $500. Start over with all troubleshooting, right at the basics (air, fuel, spark). I don't think his mechanic was any good. Try to get the old PCM (ECM?) with it, because there was probably nothing wrong with it. Go from there. -
IMHO it's worthwhile to flip the TRE on the driver's side at that height. Otherwise, yeah, V8 ZJ stuff should be good enough for mild usages. -
'Ratmanche' the '88 Comanche
DirtyComanche replied to Rockfrog's topic in Member Projects: Your Comanches
Anytime you have a rubber BONDED bushing, you have to torque the bolts with the suspension at 'natural' weight/height. For what we care that means set the truck back on the tires, then tighten everything up. Yes, you can unevenly load the crap out of things by torquing them when they're at a drooped/flexed state. I don't think that is your issue at this point. But for the sake of it, I would loosen everything up as it is sitting there, jump up and down on the bumper a bunch, and just see if it settles out any. Torque it back up in that state. IMHO, my experience with the unibody constructed Jeeps is that they were very much bang on in the critical dimensions. They had very extensive jigs for building these vehicles, as the manufacturing process was nothing like a conventional body-on-frame vehicle. I would highly doubt that the leaf/shackles hangers, which are listed as a critical dimension, were installed more than 1/8" out of true by the factory. Honestly, short of your springs being screwed, which should have been obvious before this, I would start putting an angle finder on that 8.8 axle and see if there's a story that needs to be told. If one end is bent up, and the other down, as can happen easily in a rollover, it might well account for a large amount of the 'out of true' that you're seeing on the tires vs the uniframe. -
They screw things up all the time, and not always in the bad way. As they say it's outside of their warehouses, it's a good sign. They often buy up old stock and liquidate it. I paid something like $18 for a later XJ dual diaphragm brake booster. It showed up. :rotf:
