13
Yup, need one of the lamps that lights up the cargo area of the XJ with the switch in the assembly.
I think you’re right about that. I swear I had seen some 86’s and 7’s but I could be wrong.
Actually, late 87-90 had the polished letters. 84-early 87 used a brushed aluminum to all the nameplates. Just so no one is confused and finds different looking nameplates when replacing with the correct year.
90 MJ 2.5 AX4 bucking issue
eaglescout526 replied to Kikendallmd's topic in MJ Tech: Modification and Repairs
Check the TPS. The TBI has a pressure regulator on the body, if it hasn’t been serviced, it could be failing but don’t suspect that right away as that’s a full day job to rebuild the TBI. -
CB Radio Mounting Locations?
eaglescout526 replied to CheepComanche's topic in MJ Tech: Modification and Repairs
Is your MJ an auto or manual? I ask cause if it’s a manual truck, you can use the TCU mounting studs on the lower part of the dash to make a bracket from that to mount your CB. -
I don’t see any gaskets in the catalog. So maybe the way G did it is the way they did it in the factory or at the dealer.
This issue makes me think TPS. I’ve had it to where I would be driving and I’d get the same thing where it would hesitate and buck and go back to normal driving until it acts up again a few miles later. Found it to be TPS as that’s what tells the ECU to more or less dump fuel. -
I can take a look at my XJ. I know some nutserts can come with an o-ring on them to help with the waterproofing. My best guess would be that they had gaskets with the kit.
Chunk, A 1984 XJ
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
Got this done last night. It is now ready for the headliner and dome lamps. Slight hiccup in the headliner. My dad has tweed to do the liner but there’s not enough sadly so I had to order more. This will match the seats a bit more and be more in line with my MJ and her headliner. Also the window seals came in but not the wipes, those are backorder till April(no these aren’t OEM sadly as those are gone now.) -
TBI or Carb? '86 2.5L to 3.4L upgrade
eaglescout526 replied to FigurativeGarbage's topic in MJ Tech: Modification and Repairs
You should probably start a build thread on this at this point. Doesn’t seem like much of questions here and just more documentation of your swap. -
Chunk, A 1984 XJ
head liner is out, it is gonna get recovered tomorrow. I made a new roof harness to use the new dome/map lamp and one for the cargo lamp as well. Currently don't have the right cargo lamp but when I find one I will do the swap which will be easy. Also got the holes cut/expanded for both lamps. Gonna be really nice to have both. -
Chunk, A 1984 XJ
Looks like the headliner is coming out for a possible recover and gonna put in a dome lamp and cargo lamp. -
*ZZ -ZZ AGR AJY Popular Equipment Package BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDJ 5SPD MANUAL TRANS A881 EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAE EMISS CONTROL TESTING LABEL NFA TANK - 23 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY RAF RADIO - AM/FM/MTR SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN Build date 8/14/85 Body code TM62
*ZZ -ZZ AGR AGY Seating Group AJY Popular Equipment Package BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DGK Transmission - 4-Spd. Automatic EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY RAB Radio - AM/FM SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN WJM Wheels - 15 x 7.0 Chrome YJA NEW VEHICLE SERVICE Build date 7/25/85 Body code TM62
Passenger side head is done and the shop removed the two broken bolts too! I didn’t think they would’ve done that but I’ll take it! Also as I dig more and more into finding things to be powder coated, I have fully learned and accepted that I do indeed need to buy a full radiator core support. It is too far rusted on the drivers side right at the battery tray to be of use and stay installed.
So I just did the acetone ATF mix on my T/As power steering pump pulley as it needs to be removed and powder coated like the rest of the parts and last night it was a pain to get it to budge. I put the mix on the pulley center and voila! I got it off with out exerting my energy.
Chunk, A 1984 XJ
And you’re right. They really are comfy. Like they may not have the wings that later seats do but man I feel comfy as I type this while sitting in the drivers seat haha. No stress on the back what so ever. -
Leaf Springs Sitting at Different Heights
eaglescout526 replied to howeitsdone's topic in MJ Tech: Modification and Repairs
Well that was my 2 cents haha. Mine was off for a bit until I found out I had one of the shackles flipped the wrong way. -
Are your shackles facing the same way? -
Temp light comes on and off
eaglescout526 replied to Sgt Thor's topic in MJ Tech: Modification and Repairs
There’s two types of the temp and oil sensors. One is a sensor that is for the gauges and the other is a sender for the light. -
I bet you anything it might have the gauge sensor instead of the one for the light. -
I have a full perforated leather wrap one doing nothing Would look fantastic in my 84 actually haha.
Chunk, A 1984 XJ
Chunk, A 1984 XJ
Lets see, what did I get done today. Floors are painted check!(pill capsules are for screws so I don't lose them, not actual medicine) shift gate has been changed for the 228/9 t-case. Vinyl floor has been put back in. Seats have been put back in and tested to make sure they still work. Seat belt buckles are in. Drivers side not chiming, looking into that. Lots have been done today!
