fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. You say tomAto I say tomato, from the definitions it seems they are unibody:
  2. What's the red interior from?
  3. Isn't the roof part of the structural integrity for unibody vehicles?
  4. I always ask for weights on the inside only, at least I wouldn't have to see the dumbassery.
  5. Do the little "nubs" that hold the clips for the metal trim interfere with the rubber trim?
  6. The black contrast looks great!
  7. I totally missed these were from Mopar Performance, I should have installed mine years ago to boost my HP. BTW, I would be interested in a reproduction one.
  8. Nice, pictures of the engine?
  9. TPS should be 17% at idle. Test your O2 sensor resistance between A&B should be 5-7 ohms. Edit: I see your O2 sensor is switching so it looks like it's working properly.
  10. How much are those? An arm, a leg and a pair of ""?
  11. Here's the '88 electrical manual, I know some things are different, but should be similar.
  12. Yes, I run all of mine to 2.5L overflow tanks. So technically it is not a closed system.
  13. If you want to never have to replace that plastic tank but want to keep the closed set up you can get one of these http://macsradiatorshop.com/replacment-jeep-radiator-fill-tanks.html Pricey but very well made.
  14. Stage one says ECU#P4529334 and stage two says "add..." so yes the performance ECU seems to be required.
  15. Eagle covers some difference here:
  16. Look for these.
  17. Wow, how did you order it? And then you shipped it back!
  18. Anyone know the difference between HD and High Volume oil pumps?
  19. You can also try Spencer at http://jeepsticker.com
  20. Is it PN P4529380?
  21. I have a NOS one of those!
  22. If you have to to remove the fuel pump, dropping the tank is not necessary.
