13
*X1 -H9 3LY AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE BCQ Battery - Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDJ 5SPD MANUAL TRANS ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAF HIGH ALTITUDE EMISS CONTROL PKG NHQ Transmission Heater NMB ENGINE COOLING - STANDARD DUTY PS4 QS4 RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 8/23/87 Body code TM61 Sold by CASA CHRY-JEEP ON THE WESTSIDE, ALBUQUERQUE NM
*B1 -H9 AGC APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual EPD ENGINE - 2.5L I4 TBI GAS JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PWB QWB TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 9/10/87 Body code TL61 Sold by SCHAFER MOTORS INC, IRONTON OH
Parts needed for a waggy header
eaglescout526 replied to Smokeyyank's topic in MJ Tech: Modification and Repairs
I have the plugs for the headlamps in my save for later on Amazon. I’ll have to get the numbers for that. -
Nope. But me and my roommates jokingly cheer on the huskies as a retort haha.
My wife went there as well. Never stops talking about that place.
The harness is probably the most important part to using that header. Otherwise it’s just a decoration piece. You can make a harness as all the plugs for the lamps are available, i don't know about the sockets for the turn signals and the side marker sockets are the same as what’s on the standard harness. -
For a democratic state, there sure as hell is a lot of XJs and MJs floating around up there. My wife used to live up the before coming down here and I’ve seen a couple MJs and plenty of XJs and an Eagle.
He also has another Street MJ. Both of them are awesome.
86 2.5l 4 cylinder distributor
eaglescout526 replied to harleysMJ's topic in MJ Tech: Modification and Repairs
But is it outputting the right voltage? Voltage should be more than .2VAC. If it’s not within the acceptable range of .3-.5 with .2 being the absolute bare minimum to get one by, it probably isn’t good. Have you cleaned the inside of the cap and cleaned the rotor too? now you say the coil works, are you getting spark from coil to the cap and it’s not just distributing from there or is the coil just passing a “test”? -
Hang on there. If you’re not getting spark have you tested the CPS or crank shaft position sensor that sits on top of the drivers side bell house? If it’s dirty or not outputting the proper AC voltage anymore it won’t tell to ECU that it is ok to start the ICU and send spark down the line to fire the plugs. But yes the 2.5L distributor does not need a lot to it to work. -
Chunk, A 1984 XJ
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
I am finally happy to say that the floor is done! They aren’t the best welds in the world but they are pretty sturdy to satisfy me. The only issue I still have is the rear of this floor panel is the seam sealer and lack of metal to actually batten the floor down is an issue but not much of one to have me greatly concerned. Now I need to get some primer to paint the floor and seabring red paint to make the floor new again. Now I can begin electrical work for the seats, doors, mirrors and getting the harness prepped and ready for the TBI conversion. -
Spare Tire Cable Replacement
eaglescout526 replied to Warren99's topic in MJ Tech: Modification and Repairs
If you drill out the rivets holding the brackets together, it’ll all come apart pretty easy and you’ll see how it’s built. I took a trashed one and adapted the brackets to an S10 winch for mine. -
*ZZ -ZZ CGX Head Restraints-Outboard Seating, RR DDJ 5SPD MANUAL TRANS EPD ENGINE - 2.5L I4 TBI GAS HCC HEATER W/UPR LEVEL VENTIL - TYPE II JDA SPEEDOMETER - 140 KILO PRIMARY KQJ LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED Build date 11/14/85 Body code TL62
Whoops. Forgot the location. I’ll get that here in a minute.
Upgrading my “dummy light” gauge cluster??
eaglescout526 replied to Bomberjeep's topic in MJ Tech: Modification and Repairs
You’re right, i don't know how I didn’t notice it before. For some reason I was thinking it wasn’t there on mine. But that’s weird that yours doesn’t have the 90* elbow. -
Actually if you look back at when the kit was first started by Dana, they had metal cased speed sensors where the threaded sides were different. Now as time went on and the kit was made on the side by Dana until someone bought it, they went to the plastic sensor which I’m sure accommodates for two different speedos, hence the adaptor. I don't know which make had the cable be the same on either side of the sensor but I’m willing to bet it was one of the big 3.
NOS 89 4.0 195 Thermostat
eaglescout526 replied to oleskool's topic in MJ Tech: Modification and Repairs
Oh I know, but the OP was having issues locating OEM with the number. -
83501426AD Currently on back order -
I’ll admit G. Your MJ is an inspiration for me to take it slow on both the XJ and T/A to get all the details just right. Love watching this build.
Mopar still makes them. -
new full taillight assembly coming from Oracle!
eaglescout526 replied to Pete M's topic in MJ Tech: Modification and Repairs
Well the armor look should solve busted tail lights. -
The UK use MPH.
1990 Comanche Eliminator
eaglescout526 replied to pizzaman09's topic in Member Projects: Your Comanches
No. The vac portion on top only dumps vacuum when the brake pedal is depressed and disengages cruise control. As for what it does with a t-case, i don't know. My MJ isn’t equipped with 4wheel drive and my XJ doesn’t have cruise.
