eaglescout526
Administrators
    13
  1. *X2 -YY AGC APA MONOTONE PAINT PACKAGE BCQ Battery - Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NHM AUTO SPEED CONTROL PE4 Colorado Red QE4 Colorado Red SBA POWER STEERING SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT WJN 15" ALUMINUM WHEELS Build date 10/22/87 Body code JL62 Sold by RENTON JEEP-EAGLE, RENTON WA
  2. *X1 -SA Charcoal 3LW AGJ AGP APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT DDJ 5SPD MANUAL TRANS ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Colorado Red QE4 Colorado Red RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT WJN 15" ALUMINUM WHEELS Build date 3/16/88 Body code TM61 Sold by JIMMIE VICKERS INC, MERRITT ISLAND FL
  3. *ZZ -ZZ CGX Head Restraints-Outboard Seating, RR DCK 4SPD MANUAL TRANS - AISIN SEIKI EPD ENGINE - 2.5L I4 TBI GAS HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAF HIGH ALTITUDE EMISS CONTROL PKG Build date 11/29/85 Body code JL62
  4. Welcome to the 80’s and early days of sophisticated car wiring!
  5. Nope. That’s the blue chime box that lets you know the headlamps are on after turning off the Jeep and that your unbuckled and your key is in the ignition with the door open.
  6. Wha? No the headlamp delay module is the silver 4 prong one that is tucked up next to the steering column if installed.
  7. Can’t be, the white one is the horn relay. Unless AMC did two of them for some reason.
  8. Yup!, it is the latest and greatest number and I order it when I added AC and it says R134 on it. Now the dealer info I found a couple years ago doesnt say you have to change out the expansion valve unless there is an issue. Lol glad you found it.
  9. 56003173 is the expansion valve part number.
  10. Looks like it should. What year is the MJ Pete?
  11. Yes you will need new o-rings all around. The expansion valve doesnt need any o-rings but should be changed out to work with R-134a.
  12. I can get the sheet while I’m at work but can’t get on CC to post it.
  13. Yeah this is good info. I didn’t know there was a new filter. We all should probably change this.
  14. I will edit this list as I find more stuff or if something gets pointed out that I missed.
  15. I have one set up, it’s hidden as I keep looking through the parts catalog to find year specific and MJ and XJW specific things.
  16. Hahaha I can’t do an LS swap. It’s not really mine and the I6 is plenty of power for my sister. I think we will work to change the trans to a 5 speed but that’s about it.
  17. Radiator swap went off without a hitch. Got the new one in. Crowns model is accurate to the T except the radiator cap. Looks like they designed it to probably fit their caps which doesn’t surprise me. So I broke out the dremel to make sure my AMC radiator cap would fit on the radiator. All is good. No leaks which is nice.
  18. *C1 -SA Charcoal 151 Zone 51-Chicago 1AA U.S. Dealer Retail 26C Customer Preferred Package 26C 2TC Customer Preferred Package 2TC 3VN Customer Preferred Discount 4HA Special Scheduling Condition I 4M1 Retail to Bid Diversion Tracking 4UA SCA Tissue North America LLC ADH HEAVY DUTY ELECTRICAL GROUP ALA APA MONOTONE PAINT BAR 90 AMP ALTERNATOR BCD 550 AMP MAINTENANCE FREE BATTERY BGA POWER FRONT DISC/REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKA CARPETS - FLOOR AND CARGO AREA DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS DGS 4-SPEED AUTOMATIC AW4 TRANSMISSION DHA LOCK-UP TORQUE CONVERTER DHN COMMAND-TRAC PART TIME 4WD SYSTEM DHT SHIFT-ON-THE-FLY,P/TIME T/CASE DJH 230MM FRONT AXLE DMD 3.55 REAR AXLE RATIO DRJ DANA 35 REAR AXLE ERH 4.0L I6 POWER TECH ENGINE GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEC FRONT LEFT SIDE SLIDING WINDOW GFD REAR SLIDING WINDOW GRZ LEFT REMOTE MIRROR GSZ RIGHT REMOTE CONTROL MIRROR GTZ MANUAL REMOTE MIRRORS HCD DO NOT USE - SEE HCA JAZ DO NOT USE - SEE JP, KA CLASSES JCA 85 MPH PRIMARY SPEEDOMETER JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER K3Z STRIPE/BADGE/MOLDING/COLOR KER KWR STRIPE/BADGE/MOLDING/COLOR LBC GLOVE BOX LAMP LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PS7 QS7 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBC Compact Spare Tire TBM Tire Carrier Winch TMW Tires TZA Goodyear Brand Tires WJN 15" Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z82 Right Front Spring Group XI Build date 2/28/92 Body code JL61 Sold by SCHAUMBURG JEEP INC, SCHAUMBURG IL
  19. *F2 -SA Charcoal 142 Zone 42-Detroit 1AA U.S. Dealer Retail 5KK First American Title Insurance CO. ALA ALK APA MONOTONE PAINT BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA POWER FRONT DISC/REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKJ BLACK VINYL FLOOR COVERING CSR PASSENGER ASSIST HANDLES DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS DGS 4-SPEED AUTOMATIC AW4 TRANSMISSION DHT DMG 4.56 REAR AXLE RATIO DRJ DANA 35 REAR AXLE EAA ALL ENGINES EAF ALL FUEL INJECTED ENGINES-GAS EPD ENGINE - 2.5L I4 TBI GAS GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GNA REAR VIEW DAY/NIGHT MIRROR GRZ LEFT REMOTE MIRROR GSZ RIGHT REMOTE CONTROL MIRROR GTZ MANUAL REMOTE MIRRORS HCD DO NOT USE - SEE HCA JAZ DO NOT USE - SEE JP, KA CLASSES JCA 85 MPH PRIMARY SPEEDOMETER JJA CIGAR LIGHTER K3Z STRIPE/BADGE/MOLDING/COLOR KDB STRIPE/BADGE/MOLDING LBC GLOVE BOX LAMP LCJ DOME/READING LAMP B-PILLAR LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MBJ Black Bumper MFF Black Grille MHB Bright Windshield Moldings MMC Rear Solid Window MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PW7 Bright White Clear Coat QW7 Bright White Clear Coat RA8 Delete Radio SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z56 Left Front Spring Group Vi Z76 Right Front Spring Group VI Build date 9/21/89 Body code TL61 Sold by DAVIS JEEP-EAGLE INCORPORATED, BATTLE CREEK MI
  20. I’ll start a thread and take some pics. The car is in nice shape and needs to be put inside but it seems like my grandfather was smart about this car and got parts and pieces for it to bring it back to its glory. It’s white with the blue interior from which I have seen is iconic to the Z line.
  21. Welcome to the club and congrats!
  22. Yeah you’re right Pete. I think I have a couple books somewhere on diy repairs around your house and appliances is one of the books.
  23. Yeah I’m starting to hate them too. I’ll do anything to not spend money on a new one. Except the washer. That was a lost cause there.
  24. Yall ever have a moment with your wife or other and they drag you to the appliance section of say Best Buy and look at dishwashers? Few days later same appliance you looked at fails? Yeah had that last night. Tore the dishwasher apart and found the problem. The bi-metal or fuse is what they should call it went bad and thus I ended up with a dead control panel to the dishwasher. So a new one is on the way. I verified the issue with both a multimeter by following the service papers instructions and i put a 5 amp ATO fuse to further confirm the issue. Fun stuff!
