eaglescout526
Administrators
    13
  1. If it’s a manual trans, the trans has value not to mention its an external slave which is a nice upgrade for AX5/4 owners for the 87-94 years.
  2. Got the pass head off, broke some more bolts along the way and found that one of the exhaust bolts at the exhaust pipe was already broken half way. So more welding to do! Also got the pistons cleaned up I think they came out pretty good. Found out the lower head bolts were painted so I will be painting those now to match. Now to rinse and repeat with the pass head and get the exhaust manifold off and find some bolts to replace it the busted ones.
  3. I think it’s one of those really specific things that I could look up manifold bolts all damn day and get nothing like this bolt. It’s like the CPS bolt for our Renix Jeeps.
  4. Here is the bolt I broke. I am getting an NOS one thanks to a member for the lead on one. Not the broken one but that’s what these things look like. I keep telling myself MJs are hard to work with but so far the T/A 403 has proven to be a different animal despite there being more made than the MJ but I digress. Now for the rusted freeze plug one side is brass and the other is clearly iron to my surprise. On the bright side if it had any water, it all ran out this plug before it ever froze over. Also the head is in the shop. Probably won’t be ready till Wednesday when I will take the other head to be fixed.
  5. I have one of these books. It sadly didn’t offer the 2.5L performance cam but it offered the 4.0L one.
  6. Yeah those plates are the one thing we can’t figure out what their purpose is.
  7. My XJ has this plate and these plates can be found on 84-86 Jeeps. Knowing AMC those were probably something before the VINs or they could be sale zones. Just speculation. Probably doesn’t relate to what vehicle trim it is.
  8. Probably. Especially if people are tossing the BA10/5 and upgrading the AX5 to the 15. Hell they might becoming more scarce since it seems like nothing but the auto XJs are popping up more than a manual.
  9. Not many folks have stroked the 2.5L as most dump it and go for the 4.0L since it basically has the previous 4.2L crank shaft to help stroke it out. I say if it’s something you’re going to do, research the idea and do more research until your comfortable with stroking it out. I can’t say if it’s a good option or a good idea cause it just more depends on what you want to build and how you want to do it. A friend of mine and I want to stroke out the 2.5L. I have a spare block I’d like to try this with but don’t have time or funds at the moment.
  10. I see the tag for that one right there going towards the pass side of the pumpkin. That piece of metal sticking up is the tag for that one. I definitely don’t see it on the others.
  11. Does your axles still have the service tag ID plate on the cover? That usually has an AMC part number(or Chrysler if it’s newer) and the ratio beneath the part number.
  12. You can use those terminals. All terminals are created equal in terms of getting them connected to each other.
  13. What’s bad is I have two. Not including the one on my truck, my original and one I got from MJCARENA a few years ago. I really want to take my original one apart and fix it. But that’s a project down the road.
  14. Well all there is is OEM for tail gates. Unless keyparts starts making them which they may not as that requires getting Chrysler to approve of the Jeep on the tailgate itself.
  15. Well if there’s no aftermarket stamping going on for these, folks are gonna ask and if you tack on people making benches and tables out of tailgates and you find this one for the Jeep enthusiast to make either of those two, then it’s supply and demand value at that point. It’s like original tail lights.
  16. What about going weatherpack? 86 used those and they work fine and can handle various gauge wiring. Or if you look at other Chrysler cars in the yard from the same time period, you might find the connector you’re after.
  17. I had one guy a couple months ago pull up to my house while I was outside working on Chunk come up and ask if my MJ was for sale. Older gentleman too, in his 60's. I told him the she wasnt for sale. Told me about how they used to race them(which I knew about already but listened) and what not but I think they guy was upset that someone as young as I wouldnt sell a vehicle older than me but he seemed eager to get off my property in a huff after I said no...oh well. I rarely get asked.
  18. No problem! Good luck!
  19. *B1 -SA Charcoal AGC APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGW Transmission - 4-Spd. Automatic ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAE EMISS CONTROL TESTING & LABEL NHB HVY.DTY/AUX TRANS OIL COOLER NHQ Transmission Heater NMB ENGINE COOLING - STANDARD DUTY PE4 Colorado Red QE4 Colorado Red SBA POWER STEERING TBG SPARE TIRE - COMPACT YJP NEW VEHICLE SERVICE - WINDSOR Build date 8/2/87 Body code JL62 Sold by PETE ELLIS DODGE INC SOUTHGATE CA
  20. *Q7 CLOTH LOW-BACK BUCKET SEATS -SA CHARCOAL 172 Zone 72-Portland 1AA U.S. Dealer Retail 3V5 Customer Preferred Discount 5KR Midland Corporation ADA LIGHT GROUP ALR APA MONOTONE PAINT ARM RADIO AM/FM CASSETTE BAF 130 AMP ALTERNATOR BCX Maint. Free Battery BGA POWER FRONT DISC/REAR DRUM BRAKES CAC LOW BACK BUCKET SEATS CDB RECLINING FRONT SEATS CKA CARPETS - FLOOR AND CARGO AREA CUF FULL LENGTH FLOOR CONSOLE DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS DGS 4-SPEED AUTOMATIC AW4 TRANSMISSION DHA LOCK-UP TORQUE CONVERTER DHN COMMAND-TRAC PART TIME 4WD SYSTEM DHS PUSH TO PASS DJH 230MM FRONT AXLE DMD 3.55 REAR AXLE RATIO DRJ DANA 35 REAR AXLE ERH 4.0L I6 POWER TECH ENGINE GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GFD REAR SLIDING WINDOW GNC SUN VISORS W/ILLUM VANITY MIRRORS GRZ LEFT REMOTE MIRROR GSZ RIGHT REMOTE CONTROL MIRROR GTZ MANUAL REMOTE MIRRORS HCD DO NOT USE - SEE HCA JAY DO NOT USE - SEE JP, KA CLASSES JCA 85 MPH PRIMARY SPEEDOMETER JGB JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER K27 DO NOT USE K2B STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KLT KWD LAJ HEADLAMPS ON WARNING CHIMES LBB COURTESY LAMPS LBC GLOVE BOX LAMP LBD ASH TRAY LAMP LBE AMBIENT LIGHT LDA UNDERHOOD LAMP LHD HEADLAMP OFF TIME DELAY LMA HALOGEN HEADLAMPS LNJ FRONT FOG LAMPS MB1 Black Front Bumper MBJ Black Bumper MCA MDA Front License Plate Bracket MFK MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBC Compact Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires TZA Goodyear Brand Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z82 Right Front Spring Group XI Build date 8/21/90 Body code JL61 Sold by EASTSIDE CHRYSLER JEEP, BELLEVUE WA
  21. Build date 8/17/88 Body code TL61 Sold by JASPER JEEP-DODGE-CHRY-PLYMOUTH, JASPER GA
  22. Build date 1/13/87 Body code JH61 Sold by TEL-TWELVE A-J-R INC SOUTHFIELD MI
  23. *ZZ -ZZ ADA LIGHT PACKAGE AJT RADIO PREP GROUP AJZ BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MD8 Delete Front License Plate Bracket MFD BRIGHT GRILLE - TYPE I MWF BOX SIDE RAILS NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY SBA POWER STEERING Build date 9/11/85 Body code JP62
  24. For the 2.5L if you want some pep, make sure your sensors are reading within spec, mostly the TPS, and make sure your ignition system and fuel system is clean and free of corrosion and blockage(fuel lines and filter and injector). Then if you’re still not satisfied with making sure everything is up to snuff then I’d say go for the cam. Knock out the free stuff first before getting a new part. also converting to an electric fan, dropping power steering and AC will probably help gain some power too. I'm guessing where you want pep is take off in first gear huh? Honestly when AMC made the 2.5L, they did it for three reasons. New engine, ditch the Iron Dimwit from GM and to have a Jeep oriented engine.
  25. Probably not. Not may Jeep owners stick with the 2.5L like you and I. There is a 2.5L dedicated performance group on Facebook you can ask. Some guys have gone as far as to stroke and bore out the 2.5L to get up to a 3L engine. One of our very own members supercharged his or something of the nature. If your going for performance, you can give it a shot. If your just replacing it, then stick with stock.
