13
86 MJ No Spark
eaglescout526 replied to JustaValiantguy's topic in MJ Tech: Modification and Repairs
Does the wire have a flat connector and is a red wire? If so that for the optional under hood light. It does not plug into that spade on the coil. Don't know what that's for. For no spark / start I would check the Crankshaft Position Sensor on top of the transmission bell housing on the drivers side. See if the sensor is dirty and putting out the right voltage. -
Like the title says, I am in search of a drivers side drip rail molding. For whatever reason mine is missing from my truck prior to my owner ship and I'm curious if anyone happens to have one to sell. Does not matter if it is black or chrome.
Battery tray Question
eaglescout526 replied to Articul8's topic in MJ Tech: Modification and Repairs
Dang. Well, snapping it off or putting a good liquid rust remover like vinegar is all I got left for ideas. -
You could always try soaking the nuts in something if you don’t want to snap it off. If you are not in a rush to get the job done -
Lol, oops. yea I am. No that shouldn’t happen on the freeway at all. Just at times when the vehicle isn’t moving.
From what I’ve been hearing a lot of people don’t like it and it seems like the battery enjoys dying early in its life. There’s been times at work where customers come in because their “fuel saver” battery will be dead and it would not be in stock here at the dealer. Chrysler can’t seem to keep the special battery stocked unless the dealer orders them on the side from elsewhere. But they are only on certain Jeep vehicles equipped with the pentastar 3.6 and fiats. So they are not terribly problem prone, just that battery likes to die
No, they don’t. Thank goodness too.
Alrighty, after spending half the day swapping throttle bodies around I finally got it done. Could not do a whole swap and done, I had to swap the bowls around as the other throttle body had another open vacuum port and the one that came with my truck did not have such. So after installing the wrong gasket and discovering gas leak around the bowl, I removed the body again and tightened the screws to the bowl and swapped in the right gasket and now she purrs. Still a tiny leak around the bowl but there's nothing I can do as no one seems to make a rebuild kit for the 2.5L TBI. I did find and buy the last two injector retainer kits from Chrysler so that is now all new. Lesson learned, do not tighten those screws so damn tight! Updates: while back I swapped in a drivers side remote mirror so now I have a dual remote set up finally, swapped throttle body and several months ago I sent off an RX-141 radio I found at AMC salvage to be repaired after my goof up and Jeremy just now finished restoring it! I think I will probably end up swapping in that radio. Also swapped valve cover with the new one I recently painted and got a 21 slot grill on. I'll get a pic of that later. Future: Cruise control, radio and hopefully a paint job. Thanks Pete for this sticker! RIP Don. Edit: Just found a rebuild kit after some digging.
- 657 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
What gogmorgo said, give it a good ole tune up and drive it around more than just a block and push it a little to get everything up to operating temp. Then go get it tested after your warm up drive
Customish Clock Panels
eaglescout526 replied to SatiricalHen's topic in MJ Tech: Modification and Repairs
Looks like a good idea. Probably would be a better alternative than cutting holes into the clock or the clock delete panels -
Thank you. Little update: Since replacing the O-rings for the TBI I have noticed an increase in throttle response and the injector is not spraying all over the place now. Woo!..... broke the injector retainer screw which some of you may have seen. Went to AMC salvage today, scored a whole cruise minus the speedo cables which I hope I can find new. Came out of an 84-86 Cherokee? I do not know but it had the GM deluxe trash can at one point. I may replace the wiper/cruise/turn signal lever if they are reproduced for cruise. Also a plan B to fix my screw up braking that screw head, the yard had a used throttle body while I was there and so naturally I bought that, luckily it was not a fortune. Plan is to get the throttle body cleaned while I'm at work before a weekend install After watching TFL's video on their MJ I may have gotten a little too inspired and I decided to take my front header apart and repaint the trim. I also restored my eight slot grill but that was before the videos existence. Now some pics: Naturally I love it but who doesn't love what they do to their truck. Not seen very well in the picture but I did buff the headlight retainers to stand out better.
- 657 replies
- pioneer
(and 2 more)
Tagged with:
Parks and rec There is one in the movie "Small Soldiers".
Anyone found a bench seat cover that fits?
eaglescout526 replied to EUREKA's topic in MJ Tech: Modification and Repairs
Not really an answer, but for as long as my grandfather owned the truck before me, he had put a blanket over the bench to protect it, cut holes in it for the seat belts and done. -
New Leaf Springs
eaglescout526 replied to Ls2xjcomanche's topic in MJ Tech: Modification and Repairs
I bought one leaf set from them. I love it. Course any non broken leaf pack is an improvement over a pack with one broken leaf. That being said, their dowel pin to line up with the axle is not the same as the factory axle alignment pin, so save your old leafs like Pete said. -
Who knows? But we all know you can't do that with the HO front end. Maybe we could use that as the symbol for Renix era Jeeps
After seeing this I realllllllyyy want to have mine repainted. Also I would like to point out that the grill is broken on the second slot closest to the passenger side
Unknown electrical components
eaglescout526 replied to Amccutc21's topic in MJ Tech: Modification and Repairs
In the top picture, from left to right is the cruise control module, emissions service timer and the ECU. As for the leaks I have heard the windshield and the master cylinder are common places -
I see a tool for mass reproduction.
Wow. This sounds really familiar to me. When you remove it from the truck and put it on the bench, do you find the reverse or fifth gear engaged? This was my problem when reinstalling my trans, the fifth gear would slide in and I could not engage any gear unless I removed it from the truck and put the trans back into neutral. The problem was tilting it back and the trans would slide into gear. This trans is long gone as it grenaded it self.
Thats the load sensing valve. Some guys delete it but that is due to it not working.
Fuse panel clarification
eaglescout526 replied to ftpiercecracker1's topic in MJ Tech: Modification and Repairs
Chime module is blue or black Black chimed only on key in ignition or seat belt, blue does the previous two with addition of warning you about the headlights dash/headlights being on The silver fuse is the wiper breaker. -
A College Students V8 Comanche
eaglescout526 replied to 88mjsally's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Holy cow! Those taillights have mirror reflection to them! That's a score to make some jealous. Did ya find them in a junkyard? -
https://www.crownautomotive.net/Idle-Air-Speed-Motor/83502375.html .
