fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. I've learned exactly where to park each vehicle so they're right at the sidewalk but not hanging over The funny thing is ours is not the shortest driveway in the neighborhood.
  2. Mine is short but fairly steep, it was fun pulling the engine with the truck in the garage and the hoist on the driveway. At least there's no snow or ice here.
  3. ............there you sit drinking beer for 1.5 hours while you recharge.
  4. From what I remember, I put a flathead screwdriver between the vent and dash at the top, pressed down and out. There is a piece that can fall into the vent so be careful.
  5. I still have mine from my formative years.
  6. I don't have any recommendations but I've had a cheap corded Homelite one for 10 years and it's been a workhorse.
  7. Too funny, that's 22 miles from my house and 18 miles from my work.
  8. I've always read a front receiver hitch will not work with the skid plate. Maybe with some modifications it could work?
  9. Received the OmixAda yesterday, looks identical to the new NTK/Bosch, 4 wires, steel body and resistance is 4.4 just like those two. Not sure if I'm going to try it out or just return it.
  10. I do not think this is correct. The symbol is not the same as fog lights, it is the same as the high beam symbol. If you look at the factory wiring diagram in the above attached thread, the switch is only activated if the high beams are on, the switch is wired to the high beam circuit. Conversely, the fog lights turn off when the high beams are activated. These are the the fog and sport bar light switch panel symbols:
  11. It must be the air flow is different now and the cable isn't being buffeted. You should probably zip tie the cable down better anyways. But, hey, a fix is a fix
  12. Good work! I'm still waiting on the OmixAda O2 sensor, should be here tomorrow.
  13. Don had written a DIY for an adjustable version.
  14. My sport bar switch is where the trans power/comfort switch is located. This thread has the installation instructions showing its placement.
  15. Thanks, some day I will replace it with a modified Hurst Pistol Grip for a MOPAR.
  16. Did the o-ring/spacer/o-ring come on a plastic "plug"? You're supposed to push the entire thing into the fuel line, remove the plastic plug and then press the line onto the rail. If there is no plug, place the spacer on the rail then an o-ring, press the line on, remove the line (o-ring and possibly spacer will stay in the line), install the last o-ring in the rail and push the line back on. Make sure to lubricate the o-rings.
  17. Is the driver's the one with or without the bend in the metal attachment bracket? I have a cordovan (burgundy) one you can have, no charge.
  18. Welcome
  19. It's plug and play, nothing else required except for a working bulb. OP wrote 1990 XJ.
  20. The '90 and up light and harness are different, both power and ground are provided by the harness. I'm sure you can make your light work by only connecting the red wire from the harness.
  21. Thanks Jeep Driver, I'll try an OmixAda for the 4.0L. https://www.cseoffroad.com/1722216.html
  22. Well, I just received a Bosch one. Looks identical to the new NTK: metal body, four wires out of the body and reads 4.5 ohms. I will try it and see but I'm not very hopeful. Edit: I checked resistance between A&B, 4.5 ohms just like the NTK, ended up just returning it. Interesting that both Bosch and NTK wete made in Spain, they must be from the same manufacture.
  23. Hey Knucklehead, did you get the diamond plate or the plain?
