fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. I drilled them out and brazed in new screws.
  2. I know when my TPS was not adjusted correctly it would bog down when I accelerated, maybe not your issue but something to keep in mind.
  3. They are the codes for the keys. Are two of them rectangular and two are rounded? Rounded are for the doors.
  4. Maybe like this?
  5. Welcome. When you post, at the bottom there's something that says "Drag files here to attach, or choose files" you can click on choose files then browse to your pics on your phone or PC. I might have some burgundy plaid seat covers, I'll look.
  6. Thanks guys, got one.
  7. I need part #3 in the diagram and it has to fit the AX-15 gearshift that goes into the transmission (AX-15, AX-4, AX-5) not sure if BA-10/5 is the same, Shipped to 94534. Thanks.
  8. 2.8L V6, Automatic At the Redding CA Pick-N-Pull
  9. Where in Northern California were you?
  10. Can't someone pull out the two inches, and just pull 2 inches on the other side of the eye then, then 4 inches, then 8 inches, etc.. It's a good deterrent though, hopefully some dumba$$ doesn't want to take the time to do that.
  11. While I can appreciate the workmanship that went into making those, I don't think they fit the style of the truck, just my opinion from within my box. To each their own.
  12. I remember Don (Hornbrod, RIP) had a mod that fixed this.
  13. fiatslug87
    Finally
    Is it still in California?
  14. fiatslug87
    Finally
    Welcome, what are the specs on it? Remember to add it to the registry.
  15. As Eaglescout said.
  16. My RENIX Engine Monitor (REM) from Nickintime https://nickintimedesign.com/
  17. All mine have buckets, but I did install a Cat 5e connector for my REM into a switch plug.
  18. Not cleaver, but I put a power source in the center console.
  19. Ashtrays are the same.
  20. I've seen some mini consoles that are longer in the front, I assumed they were for the automatics to accommodate the linkage but I only see one part number listed in the parts catalog. But as Stroker said each will accommodate the boot, however, you do need the retaining ring for a proper fit.
  21. The Nevada yards always have a lot of XJs and now they have an '86 MJ.
