8
Everything posted by fiatslug87
looking for your Comanche literature
fiatslug87 replied to Pete M's topic in MJ Tech: DIY Projects and Write-Ups
Too funny, that's the one I was going to send you. Pete, I remember you had a thread requesting MJ literature be posted, if you find it can you make it a stickey? Edit: found it -
Need opinions on removing broken stud
fiatslug87 replied to fiatslug87's topic in MJ Tech: Modification and Repairs
Anyone use a 90° flex shaft attachment? Think this will work? https://www.amazon.com/DEWALT-DWARAFS-Right-Angle-Shaft/dp/B013UBXU3E/ref=mp_s_a_1_3?keywords=dewalt+right+angle+attachment&qid=1559610357&s=gateway&sr=8-3 -
Just by looking at it I can't see that the lifting/tilting method would give enough clearance, this is also a manual so the shifter would need removal(?). I'm thinking of pulling the head, is this crazy? -
fiatslug87 posted a topic in MJ Tech: Modification and Repairs
I've had a vacuum leak at cylinder 6 and found the last stud missing. I just removed the intake and exhaust manifolds and can now see the stud is broken about 1/8" below the surface. I don't' think I can get a drill, even a 90° drill in there due to the firewall bump out. What would you guys do? 90 4.0L -
Who, me? Withold info from my MJ brethren? NEVER! I know I posted the whole list in a thread somewhere, here it is again.
Long bed ones are 77 1/2" from tip to tip of the brackets and each rail is 33". Here are the part numbers from a Comanche accessory catalog. If you pm an email address I can send you a PDF of all the listings if you do not have them.
Here's the front skid plate. It attaches to the frame behind the sway bar bushings (threads are present) and to the front piece under the radiator.
EGR fitting size??? Custom EGR Pipe???
fiatslug87 replied to hakukamana's topic in MJ Tech: Modification and Repairs
I had a similar issue. I ended up cutting the pipe in half, attaching both ends loosely and sleeving with another pipe and welding it. The engine was out which made it easier. In CA the EGR has to work. -
Trying to replace shift Boot
fiatslug87 replied to Phillip Gwin's topic in MJ Tech: Modification and Repairs
Thanks for posting the vid. I've been wondering what's the "easiest" method. -
I had the same issue a while ago, I replaced the injectors with referb ones and it's been fine ever since. I did replace the exhaust manifold and O2 sensor at the same time but I assume those were not the issue.
Need help with finding fuel injectors
fiatslug87 replied to jdwillys's topic in MJ Tech: Modification and Repairs
Thanks Cruiser, I "joined" CherokeeForum yesterday to contact him. -
What does jhc7399 charge for a set? -
Prop valve adjust/setting
fiatslug87 replied to WhiskeyBravoXJ's topic in MJ Tech: Modification and Repairs
Have you read this thread? -
I had those Hellas, eventually moisture built up inside and corroded the reflective surface. I went back to sealed beams.
Retainer for shifter boot
fiatslug87 replied to Manche757's topic in MJ Tech: Modification and Repairs
The Quadratec item has a review saying it fit their '94 so as eaglescout526 said, it should fit. -
Not even close . The University of California motto is Fiat Lux (let there be light) I gratuated from the Santa Cruz campus in 1987 and their mascot is the banana slug so, Fiatslug87 was born (let there be slug 1987). Now the important info:
Frustration with missing emblems
fiatslug87 replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
I have a pair you can have for cheap, one is in pretty good shape, the other not as good. PM me if interested. -
Just remember the plugs are different for 1990 and up.
Renix fuel system.
fiatslug87 replied to Wounded_Fighter's topic in MJ Tech: Modification and Repairs
That's done with your right foot. -
Tesla roadster at Ridge Vineyards in the Santa Cruz mountains overlooking Apple's headquarters (Apple Park).
Lemmy was much better! The voice isn't gravely enough.
Tilt Forward Mechanism on Bucket Seats
fiatslug87 replied to Ls2xjcomanche's topic in MJ Tech: Modification and Repairs
Follow the cable and zip tie it to the frame at the bottom corner to take up the slack.
